[STM32N6] 【STM32N6570-DK评测】二、解决了pack包的问题,解析第一个例程
 楼主| 地瓜patch 发表于 2025-4-27 22:07 来自手机 | 显示全部楼层 |阅读模式
一、概述
终于解决解决了pack包的问题,见帖子https://bbs.21ic.com/icview-3446880-1-1.html打开STM32Cube_FW_N6_V1.1.0开发包,下入第一个bsp例程,该例程分为5个独立的demo。
二、例程功能分析
对例程进行解读分析,也是一个学习过程。
通过读程序能够学习作者的编程思路和方法。
1.第一个Demo是触屏填充实现这个功能的代码逻辑很简单,首先由 x1 = TS_State.TouchX;        y1 = TS_State.TouchY;分别获取当前触点的坐标值。然后判断坐标在蓝、红、黄、绿哪个圆内 if ((y1 > (CIRCLE_YPOS(1) - CIRCLE_RADIUS)) && (y1 < (CIRCLE_YPOS(1) + CIRCLE_RADIUS)))
将其用对应颜色填充  UTIL_LCD_FillCircle(CIRCLE_XPOS(1), CIRCLE_YPOS(1), CIRCLE_RADIUS, UTIL_LCD_COLOR_BLUE);
代码如下
if(TS_State.TouchDetected)
          if ((x1 > (CIRCLE_XPOS(1) - CIRCLE_RADIUS)) &&
              (x1 < (CIRCLE_XPOS(1) + CIRCLE_RADIUS)))
            if ((state & 1) == 0)
              Touchscreen_DrawBackground_Circles(state);
              HAL_Delay(1);
              state = 1;
          if ((x1 > (CIRCLE_XPOS(2) - CIRCLE_RADIUS)) &&
              (x1 < (CIRCLE_XPOS(2) + CIRCLE_RADIUS)))
            if ((state & 2) == 0)
              UTIL_LCD_FillCircle(CIRCLE_XPOS(2), CIRCLE_YPOS(2), CIRCLE_RADIUS, UTIL_LCD_COLOR_RED);
              HAL_Delay(1);
              state = 2;
          if ((x1 > (CIRCLE_XPOS(3) - CIRCLE_RADIUS)) &&
              (x1 < (CIRCLE_XPOS(3) + CIRCLE_RADIUS)))
            if ((state & 4) == 0)
              UTIL_LCD_FillCircle(CIRCLE_XPOS(3), CIRCLE_YPOS(3), CIRCLE_RADIUS, UTIL_LCD_COLOR_YELLOW);
              state = 4;
          if ((x1 > (CIRCLE_XPOS(4) - CIRCLE_RADIUS)) &&
              (x1 < (CIRCLE_XPOS(4) + CIRCLE_RADIUS)))
            if ((state & 8) == 0)
              UTIL_LCD_FillCircle(CIRCLE_XPOS(4), CIRCLE_YPOS(3), CIRCLE_RADIUS, UTIL_LCD_COLOR_GREEN);
              state = 8;
      } /* of if(TS_State.TouchDetected) */
2.第二个是跟随触点生成随机颜色的圆点
以下四条语句,画出了上图页眉蓝色区域并填充,限定了文字位白色,填充为蓝色
    UTIL_LCD_SetTextColor(UTIL_LCD_COLOR_WHITE);
    UTIL_LCD_SetFont(&Font24);
以下四条语句,将文字"Touchscreen dual touch polling "  "Please press the Touchscreen to activate"
"single and dual touch, then press USER button",指定起始坐标后分三行写在页眉蓝色区域
UTIL_LCD_DisplayStringAt(0, 0, (uint8_t *)"Touchscreen dual touch polling", CENTER_MODE);
UTIL_LCD_SetFont(&Font16);
UTIL_LCD_DisplayStringAt(0, 45, (uint8_t *)"Please press the Touchscreen to activate", CENTER_MODE);
UTIL_LCD_DisplayStringAt(0, 60, (uint8_t *)"single and dual touch, then press USER button", CENTER_MODE);
以下两条语句画出了触屏区域,用两个矩形框加粗了边界的宽度。将线宽从1个像素加粗为2个像素。
UTIL_LCD_DrawRect(10, 90, x_size - 20, y_size - 100, UTIL_LCD_COLOR_BLUE);
