【TI 技术资料分享】+基于MSP430F249的GPS+GPRS车载GPS
709|0
必胜客A|  楼主 | 2015-3-10 17:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
基于MSP430F249的GPS+GPRS车载GPS 基于MSP430F249的GPS GPRS车载GPS.zip (412.19 KB)
//  MSP430x24x Demo - Software Toggle P1.0, MCLK = VLO/8
//  Description; Pulse P1.0 with a 1/100 active duty cycle using software.
//  Ultra-low frequency ~ 1.5kHz, ultra-low power active mode demonstrated. All
//  the 6 I/O ports are configured as low outputs to eliminate floating inputs.
//  ACLK = VL0, MCLK = VLO/8 ~ 1.5kHz, SMCLK = n/a
//                MSP430F249
//         /|\|              XIN|-
//          --|RST          XOUT|-
//            |             P1.0|-->LED
//            |        P5.4/MCLK|-->MCLK = VLO/8
//            |        P5.6/ACLK|-->ACLK = VLO
//  B. Nisarga
//  Texas Instruments Inc.
//  July 2007
//  Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.42A
//38 Decoder Control
//#define Y0_138                       (0x0080)                        //P6.7
//#define Y1_138                       (0x0040)                        //P6.6
//#define Y2_138                       (0x0020)                        //P6.5
//#define EN_138                       (0x0010)                        //P6.4
//38 Decoder Output
//#define USB_RESET                      ((0x0000)<<5)                        //000
//#define GPS_RESET                      ((0x0004)<<5)                        //001
//#define WDG_Disable             ((0x0002)<<5)                        //010
//#define CPU_LED                      ((0x0006)<<5)                        //011
//#define IPONE_POWER_EN          ((0x0001)<<5)                        //100
//#define SPI_USB_CS              ((0x0005)<<5)                        //101
//#define SPI_UART_EXTEND2_CS     ((0x0003)<<5)                        //110
//#define SPI_UART_EXTEND1_CS     ((0x0008)<<5)                        //111
#include "430bios.h"
#include "EXAR.H"
#include "HAL.H"
#include "general.h"
#include "main_init.h"
#include "pcf8563.h"
#include "Do_Reset.h"
#include "Do_M22.h"
#include "gps.h"
#include "flash_record.h"
#include "DATA_APC.H"
#include "SET_P.H"
// volatile to prevent optimization
//volatile unsigned char j=0;
unsigned char flag=0;
//unsigned char flag1=0;
//unsigned char buf1[8]={0x55,0xAA};
//void SendUart(unsigned char *pBuffer,unsigned char n_byte);
//void  init_GPRS(void);
#pragma vector = TIMERB0_VECTOR
__interrupt void TimerB (void)
        //CCR0+=1000;                       //定时1ms,外部时钟为8M的时钟。
        gTimer++;                                        //1ms增加一次记数
        gprsTimer++;
        if(GPRS_STATUS&GPRS_TCP_FLAG)
          gM22_TCP_ECHO_Timer++;
        if(gTimer>1000)
          gTimer=0;
          gSysTimer++;
          gCircle_Timer++;
          GprsPower=1;
          //flag1=1;
          //if(apc_flag!=0)
          //  apc_flag=0;
          //  EXAR_fiforeset();
          //  for(j=0;j<EXAR_j;j++)
          //    Send_ComA(Ptr_Chn1[j]);
          //  EXAR_j=0;
          flag=~flag;
          if(flag!=0)
            //P6OUT |= EN_138;                //Enable 38 Decoder
            //P6OUT |= 0xD0;//(CPU_LED|0x1F);        //Cpu Led off
            //IO_CS_FUN(CPU_LED);
          else
            //P6OUT &= ~EN_138;
            //P6OUT &= 0x7F;
            //IO_NCS_FUN();
//volatile unsigned int i;
void main(void)
  unsigned int i;
//  unsigned char mm[256];
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  init_clk();
  init_com0_gprs();
  init_port();
  init_GPS();
  init_rtc();
  init_flash();
  init_sram();
  init_EXAR();
  Init_USB();
  Read_Gprs_P();
  Init_FMCL04();
  RTC_Set_DateTime(0x00101117,0x00123559);
  page_count_global=power_on_find_page();
  _EINT();
  init_GPRS();                                          // P5.6= ACLK option select
  for (;;)
    //if(flag!=0)
     //flag=0;
     //delay(5);
     //for(i=0;i<256;i++)
//    I2C_Write(FM24C04_WriteAddress_Page1,247, 'A');
//    I2C_Write(FM24C04_WriteAddress_Page1,248, 'P');
//    I2C_Write(FM24C04_WriteAddress_Page1,249, 'C');
//    for(i=0;i<256;i++)
     //I2C_Write(FM24C04_WriteAddress_Page0,i,'A' );
//     mm[i]=I2C_Read(FM24C04_WriteAddress_Page1,FM24C04_ReadAddress_Page1,i);
//     mm[i]=I2C_Read(FM24C04_WriteAddress_Page0,FM24C04_ReadAddress_Page0,i );
     //RTC_ReadAll();
     //SendUart(buf1,sizeof(buf1));
    if(Query376Interrupt())
      for(i=0;i<2000;i++);
      Do_USB();
    if(GPRS_STATUS&GPRS_POWER_OFF)
      Do_OFF_Power();
    else if(GPRS_STATUS&GPRS_RST_FLAG)
      Do_Reset_GSM_On();
    else
      Do_G20_Out();
    Do_GPS_Module();
    EXAR_APC_FUN();
    Write_APC_Data();
    if(gGeneral_Flag&SET_P_FLAG)
      gGeneral_Flag&=~SET_P_FLAG;
      Read_Gprs_P();
    //if(flag!=0)
     //flag=0 ;
     //Send_ComB(gYear);
     //Send_ComB(gMonth);
     //Send_ComB(gDate);
     //Send_ComB(gHour);
     //Send_ComB(gMinute);
     //Send_ComB(gSecond);
     //Send_ComB(0x0d);
     //Send_ComB(0x0a);
     //delay(500);
    //i=0;
#pragma vector= USCIAB0RX_VECTOR
__interrupt void Uart0Rx(void)
        //int i=0;
        //if((UCA0STAT&UCRXERR)==0)
          //AddUsData(RXBUF0);
          if( gReceive0_GSM_Buffer_Point != gReceive0_GSM_Buffer_End )
        { // 缓冲区满了将不接收数据,因此每包数据不要超过256字节比较好
                gReceive0_GSM_Buffer[gReceive0_GSM_Buffer_Point] = UCA0RXBUF;
                gReceive0_GSM_Buffer_Point++;
                if( gReceive0_GSM_Buffer_Point >= sizeof(gReceive0_GSM_Buffer) ) gReceive0_GSM_Buffer_Point=0;
                //gM22_GSM_ECHO_Timer=0;
                gM22_TCP_ECHO_Timer=0;
        //else
unsigned char Compare_String(unsigned char *Source,unsigned char *Target,unsigned int Count )
    while(Count>0)
        if((*Source)!=(*Target)) return(0);
        Source++;
        Target++;
        Count--;
    return(1);
