STM32每个通用定时器可以单独输出4路不同频率的PWM波形?
16918|17
 楼主| cd4066 发表于 2012-5-16 15:42 | 显示全部楼层 |阅读模式
如下代码。是不是说STM32每个通用定时器可以单独输出4路不同频率的PWM波形?我看以下代码还有每个通道的单独设置。
#include "stm32f10x.h"
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_OCInitTypeDef TIM_OCInitStructure;
uint16_t CCR1_Val = 250;
uint16_t CCR2_Val = 500;
uint16_t CCR3_Val = 750;
uint16_t CCR4_Val = 0;
uint16_t PrescalerValue = 0;
voidRCC_Configuration(void);                //时钟配置
voidGPIO_Configuration(void);            //管脚配置
void Delay (__IO uint32_tnCount);         //延时函数
int main(void)
RCC_Configuration();
GPIO_Configuration();
PrescalerValue = (uint16_t) (SystemCoreClock /24000000) - 1;
TIM_TimeBaseStructure.TIM_Period =1000;                                 //周期
TIM_TimeBaseStructure.TIM_Prescaler =PrescalerValue;             //分频
TIM_TimeBaseStructure.TIM_ClockDivision =0;                            //时钟分割
TIM_TimeBaseStructure.TIM_CounterMode =TIM_CounterMode_Up;
               //计数模式
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);                  //初始TIM3
/*************************** 通道1 ********************************/
TIM_OCInitStructure.TIM_OCMode =TIM_OCMode_PWM2;    //PWM2
TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable;   //PWM功能使能
TIM_OCInitStructure.TIM_Pulse =CCR1_Val;                           //写比较值(占空比
TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_Low;   //置高
TIM_OC1Init(TIM3, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
/****************************** 通道2 ******************************/
/* PWM1 Mode configuration: Channel2 */
TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
TIM_OCInitStructure.TIM_OCPolarity =TIM_OCPolarity_High;
TIM_OC2Init(TIM3, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
/******************************* 通道3 *********************************/
/* PWM1 Mode configuration: Channel3 */
TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
TIM_OC3Init(TIM3, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
/****************************** 通道4 *********************************/
/* PWM1 Mode configuration: Channel4 */
TIM_OCInitStructure.TIM_Pulse = CCR4_Val;
TIM_OC4Init(TIM3, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
TIM_ARRPreloadConfig(TIM3,ENABLE);                       //
TIM_Cmd(TIM3,ENABLE);                                         //使能计数
while (1)
CCR4_Val++;
if(CCR4_Val==1000)CCR4_Val=0;
TIM_SetCompare4(TIM3,CCR4_Val);                        //占空比调节
香水城 发表于 2012-5-16 16:24 | 显示全部楼层
除非不断地进行软件干预,否则单个通用定时器不可以单独输出4路不同频率的PWM波形。
 楼主| cd4066 发表于 2012-5-17 08:39 | 显示全部楼层
 楼主| cd4066 发表于 2012-5-17 08:40 | 显示全部楼层
如楼上红色的文字,那这里每个通道设置一个常数,是想得到4个不同占空比的PWM信号吗?
 楼主| cd4066 发表于 2012-5-17 08:42 | 显示全部楼层
前面的4个常数是这样设置的
weicz 发表于 2012-5-17 09:21 | 显示全部楼层
4# cd4066
对的,频率应该都是一样的,但可以输出不同占空比的波形
tianyuhui 发表于 2012-5-20 14:01 | 显示全部楼层
同意6楼。。。
google2012 发表于 2012-5-23 17:08 | 显示全部楼层
zhanxiage110 发表于 2012-5-23 21:28 | 显示全部楼层
恩,频率肯定是一个,占空比可调
INS101211 发表于 2012-6-6 15:03 | 显示全部楼层
请问这种情况下,怎么设置不同PWM的输出IO口,有没有这方面的参考文档
it_yrj 发表于 2012-12-24 23:09 | 显示全部楼层
请问楼主实现了没:一个定时器输出四路不同频率的PWM????
zengan007 发表于 2013-3-20 09:11 | 显示全部楼层
用比较输出模式 输出的好像也是PWM波吧?那样的话就可以输出4路PWM
Uyou 发表于 2014-7-14 12:37 | 显示全部楼层
四路不同频率的PWM输出,各位解决了没有啊
古月风语 发表于 2014-11-4 22:00 | 显示全部楼层
81190865 发表于 2015-1-22 15:15 | 显示全部楼层
用PWM模式是没办法输出不同频率的PWM波的,有人说用比较模式可以,我没有实现过
Serge_Ding 发表于 2015-1-23 12:52 | 显示全部楼层
四路频率一样,占空比不同的PWM
zunaxia 发表于 2017-8-6 14:05 | 显示全部楼层
戈卫东 发表于 2017-8-6 14:21 | 显示全部楼层
响应每次比较中断,大致可以做到。
