python微信机器人--主程序
879|0
dfcxfy|  楼主 | 2018-4-15 09:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
直接上程序。。
# coding:utf-8
import itchat
import urllib
import  os
import webbrowser
import json
from itchat.content import TEXT
import pyttsx
from itchat.content import *
from aip import  AipSpeech
import codecs
import paho.mqtt.client as mqtt
import mp3play
import sys
from pydub import AudioSegment
import time
import re
reload(sys)
sys.setdefaultencoding('utf8')
import os
APP_ID = '百度给的ID'
API_KEY = '百度API_KEY'
SECRET_KEY = '百度 SECRET_KEY'
# 初始化AipSpeech对象
aipSpeech = AipSpeech(APP_ID, API_KEY, SECRET_KEY)
key = '图灵给的key'
api = 'h t t p  : / / w w w  .t u l i n g 1 2 3 . c o m       /openapi/api?key=' + key + '&info='
def getHtml(url):
   page = urllib.urlopen(url)
   html = page.read()
   return html
def on_connect(client,userdata,password, rc):
   print("Connected with result code " + str(rc))
msg_information = {}
face_bug=None  #针对表情包的内容
def get_file_content(filePath):
    with open(filePath, 'rb') as fp:
        return fp.read()
@itchat.msg_register([TEXT, RECORDING, ATTACHMENT],isFriendChat=True)
def handle_receive_msg(msg):
    names = itchat.search_friends(userName=msg['FromUserName'])['NickName']
    usera = itchat.search_friends(userName=msg['FromUserName'])
    nameb = usera['UserName']
    users = itchat.search_friends(name='雨电')
    namea = users[0]['UserName']
    print names
    print namea
    print nameb
    global face_bug
    msg_time_rec = 1022   #接受消息的时间
#    msg_from = itchat.search_friends(userName=msg['FromUserName'])['NickName']   #在好友列表中查询发送信息的好友昵称
    msg_time = msg['CreateTime']    #信息发送的时间
    msg_id = msg['MsgId']    #每条信息的id
    msg_content = None      #储存信息的内容
#    msg_share_url = None    #储存分享的链接,比如分享的**和音乐
#    print msg['Type']
#   print msg['MsgId']
    if msg['Type'] == 'Text' or msg['Type'] == 'Friends':     #接受文字信息
         msg_content = msg['Text']
         print msg_content
         info=msg_content
         if(names == '雨电'):              #判断发信息人 能否控制读取物联网硬件   这里我做了两个环境监测一个放家里一个放店里
            if (info.find('家里') !=-1 ):
               os.system(r'E:\dioyong\pobao1.py')
               engine = pyttsx.init()
               engine.say(u'家里环境监测完毕')
               engine.runAndWait()
               print u'家里环境监测完毕'
            elif (info.find('店里') !=-1 ):
               os.system(r'E:\dioyong\pobao.py')
               engine.say(u'店铺环境监测完毕')
               engine.runAndWait()
               print u'店铺环境监测完毕'
            elif (info.find('打开') !=-1 ):                 #做了一个灯控硬件
               os.system(r'E:\dioyong\dakai.py')
               engine.say(u'以为你打开灯')
               engine.runAndWait()
               print u'以为你打开灯'
            elif (info.find('拍照') !=-1 ):                      #做的两个拍照截取图片   一个是海康的监控摄像头  一个是USB摄像头
               os.system(r'E:\dioyong\cap.py')
               os.system(r'E:\dioyong\haikang.py')
               itchat.send_image("cap.png", namea)
               itchat.send_image("haikang.jpg", namea)
            elif (info.find('关闭') !=-1):
               os.system(r'E:\dioyong\guanbi.py')
               engine.say(u'以为你关闭灯')
               engine.runAndWait()
               print u'以为你关闭灯'
            elif (info.find('店里环境') ==-1 ):
               request = api + info.encode("utf8")
               response = getHtml(request)
               dic_json = json.loads(response)
               if dic_json['code']==100000:
                   print '机器人: '.decode('utf-8') + dic_json['text']
                   itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode(),namea)        #图灵返回的的文字信息
               elif dic_json['code'] == 200000:
                   itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode(),namea)        #图灵返回有单个链接信息
                   itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['url'].decode() , namea)
#                   webbrowser.open_new(dic_json['url'])
               elif dic_json['code'] == 302000:
