- #include "stm32f10x.h"
- //设置主频
- #define SYSCLK_FREQ 108000000UL
- //以下不用更改
- #define RCC_CFGR_PLLMULL17 (0x08000000UL|RCC_CFGR_PLLMULL2)
- #define RCC_CFGR_PLLMULL18 (0x08000000UL|RCC_CFGR_PLLMULL3)
- #define RCC_CFGR_PLLMULL19 (0x08000000UL|RCC_CFGR_PLLMULL4)
- #define RCC_CFGR_PLLMULL20 (0x08000000UL|RCC_CFGR_PLLMULL5)
- #define RCC_CFGR_PLLMULL21 (0x08000000UL|RCC_CFGR_PLLMULL6)
- #define RCC_CFGR_PLLMULL22 (0x08000000UL|RCC_CFGR_PLLMULL7)
- #define RCC_CFGR_PLLMULL23 (0x08000000UL|RCC_CFGR_PLLMULL8)
- #define RCC_CFGR_PLLMULL24 (0x08000000UL|RCC_CFGR_PLLMULL9)
- #define RCC_CFGR_PLLMULL25 (0x08000000UL|RCC_CFGR_PLLMULL10)
- #define RCC_CFGR_PLLMULL26 (0x08000000UL|RCC_CFGR_PLLMULL11)
- #define RCC_CFGR_PLLMULL27 (0x08000000UL|RCC_CFGR_PLLMULL12)
- #define RCC_CFGR_PLLMULL28 (0x08000000UL|RCC_CFGR_PLLMULL13)
- #define RCC_CFGR_PLLMULL29 (0x08000000UL|RCC_CFGR_PLLMULL14)
- #define RCC_CFGR_PLLMULL30 (0x08000000UL|RCC_CFGR_PLLMULL15)
- #define RCC_CFGR_PLLMULL31 (0x08000000UL|RCC_CFGR_PLLMULL16)
- #define RCC_CFGR_PLLMULL32 (0x08040000UL|RCC_CFGR_PLLMULL16)
- #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL)
- /* #define DATA_IN_ExtSRAM */
- #endif
- /*!< Uncomment the following line if you need to relocate your vector Table in
- Internal SRAM. */
- /* #define VECT_TAB_SRAM */
- #define VECT_TAB_OFFSET 0x0 /*!< Vector Table base offset field.
- This value must be a multiple of 0x200. */
- * Clock Definitions
- uint32_t SystemCoreClock = SYSCLK_FREQ;
- __I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9};
- static void SetSysClock(void);
- void SystemInit (void)
- /* Reset the RCC clock configuration to the default reset state(for debug purpose) */
- /* Set HSION bit */
- RCC->CR |= (uint32_t)0x00000001;
- /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */
- #ifndef STM32F10X_CL
- RCC->CFGR &= (uint32_t)0xF8FF0000;
- #else
- RCC->CFGR &= (uint32_t)0xF0FF0000;
- #endif /* STM32F10X_CL */
- /* Reset HSEON, CSSON and PLLON bits */
- RCC->CR &= (uint32_t)0xFEF6FFFF;
- /* Reset HSEBYP bit */
- RCC->CR &= (uint32_t)0xFFFBFFFF;
- /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */
- RCC->CFGR &= (uint32_t)0xFF80FFFF;
- #ifdef STM32F10X_CL
- /* Reset PLL2ON and PLL3ON bits */
- RCC->CR &= (uint32_t)0xEBFFFFFF;
- /* Disable all interrupts and clear pending bits */
- RCC->CIR = 0x00FF0000;
- /* Reset CFGR2 register */
- RCC->CFGR2 = 0x00000000;
- #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
- RCC->CIR = 0x009F0000;
- #else
- #ifdef DATA_IN_ExtSRAM
- SystemInit_ExtMemCtl();
- #endif /* DATA_IN_ExtSRAM */
- #endif
- /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */
- /* Configure the Flash Latency cycles and enable prefetch buffer */
- SetSysClock();
- #ifdef VECT_TAB_SRAM
- SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. */
- #else
- SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. */
- #endif
- * [url=home.php?mod=space&uid=247401]@brief[/url] Update SystemCoreClock variable according to Clock Register Values.
