- #include "flash.h"
- #include "define.h"
- //************************************空函数************************************
- //函数名称: nullsubs
- //函数说明: 无
- //入口参数: 无
- //出口参数: 无
- void nullsubs(void)
- struct menu{
- unsigned char menucount; //当前层节点数
- unsigned char *str; //菜单标题
- unsigned char pos;
- unsigned char length;
- void (*subs)(); //节点函数
- struct menu *childrenmenu; //子节点
- struct menu *parentmenu; //父节点
- struct menu1{
- unsigned char *str1;
- unsigned char pos1;
- unsigned char length1;
- //******************************菜单显示内容************************************
- //说明: 结构体中放的是菜单的显示内容等参数,完成菜单功能变换,菜单返回
- // 菜单指针函数、可以指向下一级菜单,也可以指向某一项选项的功能
- // 实际中可以根据具体内容变换。
- struct menu1 menu2[2][4] = {
- {"功┃",0x80,2},
- {"能┃",0x90,2},
- {"选┃",0x88,2},
- {"择┃",0x98,2}
- {"其┃",0x80,2},
- {"它┃",0x90,2},
- {"功┃",0x88,2},
- {"能┃",0x98,2}
- struct menu main_menu[8];
- struct menu other_menu[4];
- struct menu main_menu[8] = {
- {8,"1.目标设定",0x82,5,SetValue,Null,Null},
- {8,"2.全部增加",0x92,5,AllAdd,Null,Null},
- {8,"3.全部减少",0x8a,5,AllDec,Null,Null},
- {8,"4.包机搜索",0x9a,5,Search,Null,Null},
- {8,"5.称重清零",0x82,5,ClsWeight,Null,Null},
- {8,"6.电池电压",0x92,5,ADC,Null,Null},
- {8,"7.背光调整",0x8a,5,BaL,Null,Null},
- {8,"8.厂家设置",0x9a,5,PassWords,Null,Null},
- struct menu other_menu[4] = {
- {4,"1.称重标定",0x82,5,AdjWeight,Null,main_menu},
- {4,"2.包机站号",0x92,5,SetAddress,Null,main_menu},
- {4,"3.包机子站",0x8a,5,SetStation,Null,main_menu},
- {4,"4.返回上级",0x9a,5,nullsubs,main_menu,main_menu}
- //************************************全局变量**********************************
- struct menu (*menupoint) = main_menu; //结构体指针,指向结构体后由内部函数指针指向功能函数
- void PowerOff(void)
- clrram();
- Disp_HZ(0,1," 正在关机 ",8);
- jindutiao(2,1);
- jindutiao(2,1);
- jindutiao(2,1);
- clrram();
- _DINT();
- LCD_LED_H;
- E_0;
- P5OUT&=0xfe;
- void findkey(void)
- switch(P4IN)
- case 0xFB :
- key = DOWN;
- break;
- case 0xDF :
- key = UP;
- break;
- case 0xF7 :
- key = ENTER;
- break;
- case 0xEF :
- key = ESC;
- break;
- case 0x7F :
- key = FUN;
- break;
- case 0xBF :
- key = CLS;
- break;
- case 0xFD :
- key = COMP;
- break;
- case 0xFE :
- key = POWER;
- break;
- case 0x7d :
- key = FUN_COMP;
- break;
- default :
- key= Null ;
- break;
- //***********************************待处理函数*********************************
- //函数名称: aa
- //函数说明: 实际中要替换为具体函数原型,这里只是举例说明
- //入口参数: 无
- //出口参数: 无
- void aa(void)
- clrram();
- Disp_HZ(1,1,"数据发送中",5);
- jindutiao(2,4);
- if (wait==0)
- Disp_HZ(1,1," 发送成功",5);
- jindutiao(2,1);
- else
- { clrram();
- Disp_HZ(1,1," 通讯失败",5);
- Disp_HZ(1,2," 请重试 ",5);
- while(1)
- key=Null;
- key_process();
- if(key==ENTER||key==ESC)
- {key=Null;
- break;
- clrram();
- void init_clk(void)
- uchar i;
- BCSCTL1 &= ~XT2OFF; // XT2 = HF XTAL
- do
- IFG1 &= ~OFIFG; // Clear OSCFault flag
- for (i = 0xFF; i > 0; i--); // Time for flag to set
- while ((IFG1 & OFIFG) != 0); // OSCFault flag still set?
