TMS320F28335 的时钟
2513|3
huangfeng33|  楼主 | 2014-7-30 20:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TMS320F28335上有一个基于PLL电路的片上时钟模块,为CPU及外设提供时钟有两种方式:一种是用外部的时钟源,将其连接到X1引脚上或者XCLKIN引脚上,X2接地;另一种是使用振荡器产生时钟,用30MHz的晶体和两个20PF的电容组成的电路分别连接到X1和X2引脚上,XCLKIN引脚接地。我们常用第二种来产生时钟。此时钟将通过一个内部PLL锁相环电路,进行倍频。由于F28335的最大工作频率是150M,所以倍频值最大是5。其中倍频值由PLLCR的低四位和PLLSTS的第7、8位来决定。其详细的倍频值可以参照TMS320F28335的Datasheet。下面是F28335的时钟设置
void InitPll(Uint16 val, Uint16 divsel)
  // Make sure the PLL is not running in limp mode
  if (SysCtrlRegs.PLLSTS.bit.MCLKSTS != 0)
  // Missing external clock has been detected
  // Replace this line with a call to an appropriate
  // SystemShutdown(); function.
  asm(“ ESTOP0”);
  // DIVSEL MUST be 0 before PLLCR can be changed from
  // 0x0000. It is set to 0 by an external reset XRSn
  // This puts us in 1/4
  if (SysCtrlRegs.PLLSTS.bit.DIVSEL != 0)
  EALLOW;
  SysCtrlRegs.PLLSTS.bit.DIVSEL = 0;
  EDIS;
  // Change the PLLCR
  if (SysCtrlRegs.PLLCR.bit.DIV != val)
  EALLOW;
  // Before setting PLLCR turn off missing clock detect logic
  SysCtrlRegs.PLLSTS.bit.MCLKOFF = 1;
  SysCtrlRegs.PLLCR.bit.DIV = val;
  EDIS;
  // Optional: Wait for PLL to lock.
  // During this time the CPU will switch to OSCCLK/2 until
  // the PLL is stable. Once the PLL is stable the CPU will
  // switch to the new PLL value.
  // This time-to-lock is monitored by a PLL lock counter.
  // Code is not required to sit and wait for the PLL to lock.
  // However, if the code does anything that is timing critical,
  // and requires the correct clock be locked, then it is best to
  // wait until this switching has completed.
  // Wait for the PLL lock bit to be set.
  // The watchdog should be disabled before this loop, or fed within
  // the loop via ServiceDog()。
  // Uncomment to disable the watchdog
  DisableDog();
  while(SysCtrlRegs.PLLSTS.bit.PLLLOCKS != 1)
  // Uncomment to service the watchdog
  // ServiceDog();
  EALLOW;
  SysCtrlRegs.PLLSTS.bit.MCLKOFF = 0;
  EDIS;
  // If switching to 1/2
  if((divsel == 1)||(divsel == 2))
  EALLOW;
  SysCtrlRegs.PLLSTS.bit.DIVSEL = divsel;
  EDIS;
  // If switching to 1/1
  // * First go to 1/2 and let the power settle
  // The time required will depend on the system, this is only an example
  // * Then switch to 1/1
  if(divsel == 3)
  EALLOW;
  SysCtrlRegs.PLLSTS.bit.DIVSEL = 2;
  DELAY_US(50L);
  SysCtrlRegs.PLLSTS.bit.DIVSEL = 3;
  EDIS;
zhangmangui| | 2014-7-30 22:34 | 只看该作者
有参考价值
小木欧尼| | 2014-8-25 23:20 | 只看该作者
谢谢哦
siyida| | 2014-8-26 09:41 | 只看该作者
