有大神帮忙看下程序有问题吗,脚位是PA09 PA10
//串口引脚配置
static void Uart_PortInit(void)
stc_gpio_cfg_t uartGpioCfg;
DDL_ZERO_STRUCT(uartGpioCfg);
Sysctrl_SetPeripheralGate(SysctrlPeripheralGpio,TRUE); //使能GPIO模块时钟
///<TX
uartGpioCfg.enDir = GpioDirOut;
Gpio_Init(MAINTX_PORT, MAINTX_PIN, &uartGpioCfg);
Gpio_SetAfMode(MAINTX_PORT, MAINTX_PIN, GpioAf1); //配置PA09 端口为URART0_TX
///<RX
uartGpioCfg.enDir = GpioDirIn;
Gpio_Init(MAINRX_PORT, MAINRX_PIN, &uartGpioCfg);
Gpio_SetAfMode(MAINRX_PORT, MAINRX_PIN, GpioAf1); //配置PA10 端口为URART0_RX
//串口配置
static void Uart_CfgInit(void)
stc_uart_cfg_t stcCfg;
stc_uart_multimode_t stcMulti;
stc_uart_baud_t stcBaud;
DDL_ZERO_STRUCT(stcCfg);
DDL_ZERO_STRUCT(stcMulti);
DDL_ZERO_STRUCT(stcBaud);
///< 开启外设时钟
Sysctrl_SetPeripheralGate(SysctrlPeripheralUart0,TRUE);///<使能uart0模块时钟
///<UART Init
stcCfg.enRunMode = UartMskMode3; ///<模式3
stcCfg.enStopBit = UartMsk1bit; ///<1bit停止位
stcCfg.enMmdorCk = UartMskEven; ///<偶检验
stcCfg.stcBaud.u32Baud = 9600; ///<波特率9600
stcCfg.stcBaud.enClkDiv = UartMsk8Or16Div; ///<通道采样分频配置
stcCfg.stcBaud.u32Pclk = Sysctrl_GetPClkFreq(); ///<获得外设时钟(PCLK)频率值
Uart_Init(M0P_UART0, &stcCfg); ///<串口初始化
///<UART中断使能
Uart_ClrStatus(M0P_UART0,UartRC); ///<清接收请求
Uart_ClrStatus(M0P_UART0,UartTC); ///<清接收请求
Uart_EnableIrq(M0P_UART0,UartRxIrq); ///<使能串口接收中断
Uart_EnableIrq(M0P_UART0,UartTxIrq); ///<使能串口接收中断
// EnableNvic(UART0_IRQn, IrqLevel3, TRUE); ///<系统中断使能
void UserUartInit(void)
Uart_PortInit();
Uart_CfgInit();
//Uart_SendDataIt(M0P_UART0, 0x55); //启动UART1发送第一个字节
