1.刚用ltib编译的系统,视频无法播放,求助
BSP:L3.0.35_4.1.0_130816_source.tar.gz
板子:为天嵌的板子(使用公司编译的系统已验证可以硬解码)
ltib里面编译了
--- libfslcodec
--- libfslparser libfslvpuwrap
[ ] libfslaacpcodec
[ ] libfslac3codec
[ ] libfslmscodec
[ ] libfslmsparser
*gst-fsl-plugins
[ ] gst-plugins-gl
*fsl-alsa-plugins
及
--- gstreamer
--- gstreamer-plugins-base
*gstreamer-plugins-good
*gstreamer-plugins-bad
*gstreamer-plugins-ugly
*gstreamer FFmpeg plugins
*gstreamer farsight plugins
1.使用gplay出现以下错误:
root@freescale /$ gplay /opt/movie/xiaopingguo.mp4
playbin2 is employed!
fsl_player_init(): Successfully initialize!
fsl_player_set_media_location(): filename=/opt/movie/xiaopingguo.mp4
[Stopped ][Vol=01][00:00:00/00:00:00][fps:0]Aiur: 3.0.7
Core: MPEG4PARSER_06.06.03 build on Jun 18 2013 14:52:11
mime: video/quicktime; audio/x-m4a; application/x-3gp
file: /usr/lib/imx-mm/parser/lib_mp4_parser_arm11_elinux.so.3.1
Content Info:
URI:
file:///opt/movie/xiaopingguo.mp4
Idx File:
//.aiur/.opt.movie.xiaopingguo.mp4.aidx
Seekable : Yes
Size(byte): 27063430
Movie Info:
Seekable : Yes
Live : No
Duration : 0:06:18.516672000
ReadMode : File
Track : 2
Track 00 [video_000000] Enabled
Duration: 0:06:18.361664000
Language: und
Mime:
video/x-h264, parsed=(boolean)true, width=(int)768, height=(int)432, framerate=(
fraction)23977/1000, codec_data=(buffer)000000016764001eacd940c037a100000303e800
00bb520f162d960000000168ebecb22c
H264D_ARM11_02.06.01 build on Jul 12 2011 13:38:27.
MFW_GST_H264_DECODER_PLUGIN 3.0.7 build on Aug 17 2014 01:07:24.
Track 01 [audio_000000] Enabled
Duration: 0:06:18.516672000
Language: und
Mime:
audio/mpeg, mpegversion=(int)4, channels=(int)2, rate=(int)48000, bitrate=(int)6
7384, framed=(boolean)true, stream-format=(string)raw, codec_data=(buffer)1190
FOUND GST_MESSAGE_TAG!
codec: H.264/AVC
language code: und
container format: MOV/MP4/3GP
codec: AAC
language code: und
bitrate: 67384
ov3640_write_reg:write reg error:reg=3012,val=80
ERROR: v4l2 capture: slave not found!
ehci_fsl_bus_resume begins, Host 1
ehci_fsl_bus_resume ends, Host 1
MFW_GST_V4LSINK_PLUGIN 3.0.7 build on Aug 17 2014 01:06:59.
Debug: non recoverable error while decoding the H.264 Data
Error: fatal error
Beep: 3.0.7
Core: AAC decoder Wrapper build on Mar 15 2013 09:56:21
mime: audio/mpeg, mpegversion=(int){2,4}
file: /usr/lib/imx-mm/audio-codec/wrap/lib_aacd_wrap_arm12_elinux.so
CODEC: BLN_MAD-MMCODECS_AACD_ARM_03.07.00 build on Jul 17 2012 17:47:46.
Wait status change from 2 to 4
state change failed from 2 to 4
try to play failed
Total rendered:0
[--->FINALIZE v4l_sink
[--->FINALIZE aiurdemux
FSL_PLAYER_01.00_LINUX build on Aug 17 2014 01:08:07
[h]display the operation Help
[p]Play
[e]Seek
[a]Pause when playing, play when paused
[v]Volume
[m]Switch to mute or not
[>]Play next file
[<]Play previous file
[r]Switch to repeated mode or not
[f]Set full screen or not
[z]resize the width and height
[t]Rotate
[c]Setting play rate
Display the metadata
[x]eXit
fsl_player_stop()
FSL_PLAYER_UI_MSG_INTERNAL_ERROR: internal error message received.
fsl_player_stop()
player_exit(): No more multimedia files, exit.
[Stopped ][Vol=01][00:00:00/00:00:00][fps:0]g_main_loop_thread_fun() quit!
2.用gst-launch也是出错:
root@freescale /$ gst-launch playbin2 uri=file:///opt/movie/
xiaopingguo.mp4 yekongzhongzuiliangdexingxing.mp4
root@freescale /$ gst-launch playbin2 uri=file:///opt/movie/xiaopingguo.mp4
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Aiur: 3.0.7
Content Info:
URI:
Idx File:
Seekable : Yes
Movie Info:
Seekable : Yes
Live : No
ReadMode : File
Track : 2
Language: und
Mime:
Language: und
Mime:
ERROR: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/MFW_GST_H264DEC_INFO_T:mfw_gst_h264dec_info_t0: fatal error
Additional debug info:
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Total rendered:0
Beep: 3.0.7
Freeing pipeline ...
请问怎么解决呢?