- BCSCTL2 |= SELM1; // MCLK = XT2 (safe)
- //************************************菜单显示**********************************
- //函数名称: void menu_disp(uchar n)
- //函数说明: 显示主菜单
- //入口参数: uint n,要显示的菜单级数号码
- //出口参数: 无
- void menu_disp(void)
- uchar i;
- clrram();
- maxitems = menupoint[0].menucount;
- if(userchoose < 4 && maxitems < 5)
- for(i = 0 ;i < maxitems;i++)
- wch_disp(menupoint[i].str,menupoint[i].pos,menupoint[i].length);
- else if(userchoose < 4 && maxitems >= 5)
- for(i = 0;i < 4;i++)
- else if(userchoose >= 4)
- clrram();
- clrram();
- for(i = 0; i < maxitems - 4;i ++)
- wch_disp(menupoint[i + 4].str,menupoint[i + 4].pos,menupoint[i + 4].length);
- if(menupoint == main_menu)
- for(i = 0; i < 4;i ++)
- wch_disp(menu2[0][i].str1,menu2[0][i].pos1,menu2[0][i].length1);
- else if(menupoint == other_menu)
- wch_disp(menu2[1][i].str1,menu2[1][i].pos1,menu2[1][i].length1);
- con_wch_disp(menupoint[userchoose].pos,menupoint[userchoose].length);
- //************************************键盘处理**********************************
- //函数名称: key_process
- //函数说明: 键盘处理
- //入口参数: 无
- //出口参数: 无
- void key_process(void)
- if(P4IN!=0xff)
- LED=1;
- cnt=0;
- Delay_Nms(KeyDelay);//延时消抖
- while(P4IN!=0xff)
- { cnt=0;
- findkey();
- Presstime++;
- if (Presstime > LongPress*2 && (key == DOWN||key == UP||key == FUN_COMP) )//判断长按
- break;
- else if (Presstime > LongPress*2 && (key == POWER)) //判断长按
- PowerOff();
- LPM4;
- break;
- if((P4IN!=0xff) && (key == DOWN||key == UP)&&Setvalues==1)
- { PresstimeLong++;
- if(PresstimeLong>=10&&PresstimeLong<20) key+=10;
- if(PresstimeLong>=20) key+=20;
- if(P4IN==0xff)
- Presstime=0;
- PresstimeLong=0;
- void readall(uchar nus)
- { uchar i;
- clrram();
- Disp_HZ(0,1,"**数据读取中****",8);
- Disp_HZ(0,2," 读取 号",5);
- if(nus>=1&&nus<=MaxStation[NowMainStation])
- Disp_NUM(3,2,nus,0,0);
- readstation(NowMainStation,nus,0x00,0x00);
- jindutiao(3,1);
- else
- for(i=1;i<=MaxStation[NowMainStation];i++)
- { Disp_NUM(3,2,i,0,0);
- readstation(NowMainStation,i,0x00,0x00);
- jindutiao(3,1);
- jindutiao(3,1);
- else
- jindutiao(3,1);
- if (wait==1)
- {Disp_HZ(1,1," 通讯失败",5);
- while(1)
- key=Null;
- key_process();
- {key=Null;
- break;
- void Search(void)
- clrram();
- Disp_HZ(0,0,"**搜索可用包机**",8);
- Disp_HZ(0,1," 搜索 号 ",8);
- MainsCounter=0;
- for(stations=Num_of_main;stations>=1;stations--)
- { cnt=0;
- readstation(stations,0xf0,0x07,0);
- Disp_NUM(4,1,stations,0,0);
- jindutiao(3,1);
- Disp_HZ(0,2," 搜到 个 ",8);
- Disp_NUM(4,2,MainsCounter,0,0);
- if (MainsCounter>0)
- MaxMainS=MainsCounter-1;
- Disp_HZ(0,1," 包机搜索完毕 ",8);
- Disp_HZ(0,3," ◆选择 号 ",8);
- NowMainStation=MainStation[0];
- Disp_NUM(4,3,NowMainStation,0,0);
- else
- clrram();
- Disp_HZ(0,0,"**搜索包机失败**",8);
- Disp_HZ(0,1," 请您重新搜索 ",8);
- Disp_HZ(0,2," 按任意键返回 ",8);
- key=Null;
- while(key==Null)
- key_process();
- if(MainsCounter==0)
- if(key!=Null)
- key=Null;
- break;
- else
- if(key==ENTER)
- key=Null;
- NowStation=1;
- menupoint =main_menu;
- userchoose = 0;
- displaystart = 0;
- menu_disp();
- break;
- else if(key==UP)
- if(MSCounter<MaxMainS)
- MSCounter++;
- NowMainStation=MainStation[MSCounter];
- key=Null;
- if(key==DOWN)
- if(MSCounter>0)
- MSCounter--;
- key=Null;
- void numdisp(uchar xx)
- if (xx<5)
