[其他产品] PIC16F15323单片机 (ADC+温度传感器)
1810|24
 楼主| aoyi 发表于 2022-6-23 12:06 | 显示全部楼层 |阅读模式
温度储传感器原理
FVR原理
实现代码
/*---------------------------------函数功能:-------------------------------------
采集MCU的温度,并且用RC0口(LED)来判断是否采集完成,如果温度采集AD完成,则
* AD对应的标志位ADIF=1,如果使能有效,则会产生一个中断,此时LED灯亮。
编程思路:参考手册的P131  To do an A/D Conversion, follow these steps
// PIC16F15323 Configuration Bit Settings
// 'C' source line config statements
// CONFIG1
#pragma config FEXTOSC = ECH    // External Oscillator mode selection bits (EC above 8MHz; PFM set to high power)
#pragma config RSTOSC = EXT1X   // Power-up default value for COSC bits (EXTOSC operating per FEXTOSC bits)
#pragma config CLKOUTEN = OFF   // Clock Out Enable bit (CLKOUT function is disabled; i/o or oscillator function on OSC2)
#pragma config CSWEN = ON       // Clock Switch Enable bit (Writing to NOSC and NDIV is allowed)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable bit (FSCM timer enabled)
// CONFIG2
#pragma config MCLRE = ON       // Master Clear Enable bit (MCLR pin is Master Clear function)
#pragma config PWRTE = OFF      // Power-up Timer Enable bit (PWRT disabled)
#pragma config LPBOREN = OFF    // Low-Power BOR enable bit (ULPBOR disabled)
#pragma config BOREN = ON       // Brown-out reset enable bits (Brown-out Reset Enabled, SBOREN bit is ignored)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (VBOR) set to 1.9V on LF, and 2.45V on F Devices)
#pragma config ZCD = OFF        // Zero-cross detect disable (Zero-cross detect circuit is disabled at POR.)
#pragma config PPS1WAY = ON     // Peripheral Pin Select one-way control (The PPSLOCK bit can be cleared and set only once in software)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable bit (Stack Overflow or Underflow will cause a reset)
// CONFIG3
#pragma config WDTCPS = WDTCPS_31// WDT Period Select bits (Divider ratio 1:65536; software control of WDTPS)
#pragma config WDTE = ON        // WDT operating mode (WDT enabled regardless of sleep; SWDTEN ignored)
#pragma config WDTCWS = WDTCWS_7// WDT Window Select bits (window always open (100%); software control; keyed access not required)
#pragma config WDTCCS = SC      // WDT input clock selector (Software Control)
// CONFIG4
#pragma config BBSIZE = BB512   // Boot Block Size Selection bits (512 words boot block size)
#pragma config BBEN = OFF       // Boot Block Enable bit (Boot Block disabled)
#pragma config SAFEN = OFF      // SAF Enable bit (SAF disabled)
#pragma config WRTAPP = OFF     // Application Block Write Protection bit (Application Block not write protected)
#pragma config WRTB = OFF       // Boot Block Write Protection bit (Boot Block not write protected)
#pragma config WRTC = OFF       // Configuration Register Write Protection bit (Configuration Register not write protected)
#pragma config WRTSAF = OFF     // Storage Area Flash Write Protection bit (SAF not write protected)
#pragma config LVP = ON         // Low Voltage Programming Enable bit (Low Voltage programming enabled. MCLR/Vpp pin function is MCLR.)
// CONFIG5
#pragma config CP = OFF         // UserNVM Program memory code protection bit (UserNVM code protection disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>// 调用PIC16f15323单片机的头文件
//#include"delay.h"//调用延时子函数的头文件
/*-----------宏定义--------------*/
#define  uint  unsigned int
#define  uchar unsigned char
uint  ADbuf=0;                                                // 缓存AD转换结果
/*-----------子函数声明--------------*/
/*-----------主函数--------------*/
void main()
    //-------------------1、Configure Port:---------------------//
        // The corresponding data direction register is TRISA.