UTIL_LCD_DrawRect(11, 91, x_size - 22, y_size - 102, UTIL_LCD_COLOR_BLUE);
以下语句在触摸点x1,y1画出了一个圆点,该点半径为15个像素,颜色是由touchscreen_color_idx累加得来,所以不同时刻触摸同一个像素显示颜色不同。
UTIL_LCD_FillCircle(x1, y1, TS_MULTITOUCH_FOOTPRINT_CIRCLE_RADIUS, colors[(touchscreen_color_idx++ % 24)]);
以下语句将TOUCH INFO显示在页脚
UTIL_LCD_DisplayStringAt(0, y_size - 70, (uint8_t *)"TOUCH INFO : ", CENTER_MODE);
在这个demo中可以同时触摸两个触点,由x2 = TS_MTState.TouchX[1];y2 = TS_MTState.TouchY[1];语句获取第二个触点的坐标
以下语句将两个触点坐标显示在页脚位置,紧随TOUCH INFO :之后
sprintf((char*)lcd_string, "x1 = %u, y1 = %u",  x1, y1);
sprintf((char*)lcd_string, "x2 = %u, y2 = %u",  x2, y2);
注意:在这个demo中,同时只能最多触摸两个点,大于两个点的触摸,死机。
3.第三个也是跟随触点生成随机颜色的点,不过这个demo是将屏分为240份,随机颜色填充240个方格
用一个嵌套循环将屏幕分为240个方格,hTS.Width=800;hTS.Height=480;因此K的最大值为20,L的最大值为12在这个demo中,只能识别一个触点,无法识别两个及其以上。
for(k = 0; k < hTS.Width/40; k++)
    for(l = 0; l < hTS.Height/40; l++)
      UTIL_LCD_DrawRect(40*k, 40*l,40,40, UTIL_LCD_COLOR_BLACK);
4.第四个Demo是LCD显示
1)显示3行8列 80*80像素的调色板
  for (color_index = 0; color_index < 24; color_index++)
    int x = 80 * ((color_index % 8) + 1);
    int y = 80 * (color_index / 8 + 2);
    UTIL_LCD_FillRect(x, y, 80, 80, colors[color_index]);
2)显示4行6列空心圆
  for(color_index = 0; color_index < 4; color_index++)
    for(i = 0; i < 6; i++)
      UTIL_LCD_DrawCircle(150 + (100*i), 100*(color_index+1), 40, UTIL_LCD_COLOR_BLACK);
3)显示一个4行6列的24色圆形配色表
      UTIL_LCD_FillCircle(150 + (100*i), 100*(color_index+1), 40, colors[colorIndex]);
      colorIndex++;
      HAL_Delay(50);
4)显示3个彩色三角形
for(color_index = 0; color_index < 6; color_index++)
    for(i = 0; i < 4; i++)
      triangle[0.X = 40*color_index;
      triangle[0.Y = 40 + 50*(i);
      triangle[1.X = 40*(color_index+1);
      triangle[1.Y = 65 + 50*(i);
      triangle[2.X = 40*color_index;
      triangle[2.Y = 40 + 50*(1+i);
      UTIL_LCD_FillPolygon(triangle, 3, colors[colorIndex]);
      if(colors[colorIndex == UTIL_LCD_COLOR_WHITE)
        UTIL_LCD_DrawPolygon(triangle, 3, UTIL_LCD_COLOR_BLACK);
      colorIndex++;
5)在同一行显示4个ST图标
UTIL_LCD_DrawBitmap(80, 130, (uint8_t *)st**);
  UTIL_LCD_DrawBitmap(240, 130, (uint8_t *)st**);
  UTIL_LCD_DrawBitmap(400, 130, (uint8_t *)st**);
  UTIL_LCD_DrawBitmap(560, 130, (uint8_t *)st**);
6)RGB888显示测试
UTIL_LCD_DisplayStringAt(0, 100, (uint8_t *)"LCD RGB888", CENTER_MODE);
  for (color_index = 0; color_index < 16; color_index++)
     x = 40 * ((color_index % 4) + 8) ;
     y = (40 * (color_index / 4 + 4));
    UTIL_LCD_FillRect(x, y, 40, 40, colors[color_index]);
7)ARGB4444显示测试
