新手求教,Verilog 写的抢答器
2811|10
 楼主| jim727 发表于 2012-12-12 21:46 | 显示全部楼层 |阅读模式
小弟新手,很多不懂,谢谢各位帮助
我用quartus 9.1做的,我想知道,为什么变成未知值(X)了
代码很乱,请不惜赐教
我这个是做抢答器,EN1~6是抢答按钮,GRP1~6是各组得分(初始化10分),UP是开始和重置信号,DN是高位得分,低位扣分,check是确认评分。over是控制1次抢答只能评分一次,en是看是否有人按下抢答按钮。lock是控制让第一组抢答后屏蔽其他组信号。我扬声器没写,所以留下记号。
---------------------------eda8_8.v-----------------------------------------------------------------
module eda8_8(CLK,en1,en2,en3,en4,en5,en6,GRP1,GRP2,GRP3,GRP4,GRP5,GRP6,UP,DN,check);
input UP,DN,en1,en2,en3,en4,en5,en6,CLK,check;
output  [7:0] GRP1,GRP2,GRP3,GRP4,GRP5,GRP6;
reg [7:0] GRP1,GRP2,GRP3,GRP4,GRP5,GRP6;
reg EN1,EN2,EN3,EN4,EN5,EN6,lock,checked,over;
wire en;
initial
begin
lock<=1'b1;
GRP1<=7'b00010000;
GRP2<=7'b00010000;
GRP3<=7'b00010000;
GRP4<=7'b00010000;
GRP5<=7'b00010000;
GRP6<=7'b00010000;
checked<=1'b0;
over<=1'b1;
end
always @(check or GRP1 or GRP2 or GRP3 or GRP4 or GRP5 or GRP6 )
begin
    if(check);
    else
    over=~over;
end
always @(posedge CLK)
begin
    case({UP,DN})
    2'b10://wrong answer
    begin
    if(checked&over)
    begin
    case({EN1,EN2,EN3,EN4,EN5,EN6})
    6'b100000:
    begin
        if(GRP1[3:0]!=4'h0)
        GRP1[3:0]<=GRP1[3:0]-4'h1;
    else
        begin
        GRP1[7:4]<=GRP1[7:4]-4'h1;
        GRP1[3:0]<=4'h9;
        end
    end
    6'b010000:
    begin
        if(GRP2[3:0]!=4'h0)
        GRP2[3:0]<=GRP2[3:0]-4'h1;
    else
        begin
        GRP2[7:4]<=GRP2[7:4]-4'h1;
        GRP2[3:0]<=4'h9;
        end
    end
    6'b001000:
    begin
        if(GRP3[3:0]!=0)
        GRP3[3:0]<=GRP3[3:0]-4'h1;
    else
        begin
        GRP3[7:4]<=GRP3[7:4]-4'h1;
        GRP3[3:0]<=4'h9;
        end
    end
    6'b000100:
    begin
        if(GRP4[3:0]!=0)
        GRP4[3:0]<=GRP4[3:0]-4'h1;
    else
        begin
        GRP4[7:4]<=GRP4[7:4]-4'h1;
        GRP4[3:0]<=4'h9;
        end
    end
    6'b000010:
    begin
        if(GRP5[3:0]!=0)
        GRP5[3:0]<=GRP5[3:0]-4'h1;
    else
        begin
        GRP5[7:4]<=GRP5[7:4]-4'h1;
        GRP5[3:0]<=4'h9;
        end
    end
    6'b000001:
    begin
        if(GRP6[3:0]!=0)
        GRP6[3:0]<=GRP6[3:0]-4'h1;
    else
        begin
        GRP6[7:4]<=GRP6[7:4]-4'h1;
        GRP6[3:0]<=4'h9;
        end
    end
    default:
    begin
    GRP1 <= GRP1;GRP2 <= GRP2;
    GRP3 <= GRP3;GRP4 <= GRP4;
    GRP5 <= GRP5;GRP6 <= GRP6;
    end
    endcase
    //bi~~~~~~~~~~~~500+2000hz
    end
    end
    2'b11:///right answer
    begin
    if(checked&over)
    begin
    6'b100000:
    begin
        if(GRP1[3:0]==4'h9)
        begin
        GRP1[7:4]<=GRP1[7:4]+4'h1;
        GRP1[3:0]<=4'h0;
        end
    else
        begin
