[电机控制] foc闭环调试_pi控制器调试程序框架
1875|20
 楼主| OKAKAKO 发表于 2024-9-29 16:17 | 显示全部楼层 |阅读模式
1、ADC电流偏置读取
  1. void Offset_CurrentReading(void)
  3.        static uint16_t ADC_PhaseU_Curr[100];
  4.        static uint16_t ADC_PhaseV_Curr[100];
  5.        uint16_t temp;
  6.        uint32_t sum_U=0;
  7.        uint32_t sum_V=0;
  8.        uint8_t i,k;
  9.        for(i=0;i<100;i++){
  10.               while(DMA_GetFlagStatus(DMA2_Stream0,DMA_FLAG_TCIF0)==RESET);
  11.                DMA_ClearFlag(DMA2_Stream0,DMA_FLAG_TCIF0);
  12.                   ADC_PhaseU_Curr[i] = ADC_DualConvertedValueTab[0];
  13.                  ADC_PhaseV_Curr[i] = ADC_DualConvertedValueTab[1];
  14.        }
  15.        for(k=0;k<100;k++){
  16.            for(i=k+1;i<100;i++)
  17.                if(ADC_PhaseU_Curr[i]>ADC_PhaseU_Curr[k]){
  18.                     temp=ADC_PhaseU_Curr[i];
  19.                     ADC_PhaseU_Curr[i]=ADC_PhaseU_Curr[k];
  20.                     ADC_PhaseU_Curr[k]=temp;
  21.                 }
  22.            }
  23.               sum_U=0;
  24.        for(k=25;k<75;k++){
  25.            sum_U=sum_U+ADC_PhaseU_Curr[k];
  26.        }
  27.        ADCSampPare.OffsetPhaseU_Curr =sum_U/50;
  28.        printf("U: %d \n", ADCSampPare.OffsetPhaseU_Curr);
  29.        for(k=0;k<100;k++){
  30.            for(i=k+1;i<100;i++)
  31.                 if(ADC_PhaseV_Curr[i]>ADC_PhaseV_Curr[k]){
  32.                      temp=ADC_PhaseV_Curr[i];
  33.                      ADC_PhaseV_Curr[i]=ADC_PhaseV_Curr[k];
  34.                      ADC_PhaseV_Curr[k]=temp;
  35.                 }
  36.        }
  37.        sum_V=0;
  38.        for(k=25;k<75;k++){
  39.            sum_V=sum_V+ADC_PhaseV_Curr[k];
  40.        }
  41.        ADCSampPare.OffsetPhaseV_Curr =sum_V/50;
  42.        printf("V: %d \n", ADCSampPare.OffsetPhaseV_Curr);
  43. }
2、转速测量
为以后速度环做准备
  1.        angeel_ch[sp_flag]=Anglee;
  2.        if ((TIM2->CR1 & TIM_CounterMode_Down) == TIM_CounterMode_Down){
  3.        //encoder timer down-counting
  4.               if(angeel_ch[sp_flag]>angeel_ch[(sp_flag+1)%11])
  5.               interval=angeel_ch[sp_flag]-angeel_ch[(sp_flag+1)%11]-4000;
  6.               else interval=angeel_ch[sp_flag]-angeel_ch[(sp_flag+1)%11];
  7.        }
  8.        else{
  9.               if(angeel_ch[sp_flag]<angeel_ch[(sp_flag+1)%11])</angeel_ch[(sp_flag+1)%11])
  10.               interval=angeel_ch[sp_flag]-angeel_ch[(sp_flag+1)%11]+4000;
  11.               else interval=angeel_ch[sp_flag]-angeel_ch[(sp_flag+1)%11];
  12.        }
  13.        if((interval<200)&&(interval>-200)){
  14.               speedms=interval*15;
  15.               FirstOrder_LPF_Cacl(speedms,speedms_F,0.1);
  16.               pi_spd.Fdb=speedms_F;
  17.        }
  18.        sp_flag++;
  19.        if (sp_flag>=11)sp_flag=0;
3、q轴单轴调试
      Pid参数:
  1. #define  Id_Kp                      0.0
