SPartan-6 JTAG 总是program failed
3726|3
 楼主| peric112358 发表于 2014-6-12 12:58 | 显示全部楼层 |阅读模式
最近测试自己设计的板子,发现JTAG总是失败,芯片为XC6SLX25-L1FGG484I,请高手帮忙分析指点,下面是错误报告,GUI --- Auto connect to cable...
INFO:iMPACT - Connecting to TCF agent...
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.4
INFO:iMPACT - Digilent Plugin: no JTAG device was found.
AutoDetecting cable. Please wait.
*** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusb_emb.sys found.
Driver version: src=1029, dest=1029.
Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 X86 32bit SYS 14:35:41, version = 1021.
Cable PID = 0008.
Max current requested during enumeration is 300 mA.
Type = 0x0005.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 2401.
File version of D:/Xilinx/14.5/ISE_DS/ISE/data/xusb_xp2.hex = 2401.
Firmware hex file version = 2401.
PLD file version = 200Dh.
PLD version = 200Dh.
PROGRESS_END - End Operation.
Elapsed time =      1 sec.
Type = 0x0005.
ESN option: 0000128F160001.
Attempting to identify devices in the boundary-scan chain configuration...
INFO:iMPACT - Current time: 2014/6/12 12:55:17
Identifying chain contents...'0': : Manufacturer's ID = Xilinx xc6slx25, Version : 2
INFO:iMPACT:1777 -
Reading D:/Xilinx/14.5/ISE_DS/ISE/spartan6/data/xc6slx25.bsd...
INFO:iMPACT:501 - '1': Added Device xc6slx25 successfully.
done.
Elapsed time =      0 sec.
'1': Loading file 'E:/ISE design/DFB_test/top.bit' ...
done.
INFO:iMPACT:2257 - Startup Clock has been changed to 'JtagClk' in the bitstream stored in memory,
but the original bitstream file remains unchanged.
UserID read from the bitstream file = 0xFFFFFFFF.
Data width read from the bitstream file = 1.
INFO:iMPACT - Current time: 2014/6/12 12:55:32
Maximum TCK operating frequency for this device chain: 25000000.
Validating chain...
Boundary-scan chain validated successfully.
'1': Programming device...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
[0] CRC ERROR                                                              :         0
[1] IDCODE ERROR                                                           :         0
[2] DCM LOCK STATUS                                                        :         0
[3] GTS_CFG_B STATUS                                                       :         0
[4] GWE STATUS                                                             :         0
[5] GHIGH STATUS                                                           :         0
[6] DECRYPTION ERROR                                                       :         0
[7] DECRYPTOR ENABLE                                                       :         0
[8] HSWAPEN PIN                                                            :         0
[9] MODE PIN M[0]                                                          :         0
[10] MODE PIN M[1]                                                         :         0
[11] RESERVED                                                              :         0
[12] INIT_B PIN                                                            :         0
[13] DONE PIN                                                              :         0
[14] SUSPEND STATUS                                                        :         0
[15] FALLBACK STATUS                                                       :         0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0000 0000 0000 0000
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT:188 - '1': Programming completed successfully.
LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '1': Checking done pin....done.
'1': Programming terminated. DONE did not go high.
Elapsed time =      3 sec.
连接如图所示。没有经过配置芯片,是JTAG直连的。
denglisong149 发表于 2014-6-14 14:58 | 显示全部楼层
内核电压没有
评分
参与人数 1威望 +1 收起 理由
peric112358 + 1 赞一个!
查看全部评分
 楼主| peric112358 发表于 2014-6-17 13:59 | 显示全部楼层
内核电压没有
换了块芯片好使了,但看芯片的焊接应该挺好的,有空把拆下的芯片焊下试试。。。
gaolou1991 发表于 2015-9-27 10:30 | 显示全部楼层
能帮我看下我的这个是咋回事。也下载不了。
https://bbs.21ic.com/icview-1127388-1-1.html
