MSP430G2553系列DCO信息丢失后的补救
2426|2
 楼主| 雁舞白沙 发表于 2013-12-27 14:47 | 显示全部楼层 |阅读模式
//  MSP430G2xx3 Demo - DCO Calibration Constants Programmer
//  NOTE: THIS CODE REPLACES THE TI FACTORY-PROGRAMMED DCO CALIBRATION
//  CONSTANTS LOCATED IN INFOA WITH NEW VALUES. USE ONLY IF THE ORIGINAL
//  CONSTANTS ACCIDENTALLY GOT CORRUPTED OR ERASED.
//  Description: This code re-programs the G2xx2 DCO calibration constants.
//  A software FLL mechanism is used to set the DCO based on an external
//  32kHz reference clock. After each calibration, the values from the
//  clock system are read out and stored in a temporary variable. The final
//  frequency the DCO is set to is 1MHz, and this frequency is also used
//  during Flash programming of the constants. The program end is indicated
//  by the blinking LED.
//  ACLK = LFXT1/8 = 32768/8, MCLK = SMCLK = target DCO
//  //* External watch crystal installed on XIN XOUT is required for ACLK *//
//           MSP430G2xx3
//     /|\|            XIN|-
//      | |               | 32kHz
//      --|RST        XOUT|-
//        |           P1.0|--> LED
//        |           P1.4|--> SMLCK = target DCO
//  D. Dang
//  Texas Instruments Inc.
//  May 2010
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 3.42A
#include "msp430g2553.h"
#define DELTA_1MHZ    244                   // 244 x 4096Hz = 999.4Hz
#define DELTA_8MHZ    1953                  // 1953 x 4096Hz = 7.99MHz
#define DELTA_12MHZ   2930                  // 2930 x 4096Hz = 12.00MHz
#define DELTA_16MHZ   3906                  // 3906 x 4096Hz = 15.99MHz
unsigned char CAL_DATA[8];                  // Temp. storage for constants
volatile unsigned int i;
int j;
char *Flash_ptrA;                           // Segment A pointer
void SetDCO(unsigned int Delta)            // Set DCO to selected frequency
  unsigned int Compare, Oldcapture = 0;
  BCSCTL1 |= DIVA_3;                        // ACLK = LFXT1CLK/8
  TACCTL0 = CM_1 + CCIS_1 + CAP;            // CAP, ACLK
  TACTL = TASSEL_2 + MC_2 + TACLR;          // SMCLK, cont-mode, clear
  while (1)
    while (!(CCIFG & TACCTL0));             // Wait until capture occured
    TACCTL0 &= ~CCIFG;                      // Capture occured, clear flag
    Compare = TACCR0;                       // Get current captured SMCLK
    Compare = Compare - Oldcapture;         // SMCLK difference
    Oldcapture = TACCR0;                    // Save current captured SMCLK
    if (Delta == Compare)
      break;                                // If equal, leave "while(1)"
    else if (Delta < Compare)
      DCOCTL--;                             // DCO is too fast, slow it down
      if (DCOCTL == 0xFF)                   // Did DCO roll under?
        if (BCSCTL1 & 0x0f)
          BCSCTL1--;                        // Select lower RSEL
    else
      DCOCTL++;                             // DCO is too slow, speed it up
      if (DCOCTL == 0x00)                   // Did DCO roll over?
        if ((BCSCTL1 & 0x0f) != 0x0f)
          BCSCTL1++;                        // Sel higher RSEL
  TACCTL0 = 0;                              // Stop TACCR0
  TACTL = 0;                                // Stop Timer_A
  BCSCTL1 &= ~DIVA_3;                       // ACLK = LFXT1CLK
void SetDcoConn(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  for (i = 0; i < 0xfffe; i++);             // Delay for XTAL stabilization
  P1OUT = 0x00;                             // Clear P1 output latches
  P1SEL = 0x10;                             // P1.4 SMCLK output
  P1DIR = 0x11;                             // P1.0,4 output
  j = 0;                                    // Reset pointer
  SetDCO(DELTA_16MHZ);                     // Set DCO and obtain constants
  CAL_DATA[j++] = DCOCTL;
  CAL_DATA[j++] = BCSCTL1;
  SetDCO(DELTA_12MHZ);                     // Set DCO and obtain constants
  SetDCO(DELTA_8MHZ);                      // Set DCO and obtain constants
  SetDCO(DELTA_1MHZ);                      // Set DCO and obtain constants
  Flash_ptrA = (char *)0x10C0;              // Point to beginning of seg A
  FCTL2 = FWKEY + FSSEL0 + FN1;             // MCLK/3 for Flash Timing Generator
  FCTL1 = FWKEY + ERASE;                    // Set Erase bit
  FCTL3 = FWKEY + LOCKA;                    // Clear LOCK & LOCKA bits
  *Flash_ptrA = 0x00;                       // Dummy write to erase Flash seg A
  FCTL1 = FWKEY + WRT;                      // Set WRT bit for write operation
  Flash_ptrA = (char *)0x10F8;              // Point to beginning of cal consts
  for (j = 0; j < 8; j++)
    *Flash_ptrA++ = CAL_DATA[j];            // re-flash DCO calibration data
  FCTL1 = FWKEY;                            // Clear WRT bit
  FCTL3 = FWKEY + LOCKA + LOCK;             // Set LOCK & LOCKA bit
  while (1)
    P1OUT ^= 0x01;                          // Toggle LED
    for (i = 0; i < 0x4000; i++);           // SW Delay
SetDco-2553.rar (1.9 KB, 下载次数: 6)
SetDco-2132.rar (1.11 KB, 下载次数: 2)
ayl439 发表于 2013-12-27 14:50 | 显示全部楼层
 楼主| 雁舞白沙 发表于 2013-12-27 14:52 | 显示全部楼层
void CpuClk(void)
    WDTCTL = WDTPW + WDTHOLD;                 // 禁止看门狗
    if (CALBC1_8MHZ ==0xFF || CALDCO_8MHZ == 0xFF)
        SetDcoConn();                               // 如果校正常数被删除锁住CPU!!
    BCSCTL1 = CALBC1_8MHZ;
    DCOCTL = CALDCO_8MHZ;
    P2SEL &= ~BIT6;
    P2SEL &= ~BIT7;
    BCSCTL2 &= ~(SELM1+SELM0);         //select DCOCLK for MCLK
    BCSCTL2 &=~(DIVM1 + DIVM0);
    BCSCTL2 &=~(DIVS_3);
个人签名:学者会友QQ群:72137827 三人行,必有我师!
213
