03. 串口打开和关闭按钮操作- //串口打开和关闭按钮
- void MainWindow::on_pushButton_Open_clicked()
- //设置串口号;也就是说打开的是当前显示的串口
- if(ui->comboBox_Port->currentText().isEmpty())
- QMessageBox::information(this,"提示","没有可用的串口");
- return;
- Serial.setPortName(ui->comboBox_Port->currentText());
- if(ui->pushButton_Open->text() == "打开串口")
- if(Serial.open(QIODevice::ReadWrite))//读写方式打开,成功后设置串口
- //设置波特率
- Serial.setBaudRate(ui->comboBox_Baud->currentText().toInt());
- //设置数据位
- switch(ui->comboBox_DataBit->currentText().toInt())
- case 5:
- Serial.setDataBits(QSerialPort::Data5);
- break;
- case 6:
- Serial.setDataBits(QSerialPort::Data6);
- break;
- case 7:
- Serial.setDataBits(QSerialPort::Data7);
- break;
- case 8:
- Serial.setDataBits(QSerialPort::Data8);
- break;
- default:
- QMessageBox::information(this,"提示","数据位配置出错");
- return;
- break;
- //设置校验位
- if (ui->comboBox_CheckBit->currentText() == "奇效验")
- Serial.setParity(QSerialPort::OddParity);
- else if (ui->comboBox_CheckBit->currentText() == "偶效验")
- Serial.setParity(QSerialPort::EvenParity);
- else if (ui->comboBox_CheckBit->currentText() == "无")
- Serial.setParity(QSerialPort::NoParity);
- //设置停止位
- if (ui->comboBox_StopBit->currentText().toFloat() == 1)
- Serial.setStopBits(QSerialPort::OneStop);
- else if(ui->comboBox_StopBit->currentText().toFloat() == 1.5)
- Serial.setStopBits(QSerialPort::OneAndHalfStop);
- else if(ui->comboBox_StopBit->currentText().toFloat() == 2)
- Serial.setStopBits(QSerialPort::TwoStop);
- //设置流控制
- Serial.setFlowControl(QSerialPort::NoFlowControl);
- ui->pushButton_Open->setText("关闭串口");
- //建立串口接收的槽函数
- connect(&Serial,&QSerialPort::readyRead ,this,&MainWindow::ReadRecData);
- // timer0->start(100);
- else//串口打开失败
- QMessageBox::about(NULL, "提示", "打开出错,串口被占用!");
- return ;
- else if(ui->pushButton_Open->text() == "关闭串口")
- Serial.close();//关串口
- //timer0->stop();
- ui->pushButton_Open->setText("打开串口");
