[STM32F1] 想让串口1和串口3同时实现打印输出在PC上,为什么3不正常
1521|6
 楼主| InsertTec 发表于 2014-6-26 11:02 | 显示全部楼层 |阅读模式
  1.    //USART ³õʼ»¯ÉèÖÃ
  2.   USART_InitStructure.USART_BaudRate = bound;
  3.   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  4.   USART_InitStructure.USART_StopBits = USART_StopBits_1;
  5.   USART_InitStructure.USART_Parity = USART_Parity_No;
  6.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  7.   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  8.     //Usart1 NVIC ÅäÖÃ
  9.   NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  10.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0x01 ;
  11.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x00;
  12.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;   //IRQͨµÀʹÄÜ
  13.   NVIC_Init(&NVIC_InitStructure);
  14.   USART_Init(USART1, &USART_InitStructure);
  15.   USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//¿ªÆôÖжÏ
  16.   USART_Cmd(USART1, ENABLE);    //ʹÄÜ´®¿Ú
  17. }
  18. //USART3配置
  19. void uart3_init(u32 bound)
  20. {
  21.   GPIO_InitTypeDef GPIO_InitStructure;
  22.   USART_InitTypeDef USART_InitStructure;
  23.    NVIC_InitTypeDef NVIC_InitStructure;
  24.
  25.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3|RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
  26.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  27.    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;//GPIO_Speed_50MHz;
  28.   //GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  29.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  30.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  31.
  32.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  33.    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;//GPIO_Speed_50MHz;
  34.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  35.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  36.   USART_InitStructure.USART_BaudRate = bound;
  37.   USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  38.   USART_InitStructure.USART_StopBits = USART_StopBits_1;
  39.   USART_InitStructure.USART_Parity = USART_Parity_No;
  40.   USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  41.   USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  42.   GPIO_PinRemapConfig(GPIO_Remap_USART2,ENABLE);
  43.   NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
  44.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0x01 ;
  45.   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01;
  46.   NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  47.   NVIC_Init(&NVIC_InitStructure);
  48.   USART_Init(USART3, &USART_InitStructure);
  49.   USART_ITConfig(USART3, USART_IT_RXNE, ENABLE);
  50.   USART_Cmd(USART3, ENABLE);
  51. }
 楼主| InsertTec 发表于 2014-6-26 11:05 | 显示全部楼层
//USART3打印
void u3_printf(char* fmt,...)
char *p;
char USART_RX_BUF[64];
  va_list ap;
  va_start(ap,fmt);
  vsprintf(USART_RX_BUF,fmt,ap);
p = (char *)USART_RX_BUF;
while(*p != '\0')
   while((USART3->SR&0X40)==0)
    USART3->DR = *p++;
va_end(ap);
//USART1打印
int fputc(int ch, FILE *f)
while((USART1->SR&0X40)==0)  //Ñ »··¢ËÍ,Ö±µ½·¢ËÍÍê±Ï
  USART1->DR = (u8) ch;
return ch;
 楼主| InsertTec 发表于 2014-6-26 11:08 | 显示全部楼层
我是USART1作为调试串口,USART3作为输出DSP信息的串口。但是USART3工作就不正常了,有时输出有时不输出!是中断的问题吗?
airwill 发表于 2014-6-26 12:06 | 显示全部楼层
你应该直接将
改成 USART3 .
问题在你输出的时候没有统一, printf 和 u3_printf 混用, 而 printf 系统并不支持两个端口. 当然按理说有FILE *f 这个参数可以切换 USART. 只是编译器没有很详细地给出怎么处理的说明. 恐怕内部并没有实现. 或者说留给外部实现 fputc 的时候来实现了.
int fputc(int ch, FILE *f);
既然给出了FILE *f 这个参数, 我想通过外部手段是能够实现 USART 的切换的. 但不能只是 fputc 函数里简单的 USART 的切换, 应该使用互斥机制才能实现.
 楼主| InsertTec 发表于 2014-6-26 17:04 | 显示全部楼层
你应该直接将
改成 USART3 .
您说得我更糊涂了。我看网上也有人说同时两个串口可以打印,我就参照人家的例子1!我想是,printf输出USART1;u3_printf输出USART3的信息
airwill 发表于 2014-6-26 17:32 | 显示全部楼层
printf输出USART1;u3_printf输出USART3的信息, 这样处理是可以的. 那 USART3 就不能用 printf 了, 千万不可搞混咯
另外, printf 执行起来很耗时, 时间冲突的问题, 一定要处理好哦
 楼主| InsertTec 发表于 2014-6-26 19:20 | 显示全部楼层
printf输出USART1;u3_printf输出USART3的信息, 这样处理是可以的. 那 USART3 就不能用 printf 了, 千万不 ...
现在正常了,我之前就是搞乱了!
