FSL_TICS_Rita 发表于 2014-7-18 15:32
不客气的~~我找到了再发给你哈
你好,我在IMX6SLHDG.pdf Page 30看到这样的描述:
2.5.2 DDR3 (32 bits) T topology considerations
Be sure to take into account the following when designing a T-topology system.
• Follow the routing rules described in Table 2-3 .
• Termination resistors not required.
• Short routing lengths and on -chip drive strength control.
• Your design is limited to 4 DDR chips.
• DDR3, 2 GBytes using latest memories (4 GBytes coming).
是否如果使用的是Tree拓扑结构,ODT功能是不需要的呢?这是将ODT disable?请求解答。
