在问分散加裁问题
3618|1
 楼主| yanghuyue 发表于 2007-6-9 09:39 | 显示全部楼层 |阅读模式
IO, pi, se, GPIO, gp
我的分散加载文件如下(见后):<br />但&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOIN_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CSMISPI_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CFlash_Fix.o&nbsp;(+RO)<br />这4个文件总被提示:<br />&nbsp;&nbsp;pattern&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)&nbsp;only&nbsp;matches&nbsp;removed&nbsp;unused&nbsp;sections<br />&nbsp;&nbsp;pattern&nbsp;CGPIOIN_Fix.o&nbsp;&nbsp;(+RO)&nbsp;only&nbsp;matches&nbsp;removed&nbsp;unused&nbsp;sections<br />&nbsp;&nbsp;pattern&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)&nbsp;only&nbsp;matches&nbsp;removed&nbsp;unused&nbsp;sections<br />&nbsp;&nbsp;pattern&nbsp;CFlash_Fix.o&nbsp;&nbsp;&nbsp;(+RO)&nbsp;only&nbsp;matches&nbsp;removed&nbsp;unused&nbsp;sections<br />我程序中不能调用这4个类。只要调用就提示出错。<br />但CGPIOINOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CIap.o(+RO)&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;main.o(+RO)<br />&nbsp;&nbsp;&nbsp;就可以。<br />如果把ARMLINK&nbsp;的Option&nbsp;的&nbsp;remove&nbsp;unuseed&nbsp;section&nbsp;这三项去掉(也就是不删除)则编译出错:<br />&nbsp;&nbsp;&nbsp;cannt&nbsp;use&nbsp;baseed/limit&nbsp;symbols&nbsp;for&nbsp;no_contiguous&nbsp;section&nbsp;C&&pi_ctorvec<br /><br />我的目的是,把Startup.o&nbsp;(vectors,&nbsp;+First)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOINOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CIap.o(+RO)&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;main.o(+RO)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOIN_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CSMISPI_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CFlash_Fix.o&nbsp;(+RO<br />这几个文件放在0-0000c000这个地址,这几个文件只有3K大。<br />其他的在c000地址后。<br />&nbsp;<br />分散加载文件如下&nbsp;&nbsp;<br />ROM_LOAD&nbsp;0x0<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;ROM_EXEC&nbsp;0x00000000&nbsp;0x0000c000<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Startup.o&nbsp;(vectors,&nbsp;+First)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOINOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CIap.o(+RO)&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;main.o(+RO)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOIN_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CSMISPI_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CFlash_Fix.o&nbsp;(+RO)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;}<br /><br />ROM_LOAD1&nbsp;0x0000c000<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;ROM_EXEC1&nbsp;+0<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;main_user.o(+RO)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;IRAM&nbsp;0x40000000<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Startup.o&nbsp;(MyStacks)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;(+RW,+ZI)<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;HEAP&nbsp;+0&nbsp;UNINIT<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Startup.o&nbsp;(Heap)<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;STACKS&nbsp;0x40008000&nbsp;UNINIT<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Startup.o&nbsp;(Stacks)<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />}<br /><br />
 楼主| yanghuyue 发表于 2007-6-9 10:23 | 显示全部楼层
新发现(分散加裁)
我的分散加载文件如下(见后):<br />但&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOIN_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CSMISPI_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CFlash_Fix.o&nbsp;(+RO)<br />这4个文件总被提示:<br />&nbsp;&nbsp;pattern&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)&nbsp;only&nbsp;matches&nbsp;removed&nbsp;unused&nbsp;sections<br />&nbsp;&nbsp;pattern&nbsp;CGPIOIN_Fix.o&nbsp;&nbsp;(+RO)&nbsp;only&nbsp;matches&nbsp;removed&nbsp;unused&nbsp;sections<br />&nbsp;&nbsp;pattern&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)&nbsp;only&nbsp;matches&nbsp;removed&nbsp;unused&nbsp;sections<br />&nbsp;&nbsp;pattern&nbsp;CFlash_Fix.o&nbsp;&nbsp;&nbsp;(+RO)&nbsp;only&nbsp;matches&nbsp;removed&nbsp;unused&nbsp;sections<br />我程序中不能调用这4个类。只要调用就提示出错。<br />但CGPIOINOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CIap.o(+RO)&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;main.o(+RO)<br />&nbsp;&nbsp;&nbsp;就可以。<br />如果把ARMLINK&nbsp;的Option&nbsp;的&nbsp;remove&nbsp;unuseed&nbsp;section&nbsp;这三项去掉(也就是不删除)则编译出错:<br />&nbsp;&nbsp;&nbsp;cannt&nbsp;use&nbsp;baseed/limit&nbsp;symbols&nbsp;for&nbsp;no_contiguous&nbsp;section&nbsp;C&&pi_ctorvec<br />&nbsp;&nbsp;&nbsp;定义全局变量&nbsp;CGPIOINOUT_Fix&nbsp;WDI_Fix(WDI_IN);也会提示上面错误<br />如果在涵数中定义它,当做局部变量,就不会有上在错误<br /><br /><br />我的目的是,把Startup.o&nbsp;(vectors,&nbsp;+First)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOINOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CIap.o(+RO)&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;main.o(+RO)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOIN_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CSMISPI_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CFlash_Fix.o&nbsp;(+RO<br />这几个文件放在0-0000c000这个地址,这几个文件只有3K大。<br />其他的在c000地址后。<br /><br />分散加载文件如下&nbsp;&nbsp;<br />ROM_LOAD&nbsp;0x0<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;ROM_EXEC&nbsp;0x00000000&nbsp;0x0000c000<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Startup.o&nbsp;(vectors,&nbsp;+First)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOINOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CIap.o(+RO)&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;main.o(+RO)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOOUT_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CGPIOIN_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CSMISPI_Fix.o&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;CFlash_Fix.o&nbsp;(+RO)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />}<br /><br />ROM_LOAD1&nbsp;0x0000c000<br />{<br />&nbsp;&nbsp;&nbsp;&nbsp;ROM_EXEC1&nbsp;+0<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;main_user.o(+RO)&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;(+RO)<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;IRAM&nbsp;0x40000000<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Startup.o&nbsp;(MyStacks)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;*&nbsp;(+RW,+ZI)<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;HEAP&nbsp;+0&nbsp;UNINIT<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Startup.o&nbsp;(Heap)<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;STACKS&nbsp;0x40008000&nbsp;UNINIT<br />&nbsp;&nbsp;&nbsp;&nbsp;{<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Startup.o&nbsp;(Stacks)<br />&nbsp;&nbsp;&nbsp;&nbsp;}<br />}<br />