        // Setting  a TRISA bit (= 1) will make the corresponding PORTA pi an input.
        // Clearing a TRISA bit (= 0) will make the corresponding PORTA pin an output.
        // 解释为什么需要TRISA0=1? After the A/D module has been configured as desired,
        // the selected channel must be acquired before the conversion is started.
        // The analog input channels must have their corresponding TRIS bits selected as inputs.
        TRISA0=1;                                        // RA0口为输入口,电压输入口
    TRISC0=0;                                        // AD响应中断对应的LED灯的数据方向为输出
        // 1 = Port pin is > VIH,即高电平  ;  0 = Port pin is < VIL,即低电平
        RA0=0;                                                // 要不要这行语句没有影响,因为该端口是输入端口
        RC0=0;                                                // LED灯的初值为灭
    //The ANSELA register (Register 14-4) is used to configure the Input mode of an I/O pin to analog.
    // Setting the appropriate ANSE     如果ANSEL=1,IO口为模拟输入,如果ANSEL=0,数字IO口。
    ANSA0=1;                    // Set RA0 to analog  ANSELA0,为什么见头文件<xc.h>
        while(1)                                        // 死循环,单片机初始化后,就一直运行这个死循环
        //-------------------2、Configure the ADC module:---------------------//
        //(1)寄存器ADCON1: ADFM ADCS<2:0> - - ADPREF<1:0>
        // 10-BIT ADC CONVERSION RESULT FORMAT
        ADFM=1;                                        //  AD Result Format Select bit.  0 = Left justified.  1 = Right justified
        //The source of the conversion clock is software selectable via the ADCS<2:0> bits
        ADCS2=0;ADCS1=0;ADCS0=0;                // Select ADC conversion clock    FOSC/2
         // The ADPREF<1:0> bits of the ADCON1 register provides control of the positive voltage reference
        ADPREF1=0;ADPREF0=0;            // Select voltage reference  00 =VREF+ is connected to VDD
        //(2)寄存器ADCON0:  CHS<5:0> GO/DONE ADON
        //The CHS<5:0> bits of the ADCON0 register determine which channel is connected to the sample and hold circuit.
        //CHS5=0;CHS4=0;CHS3=0;CHS2=0;CHS1=0;CHS0=0;   //   Select ADC input channel   选择RA0(AN0)作为模拟输入
        CHS5=1;CHS4=1;CHS3=1;CHS2=1;CHS1=0;CHS0=0;   //   Select ADC input channel  Temperature sensor  选择温度传感器作为模拟输入
        //ADC Conversion Status bit. 1 = ADC conversion cycle in progress. Setting this bit starts an ADC conversion cycle.
        // This bit is automatically cleared by hardware when the ADC conversion has completed.
        // 0 = ADC conversion completed/not in progress
        GOnDONE=0;                                // AD Conversion Status bit。为什么叫用GO_DONE看一下xc.h头文件
        //To enable the ADC module, the ADON bit of the ADCON0 register must be set to a ‘1’.
