msp430 spi
1362|0
 楼主| pengchunhua123 发表于 2013-11-14 20:20 | 显示全部楼层 |阅读模式
为什么我的这个程序实现不了数码管显示啊。。各位大侠帮帮忙啊。。本人菜鸟一枚啊,程序附上:
#include <MSP430x24x.h>
#define uchar unsigned char
#define uint unsigned int
#define LCK_SET P1OUT|=1
#define LCK_CLR P1OUT&=~1
uchar const table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,  //共阴数码管段选码表,无小数点
                               0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned int Data;
volatile unsigned int i;
void delayms(uint t)
    uint i;
    while(t--)
      for(i=1330;i>0;i--);//进过参数的调整
void SendSpi(uchar Dat)
   UCA0TXBUF = Dat;
   while (!(IFG2 & UCA0TXIFG));
//   return(UCA0TXBUF);
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog timer
  P3SEL |= 0x11;                            // P3.0,4 USCI_A0 option select
  UCA0CTL0 |= UCCKPH + UCMSB + UCMST + UCSYNC;  // 3-pin, 8-bit SPI master
  UCA0CTL1 |= UCSSEL_2;                     // SMCLK
  UCA0BR0 |= 0x02;
  UCA0BR1 = 0;
  UCA0MCTL = 0;
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  P1DIR=0x01;
  P1SEL=0;
  Data = 0x0FF;                             // Load inital data
  while(1);
    Data++;                                 // Increment Data value - Set BREAKPOINT here
    SendSpi(table[Data%16]);
   LCK_CLR;
    LCK_SET;
    delayms(100);          // Delay
