[资料分享]
适用于电机和泵的无线状态监控器(使用多轴振动)的参...
313|12
dirtwillfly|  楼主 | 2020-3-31 20:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TIDA-01575
描述
This reference design provides a non-invasive and non-disruptive method to monitor and assess motor health and includes both the analog front end (AFE) as well as the embedded application. The embedded application software configures the internal analog-to-digital converter (ADC) to sample the data as well as perform frequency analysis of the data. Additionally, the SimpleLink™ Software Development Kit (SDK) is used in this embedded application to enable both wired and wireless connectivity (Bluetooth® low energy). With the SimpleLink SDK, the user can easily migrate the design to Wi-Fi® and Sub-1G connectivity. This solution of AFE, embedded processing, and wireless connectivity addresses the costly challenge of motor maintenance and is a foundation to implement predictive maintenance systems. By predicting the life of a motor, an operator can optimize maintenance schedules of often costly and large motors and pumps while improving the operational lifetime of the production lines using these motors.
特性
  • Single solution provides vibration measurement in three axes with MEMS analog accelerometer
  • Most precise integrated ADCs capable of capturing vibration with resolution of 0.01g
  • Simple software migration between wired serial, wi-fi, bluetooth 5, Sub 1 GHz with SimpleLink platform and with pre-certified RF modules
  • Extended multiyear battery life with lowest power integrated ADC and efficient scalable FFT processing
  • Edge processing to reduce system power and lower network bandwidth
  • Modular BoosterPack™ plug-in module design for easy integration and development with LaunchPad™ development kit ecosystem for prototyping
Examples
The example software for this reference design is provided for two LaunchPad™ development kits through the SimpleLink MSP432P4 SDK. The relevant file paths are:
  • MSP-EXP432P401R: [SimpleLink MSP432P4 SDK]/examples/rtos/MSP_EXP432P401R/demos/tida_01575_serial/
  • MSP-EXP432P4111: [SimpleLink MSP432P4 SDK]/examples/rtos/MSP_EXP432P4111/demos/tida_01575_serial/
gwsan| | 2020-4-2 13:13 | 只看该作者
非常感谢楼主分享
kxsi| | 2020-4-2 13:13 | 只看该作者
非常感谢楼主分享
nawu| | 2020-4-2 13:13 | 只看该作者
非常感谢楼主分享
qcliu| | 2020-4-2 13:13 | 只看该作者
非常感谢楼主分享
tfqi| | 2020-4-2 13:14 | 只看该作者
非常感谢楼主分享
dirtwillfly|  楼主 | 2020-5-24 21:48 | 只看该作者
适用于电机和泵的无线状态监控器参考设计.pdf (1.88 MB)
dirtwillfly|  楼主 | 2020-5-24 21:49 | 只看该作者
TIDA-01575 Schematic.pdf (144.41 KB)
TIDA-01575 PCB.pdf (612.74 KB)
dirtwillfly|  楼主 | 2020-5-24 21:50 | 只看该作者
TIDA-01575 Gerber.zip (75.77 KB)
dirtwillfly|  楼主 | 2020-5-24 21:51 | 只看该作者
TIDA-01575 CAD Files.zip (580.06 KB)
TIDA-01575 BOM.pdf (99.65 KB)
dirtwillfly|  楼主 | 2020-5-24 21:52 | 只看该作者
TIDA-01575 Assembly Drawing.pdf (152.17 KB)
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
