[嵌入式linux]
看看 这段代码的BUG在哪里,有时候真的不注意就出错,
1393|0
ROSHEN_007|  楼主 | 2022-8-25 15:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这是我做ALSA开发的时候编写的一段代码,初始化pcm设备,发现总是打开失败,从头到尾看了好几遍才发现问题!
static int snd_pcm_init(snd_para_t *snd_para,snd_pcm_t *pcm)
    snd_pcm_hw_params_t *hwparams = NULL;
    int ret;
    if(snd_para->alsa_pcm_dev_name!=NULL)
        // ret = snd_pcm_open(&(pcm), snd_para->alsa_pcm_dev_name, snd_para->stream, 0);
        ret = snd_pcm_open(&(pcm), ALSA_PCM_PLAYBACK_DEV, snd_para->stream, 0);
    else{
        puts(" pcm dev name is null\n");
        return -1;
    if (0 != ret) {
        fprintf(stderr, "snd_pcm_open error: %s: %s\n",
        snd_para->alsa_pcm_dev_name, snd_strerror(ret));
        return -1;
    snd_pcm_hw_params_malloc(&hwparams);
    ret = snd_pcm_hw_params_any(pcm, hwparams);
    if (0 != ret) {
        fprintf(stderr, "snd_pcm_hw_params_any error: %s\n", snd_strerror(ret));
        goto err2;
    ret = snd_pcm_hw_params_set_access(pcm, hwparams, snd_para->_access);
    if (0 !=  ret) {
        fprintf(stderr, "snd_pcm_hw_params_set_access error: %s\n", snd_strerror(ret));
        goto err2;
    ret = snd_pcm_hw_params_set_format(pcm, hwparams, snd_para->fmt);
    if (0 !=  ret) {
        fprintf(stderr, "snd_pcm_hw_params_set_format error: %s\n", snd_strerror(ret));
        goto err2;
    ret = snd_pcm_hw_params_set_rate(pcm, hwparams, snd_para->sample_rate, 0);
    if (0 !=  ret) {
        fprintf(stderr, "snd_pcm_hw_params_set_rate error: %s\n", snd_strerror(ret));
        goto err2;
    ret = snd_pcm_hw_params_set_channels(pcm, hwparams, snd_para->channels);
    if (0!=  ret) {
        fprintf(stderr, "snd_pcm_hw_params_set_channels error: %s\n", snd_strerror(ret));
        goto err2;
    ret = snd_pcm_hw_params_set_period_size(pcm, hwparams, snd_para->period_size, 0);
    if (0 !=  ret) {
        fprintf(stderr, "snd_pcm_hw_params_set_period_size error: %s\n", snd_strerror(ret));
        goto err2;
    ret = snd_pcm_hw_params_set_periods(pcm, hwparams, snd_para->periods, 0);
    if (0!=  ret) {
        fprintf(stderr, "snd_pcm_hw_params_set_periods error: %s\n", snd_strerror(ret));
        goto err2;
    ret = snd_pcm_hw_params(pcm, hwparams);
    snd_pcm_hw_params_free(hwparams);
    if (0 !=  ret) {
        fprintf(stderr, "snd_pcm_hw_params error: %s\n", snd_strerror(ret));
        goto err1;
    return 0;
    err2:
    snd_pcm_hw_params_free(hwparams); //释放内存
    err1:
    snd_pcm_close(pcm); //关闭 pcm 设备
    return -1;
