#ifndef CONF_BOARD_H_INCLUDED #define CONF_BOARD_H_INCLUDED /** Enable the OLED screen. */ #define CONF_BOARD_SPI #define CONF_BOARD_SPI_NPCS2 #define CONF_BOARD_OLED_UG_2832HSWEG04 #endif /* CONF_BOARD_H_INCLUDED */ 而这些定义的实现函数在init.c中。 conf_clock.h:用来配置时钟源 复制 #ifndef CONF_CLOCK_H_INCLUDED #define CONF_CLOCK_H_INCLUDED // ===== System Clock (MCK) Source Options //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_SLCK_RC //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_SLCK_XTAL //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_SLCK_BYPASS //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_4M_RC //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_8M_RC //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_12M_RC //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_XTAL //#define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_MAINCK_BYPASS #define CONFIG_SYSCLK_SOURCE SYSCLK_SRC_PLLACK // ===== System Clock (MCK) Prescaler Options (Fmck = Fsys / (SYSCLK_PRES)) //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_1 #define CONFIG_SYSCLK_PRES SYSCLK_PRES_2 //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_4 //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_8 //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_16 //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_32 //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_64 //#define CONFIG_SYSCLK_PRES SYSCLK_PRES_3 // ===== PLL0 (A) Options (Fpll = (Fclk * PLL_mul) / PLL_div) // Use mul and div effective values here. #define CONFIG_PLL0_SOURCE PLL_SRC_MAINCK_8M_RC #define CONFIG_PLL0_MUL 25 #define CONFIG_PLL0_DIV 1 // ===== Target frequency (System clock) // - Internal RC frequency: 8MHz // - System clock source: PLLA // - System clock prescaler: 2 (divided by 2) // - PLLA source: 8M_RC // - PLLA output: 8M_RC * 25 / 1 // - System clock: 8M_RC * 25 / 1 / 2 = 100MHz #endif /* CONF_CLOCK_H_INCLUDED */ 可以看出本例中用了PLL时钟源是8MHZ内部RC conf_SPI_master.h: 配置SPI主机的一些参数。 复制/* Possibility to change low-level configurations here. */ //! Default Configuration of SPI Master Delay BCS #define CONFIG_SPI_MASTER_DELAY_BCS 0x00 //! Default Configuration of SPI Master Bits per Transfer Definition #define CONFIG_SPI_MASTER_BITS_PER_TRANSFER 8 //! Default Configuration of SPI Master Delay BCT #define CONFIG_SPI_MASTER_DELAY_BCT 0x00 //! Default Configuration of SPI Master Delay BS #define CONFIG_SPI_MASTER_DELAY_BS 0x00 //! Default Configuration of SPI Master Dummy Field // #define CONFIG_SPI_MASTER_DUMMY 0xFF #endif /* CONF_SPI_MASTER_H_INCLUDED */conf_ssd1306.h:主要定义控制管脚及SPI速率 复制 #ifndef CONF_SSD1306_H_INCLUDED #define CONF_SSD1306_H_INCLUDED // Interface configuration for SAM4N Xplained Pro #define SSD1306_SPI_INTERFACE #define SSD1306_SPI SPI #define SSD1306_DC_PIN UG_2832HSWEG04_DATA_CMD_GPIO #define SSD1306_RES_PIN UG_2832HSWEG04_RESET_GPIO #define SSD1306_CS_PIN UG_2832HSWEG04_SS // Minimum clock period is 50ns[url=home.php?mod=space&uid=517595]@3.3V[/url] -> max frequency is 20MHz #define SSD1306_CLOCK_SPEED UG_2832HSWEG04_BAUDRATE #define SSD1306_DISPLAY_CONTRAST_MAX 40 #define SSD1306_DISPLAY_CONTRAST_MIN 30 而主函数只是先添满显示区,然后利用硬件滚屏。 复制// fill display with lines for (page_address = 0; page_address <= 7; page_address++) { ssd1306_set_page_address(page_address); for (column_address = 0; column_address < 128; column_address++) { ssd1306_set_column_address(column_address); /* fill every other pixel in the display. This will produce horizontal lines on the display. */ ssd1306_write_data(0x6F); } } // scroll the display using hardware support in the LCD controller while (true) { ssd1306_set_display_start_line_address(start_line_address++); delay_ms(250); } 最后的运行效果如下:
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
等级类勋章
发帖类勋章
时间类勋章
人才类勋章
2404
7004
68
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
