还有在 mig_7series_v1_7_s7ven_data_gen里面 parameter nCK_PER_CLK = 2,是不是程序错了,这个参数不是应该是4 吗?
还有generate
if (nCK_PER_CLK == 2)
begin: calib_data32
always @ (posedge clk_i)
if (rst_i) begin
next_calib_data <= 1'b0;
calib_data <= #TCQ {{(NUM_DQ_PINS/8){8'h55}},{(NUM_DQ_PINS/8){8'haa}},{(NUM_DQ_PINS/8){8'h00}},{(NUM_DQ_PINS/8){8'hff}}};
end
else if (cmd_startA)
begin
next_calib_data <=#TCQ 1'b1;
// calib_data <= 'b0;
end
else if (fifo_rdy_i)
begin
next_calib_data <= #TCQ ~next_calib_data;
if (next_calib_data )
calib_data <= #TCQ {{(NUM_DQ_PINS/8){8'h66}},{(NUM_DQ_PINS/8){8'h99}},{(NUM_DQ_PINS/8){8'haa}},{(NUM_DQ_PINS/8){8'h55}}};
else
end
end
else
begin: calib_data64 // when nCK_PER_LK =4 has not verified
if (rst_i) begin
calib_data <= #TCQ {{(NUM_DQ_PINS/8){16'h5555}},{(NUM_DQ_PINS/8){16'haaaa}},{(NUM_DQ_PINS/8){16'h0000}},{(NUM_DQ_PINS/8){16'hffff}}};
end
begin
end
begin
calib_data <= #TCQ {{(NUM_DQ_PINS/8){16'h6666}},{(NUM_DQ_PINS/8){16'h9999}},{(NUM_DQ_PINS/8){16'haaaa}},{(NUM_DQ_PINS/8){16'h5555}}};
else
end
end
endgenerate
这段应该是PHY校验的数据吧,为什么我把这一段删掉里了,似乎对校验过程没有影响。