        ADON=1;                                        //Turn on ADC module    模数转换器使能位。 1 = A/D converter module is powered up
        //----------新增部分:温度传感器寄存器配置( CHS5=1;CHS4=1;CHS3=1;CHS2=1;CHS1=0;CHS0=0;)---------------//
        //  FVREN: Fixed Voltage Reference Enable bit.  1 = Fixed Voltage Reference is enabled
        FVREN=1;
        // FVRRDY: Fixed Voltage Reference Ready Flag bit(1).   1 = Fixed Voltage Reference output is ready for use
        FVRRDY=1;
        // Temperature Indicator Enable bit.   1 = T emperature Indicator is enabled
        TSEN=1;
        // T emperature Indicator Range Selection bit.   1 = T emperature in High Range VOUT = 3VT ; 0 = T emperature in Low Range VOUT = 2VT
        TSRNG=0;                //Min. VDD, TSRNG = 0  (Low Range)  >= 1.8
        //  ADFVR<1:0>: ADC FVR Buffer Gain Selection bit  00 = ADC FVR Buffer is off
        // ADFVR1=0;ADFVR0=1;   //01 = ADC FVR Buffer Gain is 1x, (1.024V)
        ADFVR1=0;ADFVR0=0;      //00 = ADC FVR Buffer is off
                 //--------------------3、Configure ADC interrupt (optional):---------------------//
                //ADIE=0;                                //禁止AD中断
                //AD中断使能
                ADIE=1;
                ADIF=0;                                        // Clear ADIF bit
        INTEDG=1;               // Interrupt Edge Select bit   1 = Interrupt on rising edge of INT pin
                PEIE=1;                                        // 允许外设中断
                GIE=1;                                        // 总中断允许
        //----------ADC BLOCK DIAGRAM框图有下面两个寄存器,但是AD采集程序没有用到?--------------//
        // AUTO CONVERSION TRIGGER
        // TRIGSEL<3:0>;
        //The Auto-conversion Trigger source is selected with the ADACT<4:0> bits of the ADACT register.
        // 温度采集需要下面几行代码
        ADACT4=0;ADACT3=0;ADACT2=0;ADACT1=0;ADACT0=0;//Auto-Conversion Trigger Selection bits
        //--------------------4、 Wait the required acquisition time:---------------------//
              asm("NOP");                                //延时,让模拟电压稳定
                asm("NOP");
                asm("NOP");
                asm("NOP");
                asm("NOP");
        //---------------5、Start conversion by setting the GO/DONE bit.:---------------------//
        // When ADON = 1时,GO_DONE=1: AD conversion in progress set this bit(GO_DONE=1), starts the AD conversion.
                // it is automatically cleared by hardware when the AD conversion is complete
                 GOnDONE=1;                                //开始进行AD转换   GO/DONE: A/D Conversion Status bit  ADGO=1;
        //---------6、Wait for ADC conversion to complete by one ofthe following:(1)Polling the GO/DONE bit。(2)Waiting for the ADC interrupt------//
                while( GOnDONE) continue;//等待AD转换结束,AD转换完成后,GO_DONE自动由1变成0
        //-----------------------7、Read ADC Result----------------------//
               // The conversion of an analog input signal results in a corresponding 10-bit digital number.
                // The ADRESH(高8位):ADRESL(低8位) registers contain the 10-bit result of the AD conversion.
                // When the AD conversion is complete, the result is loaded into this AD Result register pair,
                // and the GO/DONE bit is cleared and the A/D interrupt flag bit ADIF is set
         // 需要注意到底是左对齐还是右对齐,这会影响ADbuf=ADRESH*256+ADRESL是否正确
                ADbuf=ADRESH*256+ADRESL;//转换结果一共有10bit。由于2^10为1024,所以这是一个4位数  0-1023
        //---------------8、Clear the ADC interrupt flag (required if interrupt is enabled)--------------------//
/*************中断服务程序***************/
// void __interrupt(irq(TMR0,TMR1),base(0x100)) timerIsr(void)
// 文档里可以查到要用 void __interrupt() ISR(void) 的形式添加中断程序
//void interrupt ISR(void)//PIC单片机的所有中断都是这样一个入口
void __interrupt() ISR(void)//PIC单片机的所有中断都是这样一个入口
        // When the AD conversion is complete, the A/D interrupt flag bit ADIF is set.