                   itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode(),namea)        #图灵返回有多个链接信息
                   lis = dic_json['list']
                   a=0
                   while True:
                      if a==2:
                          break
                      else:
                          b= lis[a]['detailurl']
                          itchat.send_msg('机器人小雨: '.decode('utf-8') +b , namea)
#                         webbrowser.open_new(b)
                          a =a+1
               elif dic_json['code'] == 308000:
                    a=0
                    while True:
                       if a==2:
                          break
                       else:
                          a =a+1
               f = codecs.open(r'E:\dioyong\wenxin.txt', "w",'utf-8')
               f.write(dic_json['text'])
               result  = aipSpeech.synthesis(dic_json['text'], 'zh', 1, {'spd': 4,'pit': 5,
                   'vol': 5,'per':0,
               if not isinstance(result, dict):
                   with open(r'E:\dioyong\auido2.mp3', 'wb') as f:
                             f.write(result)
               clip = mp3play.load(r'E:\dioyong\auido2.mp3')
               clip.play()
               time.sleep(min(3000000, clip.seconds()))
               os.remove(r'E:\dioyong\auido2.mp3')
         else:
               itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode(),nameb)
               itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['url'].decode() , nameb)
               a=0
               while True:
                  if a==2:
                     break
                  else:
                     itchat.send_msg('机器人小雨: '.decode('utf-8') +b , nameb)
                     a =a+1
               a=0
               while True:
                  if a==2:
                     break
                  else:
                      a =a+1
    #如果发送的消息是附件、视屏、图片、语音
    elif msg['Type'] == "Attachment" or msg['Type'] == "Video" \          #接受朋友发的语音
            or msg['Type'] == 'Picture' \
            or msg['Type'] == 'Recording':
         msg_content = msg['FileName']
         msg['Text'](msg_content)
         print msg_content
         sound = AudioSegment.from_mp3(msg_content)
         sound.export(r'02.wav' , format = "wav")
         result = aipSpeech.asr(get_file_content(r'02.wav'), 'wav', 8000, {
            'lan': 'zh',
         print result['result'][0]
         info=result['result'][0]
         if(names == '雨电'):
               engine.runAndWait()
               print u'家里环境监测完毕'
               engine.runAndWait()
               print u'店铺环境监测完毕'
               engine.runAndWait()
               print u'以为你打开灯'
               engine.runAndWait()
               print u'以为你关闭灯'
                   itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['text'].decode() , namea)
                   itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['url'] , namea)
                   a=0
                   while True:
                      if a==2:
                          break
                      else:
                          a =a+1
                    a=0
                    while True:
                       if a==2:
                          break
                       else:
                          a =a+1
                   'vol': 5,'per':0,
                             f.write(result)
               clip.play()
         else:
               itchat.send_msg('机器人小雨: '.decode('utf-8') +dic_json['url'] , nameb)
               a=0
               while True:
                  if a==2:
                     break
                  else:
                     a =a+1
               a=0
               while True:
                  if a==2:
                     break
                  else:
                      a =a+1
itchat.auto_login(hotReload=True)
itchat.send_msg()
itchat.run()
本来还想通过mqtt客户端接受到检测信号,让微信机器人主动给某个好友或几个好友发送信息的。。用以做报警或预警用的 一直没弄得起来mqtt客户端(要保持长期运行)没办法和微信机器人(也要保持长期运行)程序同时运行。。。由于本人能力不足。试了多进程和变量共享都没有成功。。。。希望有大神帮忙指点指点。
