DSP6713的bootload问题
1281|0
 楼主| tmmdh 发表于 2015-6-28 10:21 | 显示全部楼层 |阅读模式
DSP6713做bootload时程序编译正常,但是out文件无法load,提示data verification failed at address 0x90000000.  please verify target memory and memory map, 如下图,在网上找了很长时间都不行,下面的是我的CMD文件,请大家帮我看看
MEMORY
    BOOTRAM:       o = 00000000h   l = 00000400h
    IRAM:          o = 00000400h   l = 0000FA00h
    CE0:               o = 80000000h   l = 01000000h
    FLASH_BOOT:    o = 0x90000000  l = 00000400h
    FLASH_REST:    o = 0x90000400  l = 0001FC00h
SECTIONS
        .boot_load : load = FLASH_BOOT, run = BOOTRAM
    /* Initialized User Code Section */
    .text           : load = FLASH_REST, run = IRAM
             LOAD_START(_text_ld_start),
            RUN_START(_text_rn_start),
            SIZE(_text_size)
    /* This is also a special initialized data section, which could stay
       in ROM, however probably not desirable, due to Slow ROM access times.
       const values never change, by definition. */
    .cinit            >         FLASH_REST
    .const      >       IRAM
    .stack      >       IRAM
    .bss        >       IRAM
    .data       >       IRAM
    .far        >       IRAM
    .switch     >       IRAM
    .sysmem     >       IRAM
    .cio        >       IRAM