- * The SystemCoreClock variable contains the core clock (HCLK), it can
- * be used by the user application to setup the SysTick timer or configure
- * other parameters.
- * [url=home.php?mod=space&uid=536309]@NOTE[/url] Each time the core clock (HCLK) changes, this function must be called
- * to update SystemCoreClock variable value. Otherwise, any configuration
- * based on this variable will be incorrect.
- * [url=home.php?mod=space&uid=536309]@NOTE[/url] - The system frequency computed by this function is not the real
- * frequency in the chip. It is calculated based on the predefined
- * constant and the selected clock source:
- * - If SYSCLK source is HSI, SystemCoreClock will contain the HSI_VALUE(*)
- * - If SYSCLK source is HSE, SystemCoreClock will contain the HSE_VALUE(**)
- * - If SYSCLK source is PLL, SystemCoreClock will contain the HSE_VALUE(**)
- * or HSI_VALUE(*) multiplied by the PLL factors.
- * (*) HSI_VALUE is a constant defined in stm32f1xx.h file (default value
- * 8 MHz) but the real value may vary depending on the variations
- * in voltage and temperature.
- * (**) HSE_VALUE is a constant defined in stm32f1xx.h file (default value
- * 8 MHz or 25 MHz, depedning on the product used), user has to ensure
- * that HSE_VALUE is same as the real frequency of the crystal used.
- * Otherwise, this function may have wrong result.
- * - The result of this function could be not correct when using fractional
- * value for HSE crystal.
- * @param None
- * @retval None
- void SystemCoreClockUpdate (void)
- uint32_t tmp = 0, pllmull = 0, pllsource = 0;
- uint32_t prediv1source = 0, prediv1factor = 0, prediv2factor = 0, pll2mull = 0;
- #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL)
- uint32_t prediv1factor = 0;
- #endif /* STM32F10X_LD_VL or STM32F10X_MD_VL or STM32F10X_HD_VL */
- /* Get SYSCLK source -------------------------------------------------------*/
- tmp = RCC->CFGR & RCC_CFGR_SWS;
- switch (tmp)
- case 0x00: /* HSI used as system clock */
- SystemCoreClock = HSI_VALUE;
- break;
- case 0x04: /* HSE used as system clock */
- SystemCoreClock = HSE_VALUE;
- break;
- case 0x08: /* PLL used as system clock */
- /* Get PLL clock source and multiplication factor ----------------------*/
- pllmull = RCC->CFGR & RCC_CFGR_PLLMULL;
- pllsource = RCC->CFGR & RCC_CFGR_PLLSRC;
- pllmull = ( pllmull >> 18) + 2;
- if (pllsource == 0x00)
- /* HSI oscillator clock divided by 2 selected as PLL clock entry */
- SystemCoreClock = (HSI_VALUE >> 1) * pllmull;
- else
- prediv1factor = (RCC->CFGR2 & RCC_CFGR2_PREDIV1) + 1;
- /* HSE oscillator clock selected as PREDIV1 clock entry */
- SystemCoreClock = (HSE_VALUE / prediv1factor) * pllmull;
- #else
- /* HSE selected as PLL clock entry */
- if ((RCC->CFGR & RCC_CFGR_PLLXTPRE) != (uint32_t)RESET)
- {/* HSE oscillator clock divided by 2 */
- SystemCoreClock = (HSE_VALUE >> 1) * pllmull;
- else
- SystemCoreClock = HSE_VALUE * pllmull;
- #endif
- #else
- pllmull = pllmull >> 18;
- if (pllmull != 0x0D)
- pllmull += 2;
- else
- { /* PLL multiplication factor = PLL input clock * 6.5 */
- pllmull = 13 / 2;
- else
- {/* PREDIV1 selected as PLL clock entry */
- /* Get PREDIV1 clock source and division factor */
- prediv1source = RCC->CFGR2 & RCC_CFGR2_PREDIV1SRC;
- if (prediv1source == 0)
- else
- {/* PLL2 clock selected as PREDIV1 clock entry */
- /* Get PREDIV2 division factor and PLL2 multiplication factor */
- prediv2factor = ((RCC->CFGR2 & RCC_CFGR2_PREDIV2) >> 4) + 1;
- pll2mull = ((RCC->CFGR2 & RCC_CFGR2_PLL2MUL) >> 8 ) + 2;
- SystemCoreClock = (((HSE_VALUE / prediv2factor) * pll2mull) / prediv1factor) * pllmull;
- break;
- default:
- break;
- /* Compute HCLK clock frequency ----------------*/
- /* Get HCLK prescaler */
- tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)];
- /* HCLK clock frequency */
- SystemCoreClock >>= tmp;
- * [url=home.php?mod=space&uid=247401]@brief[/url] Configures the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers.
