不知道怎么发图。。。算了估计也没什么人感兴趣
在CANR标志寄存器 寄存器下
Transmitter Status Bits — The values of the error counters control the actual CAN bus status of the MSCAN. As soon as the status change interrupt flag (CSCIF) is set, these bits indicate the appropriate transmitter related
CAN bus status of the MSCAN. The coding for the bits TSTAT1, TSTAT0 is:
00 TxOK: 0 ≤ transmit error counter ≤ 96
01 TxWRN: 96 < transmit error counter ≤ 127
10 TxERR: 127 < transmit error counter ≤ 255
11 Bus-Off: transmit error counter > 255