- Disp_HZ(0,xx-1,shuzi[xx-1],1);
- else if(xx>4&&xx<9)
- Disp_HZ(4,xx-5,shuzi[xx-1],1);
- else
- Disp_HZ(0,xx-9,shuzi[xx-1],1);
- void valuedisp(uchar xx,uint *num)
- if (xx<5)
- Disp_NUM(1,xx-1,num[xx],1,0);
- Disp_NUM(5,xx-5,num[xx],1,0);
- else
- Disp_NUM(1,xx-9,num[xx],1,0);
- void dis(uchar xx,uint *num)
- uchar i;
- uchar pos;
- clrram();
- if(xx<9)
- if (MaxStation[NowMainStation]<=8)
- valuedisp(i,num);
- else
- for(i=1;i<=8;i++)
- valuedisp(i,num);
- else
- if (MaxStation[NowMainStation]>8)
- for(i=9;i<=MaxStation[NowMainStation];i++)
- valuedisp(i,num);
- switch(xx)
- case 1: pos=0x80;
- break;
- case 2: pos=0x90;
- break;
- case 3: pos=0x88;
- break;
- case 4: pos=0x98;
- break;
- case 5: pos=0x80+4;
- break;
- case 6: pos=0x90+4;
- break;
- case 7: pos=0x88+4;
- break;
- case 8: pos=0x98+4;
- break;
- case 9: pos=0x80;
- break;
- case 10: pos=0x90;
- break;
- case 11: pos=0x88;
- break;
- case 12: pos=0x98;
- break;
- default:
- break;
- con_wch_disp(pos,1);
- void SetValue(void)
- readall(0xff);
- clrram();
- State=0;
- key=Null;
- dis(NowStation,set1);
- while(State==0)
- {Setvalues=1;
- key_process();
- Setvalues=0;
- if(key==ESC)
- State=1;
- key=Null;
- break;
- else if(key==ENTER)
- readstation(NowMainStation,NowStation,0x01,set1[NowStation]);
- aa();
- readall(NowStation);
- clrram();
- key=Null;
- else if(key==FUN)
- if (NowStation==MaxStation[NowMainStation])
- { NowStation=1;}
- else
- { NowStation++;}
- key=Null;
- else if(key==UP)
- if(set1[NowStation]<6000)
- set1[NowStation]++;
- key=Null;
- else if(key==DOWN)
- if(set1[NowStation]>3000)
- set1[NowStation]--;
- key=Null;
- else if(key==UP+10)
- if(set1[NowStation]<5990)
- set1[NowStation]+=10;
- key=Null;
- else if(key==DOWN+10)
- if(set1[NowStation]>3010)
- set1[NowStation]-=10;
- key=Null;
- else if(key==UP+20)
- if(set1[NowStation]<5900)
- set1[NowStation]+=100;
- key=Null;
- else if(key==DOWN+20)
- if(set1[NowStation]>3100)
- set1[NowStation]-=100;
- key=Null;
- void ClsWeight(void)
- clrram(); //清除显示
- Disp_HZ(0,0,"**称重清零******",8);
- Disp_HZ(0,1,"◆喷嘴号:",4);
- Disp_NUM(5,1,NowStation,0,0);
- State=0;
- key=Null;
- while(State!=1)
- {key=Null;
- key_process();
- if(key==ESC)
- State=1;
- key=Null;
- break;
- readstation(NowMainStation,NowStation,0x08,0x00);
- key=Null;
- aa();
- else if(key==UP)
- { NowStation=1;
- else
- { NowStation++;
- key=Null;
- if(NowStation>1)
- { NowStation--;
- else
- { NowStation=MaxStation[NowMainStation];
- key=Null;
- void AdjWeight(void)
- clrram(); //清除显示
- Disp_HZ(0,0,"**称重标定******",8);
- Disp_HZ(0,1,"进入请按组合键!",8);
- Disp_HZ(0,2,"退出请按取消键!",8);
- while(1)
- { key=Null;
- key_process();
- if (key == FUN_COMP)
- { key=Null;
- clrram(); //清除显示
- State=0;
- key=Null;
- while(State!=1)
- {key=Null;
- key_process();
- if(key==ESC)
- State=1;
- key=Null;
- break;
- AdjWeight2();
- else if(key==UP)
- { NowStation=1;
- else
- { NowStation++;
- key=Null;
- if(NowStation>1)
- { NowStation--;
- else
- key=Null;
- else if(key==ESC)
- key=Null;
- userchoose = 0;
- displaystart = 0;
- menu_disp();
- break;
- void AdjWeight2(void)
- uchar ps=0;
- key=Null;
- clrram(); //清除显示
- Disp_HZ(0,1,"◆状态:P-",5);
- Disp_NUM(5,1,ps,0,0);
- State=0;
- key=Null;
- while(1)
- { key=Null;