        if(ADIF==1)                                        // 需要进一步判断是否为外部中断的溢出中断标志位
                // The interrupt flag bit(s) must be cleared in software before
                // re-enabling interrupts to avoid recursive interrupts
                //溢出中断标志位清零     如果ADIF出现上升沿,则产生中断,所以中断发生之后要清零。
                ADIF=0;
                // 执行中断处理程序,执行中断产生时想要执行的功能
                RC0=1;                                // 外部中断发生时,LED灯亮
/***********************************汇编语言**********************************/
BANKSEL ADCON1 ;              //选择寄存器ADCON1
MOVLW B’11110000’;          //将立即数11110000传送给工作寄存器W  功能:Right justify, ADCRC,oscillator; Vdd and Vss Vref
MOVWF ADCON1 ;                //将W内的数据传送给ADCON1寄存器
BANKSEL TRISA ;                 //选择寄存器TRISA
BSF TRISA,0 ;                   //将TRISA第0位置1,即将端口RA0设置为输入  功能:Set RA0 to input
BANKSEL ANSELA ;                //选择寄存器ANSELA
BSF ANSELA,0 ;                  //将ANSLA的第0位置1,即将端口RA0设置为模拟输入   功能:Set RA0 to analog
BANKSEL ADCON0 ;                //选择寄存器ADCON0
MOVLW B’00000001’ ;           //将立即数00000001传送给工作寄存器W    功能:Select channel AN0;ADC conversion cycle in progress. ;  ADC is enabled
MOVWF ADCON0 ;                  //将W内的数据传送给ADCON0寄存器
CALL SampleTime ;               // 延时 Acquisiton delay
BSF ADCON0,ADGO ;               //将ADCON0的ADGO位置1,开始转换  功能:Start conversion   ADC Conversion Status bit。1 = ADC conversion cycle in progress.
BTFSC ADCON0,ADGO ;             //Is conversion done? 判断ADCON0的GO位是否为0?  为0则跳过,为1则顺序执行;
GOTO $-1 ;                      // No, test again   没有转换完成,再检测一遍
BANKSEL ADRESH ;                //选择寄存器ADRESH
MOVF ADRESH,W ;                 // Read upper 2 bits  将高位ADRESH的数据存入W寄存器中
MOVWF RESULTHI ;                //store in GPR space  将数据存储
BANKSEL ADRESL ;                //选择寄存器ADRESL
MOVF ADRESL,W ;                 //Read lower 8 bits
MOVWF RESULTLO ;                //Store in GPR space
quickman 发表于 2022-7-3 14:21 | 显示全部楼层
资料够全的,多谢分享
vivilyly 发表于 2022-7-3 15:06 | 显示全部楼层
谢谢lz分享,很有用
tabmone 发表于 2022-7-3 15:42 | 显示全部楼层
非常感谢楼主分享
lzbf 发表于 2022-7-3 15:57 | 显示全部楼层
回复查看一下相关的内容。
sheflynn 发表于 2022-7-3 16:10 | 显示全部楼层
谢谢你共享的资料
modesty3jonah 发表于 2022-7-3 16:24 | 显示全部楼层
感谢分享,提供的例程很实用
juliestephen 发表于 2022-7-3 16:38 | 显示全部楼层
分享的资料很高端呢。
selongli 发表于 2022-7-3 16:52 | 显示全部楼层
  应用还是很广泛的
soodesyt 发表于 2022-7-3 17:48 | 显示全部楼层
这些资料太全了!!!
cashrwood 发表于 2022-7-3 18:02 | 显示全部楼层
感谢分享,提供的例程很实用
rosemoore 发表于 2022-7-3 18:16 | 显示全部楼层
很详细的开发板资料
tifmill 发表于 2022-7-3 18:30 | 显示全部楼层
很详细的开发板资料
yeates333 发表于 2022-7-3 19:28 | 显示全部楼层
资料还是相当全面的
pklong 发表于 2022-7-3 19:39 | 显示全部楼层
资料的确是很全面
lzmm 发表于 2022-7-3 19:58 | 显示全部楼层
回复查看一下相关的内容。
232321122 发表于 2022-7-3 20:09 | 显示全部楼层
楼主,资料很好。谢谢楼主!
olivem55arlowe 发表于 2022-7-3 20:21 | 显示全部楼层
相当全的资料,很适合初学者
htmlme 发表于 2022-7-3 20:32 | 显示全部楼层
谢谢你共享的资料!!
abotomson 发表于 2022-7-3 20:43 | 显示全部楼层
有时间需要好好看看   不错
