STMS003做个外接中断触发程序,使用PF4脚外接中断源。
void interrupt_Init(void)
GPIO_Init(GPIOF, pf4, GPIO_MODE_IN_PU_IT);
GPIO_WriteHigh(GPIOF,pf4);
EXti_SetExtIntSensitivity(EXTI_PORT_GPIOF, EXTI_SENSITIVITY_LOW_ONLY);
当GPIO_Init函数配置成上拉触发(pull-up触发GPIO_MODE_IN_PU_IT模式)测试时很正常,GPIO_WriteHigh(GPIOF,pf4)能拉高PF4口为高电平,当PF4的引出线触碰到GND后,能够正常下降沿触发一次。测试OK。
但将上拉触发换成浮动触发(folating触发GPIO_MODE_IN_FL_IT模式)时,则GPIO_WriteHigh(GPIOF,pf4)不能拉高PF4口为高电平,PF4脚却一直循环触发着中断。
请问各位大神有建议否? |
