找到一个非常便宜的富士通WIFI模块,MBH7WLZ16,有没有用过的
899|0
lfjwfm|  楼主 | 2016-10-26 16:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Wireless LAN module-802.11b/g,Marvell 88W8686
WLAN standard: IEEE802.11b/g compliant
Host interface: SDIO, SPI
Power supply voltage: 3.0V, 1.8V
Operating temperature: -20 to +70 degrees C
Power consumption: Tx mode: 550mW @15dBm, Rx mode: 340mW @54Mbps, Idle mode: 300mW, IEEE power save mode (Doze): <1mW
Built-in Oscillator
Security: WEP (64/128bit), WPA, WPA2
Antenna: single port
Bluetooth coexistence (2/3/4 wire)
IEEE802.11e QoS
Package: LGA 60pin
8.5 x 8.5 x 1.2mm
有没有那位大侠用过,好用吗? MBH7WLZ16_DataSheet_1_36es_short.pdf (135.04 KB)
