[modelsim]
cyclone IVE PLL modulesim 仿真时钟输出不正常怎么破
1332|1
顶层模块
module Top_Level(
clk,
rst_n,
ddr,
data
input clk;
input rst_n;
output [7:0]data;
output [5:0]ddr;
wire clk_10k;
wire pll_rst;
//assign pll_rst = ~rst_n;
PLL U0(
        .inclk0(clk),
        .c0(clk_10k),
        .areset(!rst_n)
//assign  clk_10k = clk
wire [3:0] bit_1;
wire [3:0] bit_2;
wire [3:0] bit_3;
wire [3:0] bit_4;
wire [3:0] bit_5;
wire [3:0] bit_6;
wire [19:0]indata = 20'd123456;
mod U1(
.CLK(clk_10k),
.RST_n(rst_n),
.IN_DATA(indata),
.bit_1(bit_1),
.bit_2(bit_2),
.bit_3(bit_3),
.bit_4(bit_4),
.bit_5(bit_5),
.bit_6(bit_6)
decoder U2(
.CLK(clk_10k),
.RST_n(rst_n),
.BIT_1(bit_1),
.BIT_2(bit_2),
.BIT_3(bit_3),
.BIT_4(bit_4),
.BIT_5(bit_5),
.BIT_6(bit_6),
.DATA_DDR(ddr),
.DATA_BUS(data)
endmodule
PLL配制
硬件能跑 仿真时钟输出抽风
shcshc1234|  楼主 | 2017-3-14 21:41 | 只看该作者
妈蛋我知道咋回事了
刚才心血来潮来了一发100ms仿真 波出来了。。。
结论是等的时间不够一个周期没出来。。
