[STC单片机]
菜鸟求解,想P32接地,工作可以调光。但仿真不是这样
577|1
lxr21|  楼主 | 2017-5-24 16:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <STC15.H>
sbit led  =  P3^3;
sbit ledgao = P3^4;  //调亮
sbit leddi =P3^5;   //调暗
sbit ledkg =P3^2;   //开关
sbit fmq =P3^1;    //蜂鸣器
bit work; //工作标识
unsigned char num;
unsigned char light;
#define kg_NO()   led=1
#define kg_OFF()  led=0
char key(num)
        if(work==1)
        if(ledgao==0)
                num++;
        if(num>100)
                num=100;
                fmq=!fmq;
        if(leddi==0)
                num--;
                if(num<=1)
                        num=1;
                        fmq=!fmq;
        return num;
        void exint0() interrupt 0
                if(ledkg==0)
                        work=1;
                if(ledkg==1)
                        work=0;
                        kg_OFF();
        void Timer0Init(void)                //100微妙@11.0592MHz
        AUXR |= 0x80;                // 1T模式
        TMOD &= 0xF0;
        TL0 = 0xAE;
        TH0 = 0xFB;
        TR0 = 1;
        ET0 = 1;
        EA  = 1;
void tm0_isr() interrupt 1
        if(light=key(num))
                kg_NO();
void main()
        P3M0 = 0x00;
        P3M1 = 0x0A;
        led = 0;
ledgao =1;
  leddi =1;
ledkg =1;
fmq =0;
        num=50;
  Timer0Init();
  IT0 = 0;
  EX0 = 1;
        while(1)
        key(num);
lxr21|  楼主 | 2017-5-25 08:30 | 只看该作者
有没有人帮帮啊