- key_process();
- if(key==ENTER)
- readstation(NowMainStation,NowStation,0x09,ps);
- key=Null;
- aa();
- if(ps==7)
- Disp_HZ(5,1,"退出",2);
- else
- {Disp_HZ(5,1," ",2);
- else if(key==UP)
- if (ps==7)
- { ps=0;
- if(ps==7)
- else
- else
- { ps++;
- if(ps==7)
- else
- key=Null;
- if(ps>0)
- { ps--;
- if(ps==7)
- else
- else
- { ps=7;
- if(ps==7)
- else
- key=Null;
- else if(key==ESC)
- key=Null;
- clrram(); //清除显示
- break;
- void SetAddress(void)
- uint i=1;
- //start:
- clrram(); //清除显示
- Disp_HZ(0,0,"**包机站号设置**",8);
- Disp_HZ(0,1,"◆包机号:",4);
- Disp_NUM(5,1,i,0,0);
- State=0;
- key=Null;
- while(State!=1)
- {key=Null;
- key_process();
- if(key==ESC)
- State=1;
- key=Null;
- break;
- readstation(0xff,0xf0,0x05,i);
- key=Null;
- aa();
- else if(key==UP)
- if(i<Num_of_main)
- i++;
- else
- i=1;
- key=Null;
- if(i>1)
- i--;
- else
- i=Num_of_main;
- key=Null;
- void SetStation(void)
- uint i=8;
- clrram(); //清除显示
- Disp_HZ(0,0,"**喷嘴设置******",8);
- Disp_HZ(0,1,"◆喷嘴数:",4);
- State=0;
- key=Null;
- while(State!=1)
- {key=Null;
- key_process();
- if(key==ESC)
- State=1;
- key=Null;
- break;
- readstation(0xff,0xf0,0x06,i);
- key=Null;
- aa();
- else if(key==UP)
- if(i<12)
- i++;
- else
- i=1;
- key=Null;
- if(i>1)
- i--;
- else
- i=12;
- key=Null;
- //************************************密码函数************************************
- //函数名称: PassWords
- //函数说明: 无
- //入口参数: 无
- //出口参数: 无
- void PassWords(void)
- uint i=0;
- clrram(); //清除显示
- Disp_HZ(0,0,"**输入密码******",8);
- Disp_HZ(0,1,"◆密码值:",4);
- State=0;
- key=Null;
- while(State!=1)
- {key=Null;
- Delay_Nms(500);
- key_process();
- if(key==ESC)
- State=1;
- key=Null;
- userchoose = 0;
- displaystart = 0;
- menu_disp();
- break;
- else if((key==ENTER) && ( i == PassWord ))
- menupoint =other_menu;
- userchoose = 0;
- displaystart = 0;
- menu_disp();
- key=Null;
- State=1;
- else if(key==UP)
- if(i<99)
- i++;
- key=Null;
- if(i>0)
- i--;
- key=Null;
- void BaL(void)
- clrram(); //清除显示
- Disp_HZ(0,0,"**背光调整******",8);
- Disp_HZ(0,1,"◆亮度值:",4);
- Disp_NUM(5,1,bal,0,0);
- State=0;
- key=Null;
- while(State!=1)
- {key=Null;
- Delay_Nms(500);
- key_process();
- if(key==ESC)
- State=1;
- key=Null;
- userchoose = 0;
- displaystart = 0;
- menu_disp();
- break;
- _DINT();
- write_buff[1]=bal;
- flash_erase( pc_flash_segment); //段擦除
- write_array(pc_flash, write_buff,4); //写入指定字节数量
- _NOP();
- read_array(pc_flash,checkout,4); //再读出刚才写的字节
- bal=checkout[1];
- key=Null;
- _EINT();
- State=1;
- key=Null;
- userchoose = 0;
- displaystart = 0;
- menu_disp();
- break;
- else if(key==UP)
- if(bal<99)
- bal++;
- key=Null;
- if(bal>0)
- bal--;
- key=Null;
- //************************************电量函数************************************
- //函数名称: ADC
- //函数说明: 无
- //入口参数: 无
- //出口参数: 无
- void ADC(void)
- adc=1;
- //start:
- clrram(); //清除显示
- ADC_Init();
- Disp_HZ(0,0,"**电池电量******",8);
- Disp_HZ(1,1,"电压值:",4);
- Disp_HZ(7,1," V",2);
- Disp_NUM(4,1,Curr_Volt,1,0);
- State=0;
- key=Null;
- while(State!=1)
- {key=Null;
- key_process();
- switch (State)
- case 0 :
- if(key==ESC)
- {P6SEL= 0; // 使能ADC通道
- ADC12CTL0 = 0; // 打开ADC,设置采样时间
- ADC12IE = 0; // 使能ADC中断
- State=1;
- adc=0;
- key=Null;
- userchoose = 0;
- displaystart = 0;
- menu_disp();
- break;
