DM6437中VPFE的缩放器输出
385|2
Varus|  楼主 | 2016-4-25 20:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Snow7| | 2016-4-25 20:19 | 只看该作者
是的,output width 需是16字节的整数倍
android2| | 2016-4-25 20:44 | 只看该作者
• Vertical and horizontal resize ratio values (RSZ_CNT.VRSZ and RSZ_CNT.HRSZ) should be within
the range: 64 to 1024.
• Output Width:
– Should be within the maximum limit:
     • width < 1280 (if vertical resize value is in the range: RSZ_CNT.VRSZ = 64 to 512)
     • width < 640 (if vertical resize value is in the range: RSZ_CNT.VRSZ = 513 to 1024)
– Should be even
– Should be a multiple of 16 bytes (for vertical upsizing)