  2. #define  Id_Ki                      0.0
  3. #define  Id_Kc                      0
  4. #define  Iq_Kp                      0.1
  5. #define  Iq_Ki                      0.5
  6. #define  Iq_Kc                      0
  7. pi_iq.Ref= 50;
  8. pi_iq.Fdb=I_dq.I2;
  9. PID_CALC(pi_iq);
  10. FirstOrder_LPF_Cacl(pi_iq.Out,pi_iq.OutF,0.05);
  11. Volt_dq.V2= pi_iq.OutF;
  12. Volt_dq.V1= 0;
结合之前的开环调试,整体流程大致这样。
4、PID限幅与计算
  1. #define UP16LIMIT(var,max,min) {(var) = (var)>(max)?(max):(var) ;
  2. #define PID_CALC(v)               \
  3. v.Err = v.Ref - v.Fdb;            \
  4. v.Up= _IQmpy(v.Kp,v.Err);         \
  5. v.Ui= v.Ui + _IQmpy(v.Ki,v.Up);   \
  6. UP16LIMIT(v.Ui,v.OutMax,v.OutMin);\
  7. v.Ud = v.Kd * (v.Up - v.Up1);\
  8. v.Out = v.Up + v.Ui + v.Ud;\
  9. UP16LIMIT(v.Out,v.OutMax,v.OutMin);\
  10. v.Up1 = v.Up;
  11. 5、主程序调用
  12. int main(void)
  13. {
  14.   NVIC_Configuration();
  15.   StateContr.Control_Mode = 1;
  16.   PID_init();
  17.   Key_GPIO();
  18.   Hall_Gpio();
  19.   Encoder_Init();
  20.   USARTx_Config();
  21.   Adc_Conf();
  22.   DRV8313_GPIO();
  23.   Tim1_PWM_Init();
  24.   ROTATOR_Init();
  25.   printf("hello \n");
  26.   Offset_CurrentReading();
  27.   while(1){
  28.     Key_Scan();
  29.   }
  30. }
小小蚂蚁举千斤 发表于 2024-9-29 18:56 | 显示全部楼层
PID重在调节参数
AdaMaYun 发表于 2024-9-30 11:23 | 显示全部楼层
研究一下参数代码
为你转身 发表于 2024-9-30 12:54 来自手机 | 显示全部楼层
ADC_PhaseV_Curr[i]=ADC_PhaseV_Curr[k];                      ADC_PhaseV_Curr[k]=temp;
tpgf 发表于 2024-10-11 09:24 | 显示全部楼层
FOC系统通常采用双闭环架构,包括内部的电流环和外部的速度环或位置环
木木guainv 发表于 2024-10-11 18:11 | 显示全部楼层
通过PI控制器处理Iq和Id,实现对交流同步电机的控制
磨砂 发表于 2024-10-11 18:43 | 显示全部楼层
晓伍 发表于 2024-10-11 19:14 | 显示全部楼层
电机机械角度和电角度对准后进入电流闭环,给定iq目标值,观察Iq和Id的变化
八层楼 发表于 2024-10-11 19:47 | 显示全部楼层
传统的PI控制器可能需要结合优化算法以提升性能
观海 发表于 2024-10-11 20:20 | 显示全部楼层
Amazingxixixi 发表于 2024-10-30 15:43 | 显示全部楼层
PID是软件的么?还是硬件的?
地瓜patch 发表于 2024-10-31 08:15 来自手机 | 显示全部楼层
电机控制必不可少的基本方法
suncat0504 发表于 2024-10-31 10:34 | 显示全部楼层
pid控制器调试程序,学习
610u 发表于 2025-4-30 22:40 | 显示全部楼层
DMA 检测每次都阻塞等待:
c
复制
编辑
while(DMA_GetFlagStatus(...) == RESET);
如果此函数运行在中断或高优先级任务中,可能导致系统响应变慢。可以将 DMA 改为一次性传输 100 组数据,采完后中断通知处理更优。
代码复用性差,可封装为 Offset_ADC_Channel(uint16_t *buf, uint16_t *offset_result)。
610u 发表于 2025-4-30 22:41 | 显示全部楼层
处理方向时的临界判断语句混乱,可能出现语义错误:
c
复制
编辑
这行似乎是复制/粘贴错误,必须清理无效语法。
定值 4000 可能为一圈计数上限的近似值,推荐宏定义以提高可读性:
c
复制
编辑
#define ENCODER_CNT_MAX 4000
speedms 没有单位注释,interval*15 可能与计时器时间基准或分辨率有关,建议注释说明。
键盘手没手 发表于 2025-4-30 22:49 | 显示全部楼层
电流环控制(Iq单轴 PID)
优点:
使用 PI 控制器,适用于稳态控制。
Iq 电流闭环调试是FOC(矢量控制)的关键。
注意:
Id_Kp = 0,表示没有对 d 轴电流控制,确认是否在开环中简化。
pi_iq.Out 经 LPF 后作为 Vq 输出,合理;Volt_dq.V1=0; 固定 Vd 为 0,说明正在调试 q 轴,符合单轴测试逻辑。
键盘手没手 发表于 2025-4-30 22:50 | 显示全部楼层
PID 控制目标是电机调速还是电流闭环控制?
suncat0504 发表于 2025-5-23 15:44 | 显示全部楼层
“FOC系统通常采用双闭环架构,包括内部的电流环和外部的速度环或位置环”-----------每个汉字都懂,连起来就不懂了,哈哈哈哈
小夏天的大西瓜 发表于 2025-5-27 10:23 | 显示全部楼层
PID控制是常用的控制方法
柴库柴库 发表于 2025-5-28 22:40 | 显示全部楼层
foc控制电机,一统天下了
