pads2005 net报错
5328|3
 楼主| qixiboy 发表于 2007-6-6 10:53 | 显示全部楼层 |阅读模式
我有个原理图是protel转过去的,转时没有错误。<br />可是在生成PCB时却出现了下面的提示:<br />*Not&nbsp;valid&nbsp;pin&nbsp;name&nbsp;for&nbsp;part&nbsp;type&nbsp;B15<br />JP1.1&nbsp;C1.2&nbsp;P1.B15&nbsp;P1.B3&nbsp;P1.B17&nbsp;&nbsp;(这些是连到GND的)<br />这是怎么一回事呢?<br /><br />部分错误提示:<br />Part&nbsp;name&nbsp;already&nbsp;used&nbsp;J5<br />J5&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;HEADER_7X2@HDR2X7<br />Part&nbsp;name&nbsp;already&nbsp;used&nbsp;C190<br />C190&nbsp;&nbsp;&nbsp;&nbsp;CAP_NP@0603<br />Part&nbsp;name&nbsp;already&nbsp;used&nbsp;C191<br />C191&nbsp;&nbsp;&nbsp;&nbsp;CAP_NP@0603<br />*Not&nbsp;valid&nbsp;pin&nbsp;name&nbsp;for&nbsp;part&nbsp;type&nbsp;B15<br />JP1.1&nbsp;C1.2&nbsp;P1.B15&nbsp;P1.B3&nbsp;P1.B17&nbsp;<br />*Not&nbsp;valid&nbsp;pin&nbsp;name&nbsp;for&nbsp;part&nbsp;type&nbsp;B22<br />P1.B22&nbsp;P1.B28&nbsp;P1.B34&nbsp;P1.B38&nbsp;P1.B46&nbsp;<br />*Not&nbsp;valid&nbsp;pin&nbsp;name&nbsp;for&nbsp;part&nbsp;type&nbsp;B49<br />P1.B49&nbsp;P1.B57&nbsp;P1.A18&nbsp;P1.A24&nbsp;P1.A30&nbsp;<br />*Not&nbsp;valid&nbsp;pin&nbsp;name&nbsp;for&nbsp;part&nbsp;type&nbsp;A35<br />P1.A35&nbsp;P1.A37&nbsp;P1.A42&nbsp;P1.A48&nbsp;P1.A56&nbsp;<br />*Not&nbsp;valid&nbsp;pin&nbsp;name&nbsp;for&nbsp;part&nbsp;type&nbsp;B9<br />C22.2&nbsp;P1.B9&nbsp;P1.B11&nbsp;C23.1&nbsp;C3.2&nbsp;<br />*Bad&nbsp;*CONNECTION*&nbsp;ascii&nbsp;data&nbsp;format,&nbsp;nets&nbsp;must&nbsp;contain&nbsp;more&nbsp;than&nbsp;one&nbsp;pin.&nbsp;Signal&nbsp;MUTEC<br />*Bad&nbsp;*CONNECTION*&nbsp;ascii&nbsp;data&nbsp;format,&nbsp;nets&nbsp;must&nbsp;contain&nbsp;more&nbsp;than&nbsp;one&nbsp;pin.&nbsp;Signal&nbsp;GPIO57<br />*Bad&nbsp;*CONNECTION*&nbsp;ascii&nbsp;data&nbsp;format,&nbsp;nets&nbsp;must&nbsp;contain&nbsp;more&nbsp;than&nbsp;one&nbsp;pin.&nbsp;Signal&nbsp;AO_SD3<br />*Bad&nbsp;*CONNECTION*&nbsp;ascii&nbsp;data&nbsp;format,&nbsp;nets&nbsp;must&nbsp;contain&nbsp;more&nbsp;than&nbsp;one&nbsp;pin.&nbsp;Signal&nbsp;AO_SD2<br />*Bad&nbsp;*CONNECTION*&nbsp;ascii&nbsp;data&nbsp;format,&nbsp;nets&nbsp;must&nbsp;contain&nbsp;more&nbsp;than&nbsp;one&nbsp;pin.&nbsp;Signal&nbsp;AO_SD1
 楼主| qixiboy 发表于 2007-6-6 10:54 | 显示全部楼层
edanzg 发表于 2007-6-7 20:42 | 显示全部楼层
可能重命名了。
