将下面文件放置在你的工程下,并取任意名称,这里笔者取名为 GD32DBG.ini- /******************************************************************************/
- /* STM32DBG.INI: STM32 Debugger Initialization File */
- // <<< Use Configuration Wizard in Context Menu >>> //
- /* This file is part of the uVision/ARM development tools. */
- /* Copyright (c) 2005-2007 Keil Software. All rights reserved. */
- /* This software may only be used under the terms of a valid, current, */
- /* end user licence from KEIL for a compatible version of KEIL software */
- /* development tools. Nothing else gives you the right to use this software. */
- FUNC void DebugSetup (void) {
- // <h> Debug MCU Configuration
- // <o1.0> DBG_SLEEP <i> Debug Sleep Mode
- // <o1.1> DBG_STOP <i> Debug Stop Mode
- // <o1.2> DBG_STANDBY <i> Debug Standby Mode
- // <o1.5> TRACE_IOEN <i> Trace I/O Enable
- // <o1.6..7> TRACE_MODE <i> Trace Mode
- // <0=> Asynchronous
- // <1=> Synchronous: TRACEDATA Size 1
- // <2=> Synchronous: TRACEDATA Size 2
- // <3=> Synchronous: TRACEDATA Size 4
- // <o1.8> DBG_IWDG_STOP <i> Independant Watchdog Stopped when Core is halted
- // <o1.9> DBG_WWDG_STOP <i> Window Watchdog Stopped when Core is halted
- // <o1.10> DBG_TIM1_STOP <i> Timer 1 Stopped when Core is halted
- // <o1.11> DBG_TIM2_STOP <i> Timer 2 Stopped when Core is halted
- // <o1.12> DBG_TIM3_STOP <i> Timer 3 Stopped when Core is halted
- // <o1.13> DBG_TIM4_STOP <i> Timer 4 Stopped when Core is halted
- // <o1.14> DBG_CAN_STOP <i> CAN Stopped when Core is halted
- // </h>
- _WDWORD(0xE0042004, 0x00000027); // DBGMCU_CR
- _WDWORD(0xE000ED08, 0x20000000); // Setup Vector Table Offset Register
- DebugSetup(); // Debugger Setup