- * @param None
- * @retval None
- const uint32_t RCC_CFGR_PLL_TAB[]=
- 0,
- 0,
- RCC_CFGR_PLLMULL2,
- RCC_CFGR_PLLMULL3,
- RCC_CFGR_PLLMULL4,
- RCC_CFGR_PLLMULL5,
- RCC_CFGR_PLLMULL6,
- RCC_CFGR_PLLMULL7,
- RCC_CFGR_PLLMULL8,
- RCC_CFGR_PLLMULL9,
- RCC_CFGR_PLLMULL10,
- RCC_CFGR_PLLMULL11,
- RCC_CFGR_PLLMULL12,
- RCC_CFGR_PLLMULL13,
- RCC_CFGR_PLLMULL14,
- RCC_CFGR_PLLMULL15,
- RCC_CFGR_PLLMULL16,
- RCC_CFGR_PLLMULL17,
- RCC_CFGR_PLLMULL18,
- RCC_CFGR_PLLMULL19,
- RCC_CFGR_PLLMULL20,
- RCC_CFGR_PLLMULL21,
- RCC_CFGR_PLLMULL22,
- RCC_CFGR_PLLMULL23,
- RCC_CFGR_PLLMULL24,
- RCC_CFGR_PLLMULL25,
- RCC_CFGR_PLLMULL26,
- RCC_CFGR_PLLMULL27,
- RCC_CFGR_PLLMULL28,
- RCC_CFGR_PLLMULL29,
- RCC_CFGR_PLLMULL30,
- RCC_CFGR_PLLMULL31,
- RCC_CFGR_PLLMULL32
- static void SetSysClockToPll(uint8_t __pre,uint8_t __pllmul)
- __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
- /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
- /* Enable HSE */
- RCC->CR |= ((uint32_t)RCC_CR_HSEON);
- /* Wait till HSE is ready and if Time out is reached exit */
- do
- HSEStatus = RCC->CR & RCC_CR_HSERDY;
- StartUpCounter++;
- } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
- if ((RCC->CR & RCC_CR_HSERDY) != RESET)
- HSEStatus = (uint32_t)0x01;
- else
- HSEStatus = (uint32_t)0x00;
- if (HSEStatus == (uint32_t)0x01)
- /* Enable Prefetch Buffer */
- FLASH->ACR |= FLASH_ACR_PRFTBE;
- /* Flash 2 wait state */
- FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
- #if SYSCLK_FREQ>48000000ul
- FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
- #elif SYSCLK_FREQ>24000000ul
- FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_1;
- #endif
- /* HCLK = SYSCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
- /* PCLK2 = HCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
- /* PCLK1 = HCLK */
- RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
- //8/2*(15+12)=108MHz
- uint32_t __cfgr=RCC_CFGR_PLLSRC_HSE;
- if(__pre)
- __cfgr |=RCC_CFGR_PLLXTPRE_HSE_Div2;
- if(__pllmul<=32)
- __cfgr |= RCC_CFGR_PLL_TAB[__pllmul];
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
- RCC_CFGR_PLLMULL));
- RCC->CFGR |= __cfgr;
- /* Enable PLL */
- RCC->CR |= RCC_CR_PLLON;
- /* Wait till PLL is ready */
- while((RCC->CR & RCC_CR_PLLRDY) == 0)
- /* Select PLL as system clock source */
- RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
- RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
- /* Wait till PLL is used as system clock source */
- while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
- else
- { /* If HSE fails to start-up, the application will have wrong clock
- configuration. User can add here some code to deal with this error */
- uint8_t __pre=1;
- uint8_t __pllmul=(SYSCLK_FREQ) / ((HSE_VALUE)/2);
- SetSysClockToPll(__pre,__pllmul);