        GRP1[3:0]<= GRP1[3:0]+4'h1;
        end
    end
    6'b010000:
    begin
        if(GRP2[3:0]==9)
        begin
        GRP2[7:4]<=GRP2[7:4]+4'h1;
        GRP2[3:0]<=4'h0;
        end
    else
        begin
        GRP2[3:0]<=GRP2[3:0]+4'h1;
        end
    end
    6'b001000:
    begin
        if(GRP3[3:0]==9)
        begin
        GRP3[7:4]<=GRP3[7:4]+4'h1;
        GRP3[3:0]<=4'h0;
        end
    else
        begin
        GRP3[3:0]<=GRP3[3:0]+4'h1;
        end
    end
    6'b000100:
    begin
        if(GRP4[3:0]==9)
        begin
        GRP4[7:4]<=GRP4[7:4]+4'h1;
        GRP4[3:0]<=4'h0;
        end
    else
        begin
        GRP4[3:0]<=GRP4[3:0]+4'h1;
        end
    end
    6'b000010:
    begin
        if(GRP5[3:0]==4'h9)
        begin
        GRP5[7:4]<=GRP5[7:4]+4'h1;
        GRP5[3:0]<=4'h0;
        end
    else
        begin
        GRP5[3:0]<=GRP5[3:0]+4'h1;
        end
    end
    6'b000001:
    begin
        if(GRP6[3:0]==9)
        begin
        GRP6[7:4]<=GRP6[7:4]+4'h1;
        GRP6[3:0]<=4'h0;
        end
    else
        begin
        GRP6[3:0]<=GRP6[3:0]+4'h1;
        end
    end
    default:
    begin
    end
    endcase
    //bi~~~~~~~~~~~~500+1000hz
    end
     end
    2'b00://not start yet
    begin
    if(EN1|EN2|EN3|EN4|EN5|EN6);
    //bi~~~~~~~~~~~~500hz
    end
    2'b01://not start yet
    begin
    end
    endcase
end
assign en=en1|en2|en3|en4|en5|en6;
always @(posedge en or negedge UP or posedge check)
begin
    if(check)checked=check;
    case({en1,en2,en3,en4,en5,en6})
    6'b100000:
    begin
    EN1=1'b1&lock;
    end
    6'b010000:
    begin
    EN2=1'b1&lock;
    end
    6'b001000:
    begin
    EN3=1'b1&lock;
    end
    6'b000100:
    begin
    EN4=1'b1&lock;
    end
    6'b000010:
    begin
    EN5=1'b1&lock;
    end
    6'b000001:
    begin
    EN6=1'b1&lock;
    end
    default:
    begin end
    endcase
if(!UP)
    begin
    checked=1'b0;
    lock=~lock;
    EN1=1'b0; EN2=1'b0;
    EN3=1'b0; EN4=1'b0;
    EN5=1'b0; EN6=1'b0;
    end
end
endmodule
xlhtracy 发表于 2012-12-13 17:48 | 显示全部楼层
坐的猴哥
jahnson066 发表于 2012-12-13 19:16 | 显示全部楼层
猴哥是搞xilinx的,不是altera,哈哈
528388812 发表于 2012-12-13 19:23 | 显示全部楼层
这是一套程序?
 楼主| jim727 发表于 2012-12-13 21:33 | 显示全部楼层
这是一套程序?
不是,我只是做了编号
 楼主| jim727 发表于 2012-12-13 21:34 | 显示全部楼层
谢谢提醒,还是希望有人解答,至少给个思路
GoldSunMonkey 发表于 2012-12-14 22:34 | 显示全部楼层
哪里觉得不对呢?
 楼主| jim727 发表于 2012-12-16 21:01 | 显示全部楼层
哪里觉得不对呢?
仿真时序图的输出结果不符合预期,我用红色方框标注的位置出现X(undefined value),我想知道为什么
GoldSunMonkey 发表于 2012-12-16 21:26 | 显示全部楼层
检查该值的来源
 楼主| jim727 发表于 2012-12-17 13:16 | 显示全部楼层
检查该值的来源
怎么检查  输出不是reg类型么,怎么会未知值
zhaorj8780 发表于 2013-1-16 18:59 | 显示全部楼层
多学习