UTIL_LCD_DisplayStringAt(0, 100, (uint8_t *)"LCD ARGB4444", CENTER_MODE);
  for (color_index = 8; color_index < 24; color_index++)
5.第五个demo是读写sd卡
SD卡初始化
UTIL_LCD_DisplayStringAt(20, 100, (uint8_t *)"SD Initialization : OK", LEFT_MODE);
SD卡连接正常
  UTIL_LCD_DisplayStringAt(20, 300, (uint8_t *)"     SD Connected", RIGHT_MODE);
SD卡擦除正常
UTIL_LCD_DisplayStringAt(20, 115, (uint8_t *)"SD ERASE : OK", LEFT_MODE);
SD写入0x22FF
SD_state = BSP_SD_WriteBlocks(0,(uint32_t *)aTxBuffer, SD_START_ADDRESS, NB_BLOCK_BUFFER);
SD写入完成
UTIL_LCD_DisplayStringAt(20, 130, (uint8_t *)"SD WRITE : OK", LEFT_MODE);
SD读取完成
UTIL_LCD_DisplayStringAt(20, 145, (uint8_t *)"SD READ : OK", LEFT_MODE);
SD测试结束
UTIL_LCD_DisplayStringAt(20, 160, (uint8_t *)"SD TEST : OK", LEFT_MODE);
6.第六个是摄像头获取图像并显示在LCD屏上,并旋转180度
获取Camera数据
BSP_CAMERA_Start(0, (uint8_t *)CAMERA_FRAME_BUFFER, CAMERA_MODE_CONTINUOUS);
Camera图像在LCD中反转4次,首先是垂直镜像,然后是水平镜像
while(MirrorFlipIndex < 4)
        Camera_ISP_IdleWait(2000);
        BSP_CAMERA_SetMirrorFlip(0, CameraMirrorFlip[MirrorFlipIndex]);
        MirrorFlipIndex++;
IMG_20250426_161818_edit_56282233005738.jpg [attach]2398350[/attach[color=var(--darkreader-text-444444, #a19c95)][backcolor=var(--darkreader-background-ffffff, #141617)]] IMG_20250426_161820_edit_56299173744124.jpg
Camera镜像函数,说实话没看明白,没有对数据进行造作呢
int32_t BSP_CAMERA_SetMirrorFlip(uint32_t Instance, uint32_t MirrorFlip)
  int32_t ret;
  if (Instance >= CAMERA_INSTANCES_NBR)
    ret = BSP_ERROR_WRONG_PARAM;
  else if (Camera_Cap.MirrorFlip == 0U)
    ret = BSP_ERROR_FEATURE_NOT_SUPPORTED;
  else if (Camera_Drv->MirrorFlipConfig(Camera_CompObj, MirrorFlip)  < 0)
    ret = BSP_ERROR_COMPONENT_FAILURE;
  else
    Camera_Ctx[Instance.MirrorFlip = MirrorFlip;
    ret = BSP_ERROR_NONE;
  /* Return BSP status */
  return ret;
从DCMIPP中获取Camera数据
int32_t BSP_CAMERA_Start(uint32_t Instance, uint8_t *pbuff, uint32_t Mode)
  int32_t ret = BSP_ERROR_NONE;
  else if (HAL_DCMIPP_CSI_PIPE_Start(&hcamera_dcmipp, DCMIPP_PIPE1, DCMIPP_VIRTUAL_CHANNEL0 , (uint32_t)pbuff, Mode) != HAL_OK)
    ret = BSP_ERROR_PERIPH_FAILURE;
  else
    /* No action */
  /* Start the Image Signal Processing */
  if (ISP_Start(&hcamera_isp) != ISP_OK)
  return ret;
三、小结
这个bsp的例程所展示的都是最基本的功能。
这个例程的最大好处来说就是简单,逻辑清晰,流程明了。作为学习用例程极其合适。
通过分析程序,学习了多种图形的绘制,填充。
学习了如何获取触电坐标。
学习了Camera数据的获取和使用。
这个程序的确值得认真学习分析。
开卷有益!!!!
真的问题不大 发表于 2025-5-13 09:48 | 显示全部楼层
感谢楼主分享
suncat0504 发表于 2025-5-13 14:12 | 显示全部楼层
使用例程,大于两个点的触摸,死机?程序处理逻辑有遗漏?
Ketose 发表于 2025-7-8 16:00 | 显示全部楼层
收一块STM32N6开发板。
szt1993 发表于 2025-7-8 19:34 | 显示全部楼层
图形解码用的啥库文件?
