这是我使用过的代码   仅供参考
#include <csl.h>
#include <csl_pll.h>
#include <csl_chip.h>
#include <stdio.h>
#define ioport_csl_sel 1
void CLK_init()
        ioport unsigned int *clkmd;
        ioport unsigned int *sysr;
        clkmd =  (unsigned int *)0x1c00;
        sysr  =  (unsigned int *)0x07fd;
        *clkmd = 0x2613;                        //144MHz
        *sysr  = 0x0006;                        //CLKDIV = 0-7 ->CLKOUT = CPU clock/(2*CLKDIV)
        //CLKOUT = 144/12 = 12MHz
PLL_Config myConfig        = {
        0,                /*IAI:PLL将使用与进入Idle状态之前相同的设置进行锁定*/
        1,                /*IOB:时钟发生器切换到旁路模式,重新开始PLL锁相过程*/
        24,                /*锁定模式下的PLL倍频值*/        //12M * 24
        1                /*旁路下的分频值*/                  //2分频
void main(void)
        #if ioport_csl_sel
                /*初始化CSL库*/
            CSL_init();
            /*设置系统的运行速度为144MHz*/
            PLL_config(&myConfig);
                CHIP_RSET(SYSR,4);                //CLKOUT = CPU clock/(2*CLKDIV)  CLKOUT = 144/8 = 18MHz
                while(1);
        #else
                CLK_init();
                while(1);
        #endif
