VHDL仿真testbench书写问题
1484|2
 楼主| damoyeren 发表于 2013-11-13 13:51 | 显示全部楼层 |阅读模式
1.本程序是串口接收程序,收到的数据是乱的,我想仿真下。程序如下:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity fasong is
port(
   clkin  :in std_logic;
   resetin:in std_logic;
   rx     :in std_logic;
   led    :out std_logic_vector(2 downto 0)
end fasong;
architecture behave of fasong is
signal clk_temp:std_logic;
signal led_temp:std_logic_vector(7 downto 0);
component uart_r is
  port(clk_r  :in std_logic;
    reset_r:in std_logic;
    rx_in  :in std_logic;  --串口数据输入
    rx_out :out std_logic_vector(7 downto 0);--串口输入输出
    ready:out std_logic);--接收一帧数据结束标志信号
end component;
component fenpin is
port(clk:in std_logic;
   reset_t:in std_logic;
   clk_out:out std_logic);
    end component;
begin
U1:fenpin port map(clk=>clkin,reset_t=>resetin,clk_out=>clk_temp);
U2:uart_r port map(clk_r=>clk_temp,reset_r=>resetin,rx_in=>rx,rx_out=>led_temp);
process(resetin,clkin)
begin
  if resetin='0' then
   led<="111";
  else
   if clkin'event and clkin='1' then
    case led_temp is
     when x"00"=>led<="000";
     when x"01"=>led<="001";
     when x"02"=>led<="010";
     when x"03"=>led<="011";
     when x"04"=>led<="111";
     when others=>led<="000";
    end case;
   end if;
  end if;
end process;
end behave;
2.testbench如下
library ieee;
entity fasong is
port(
   rx     :in std_logic;
end fasong;
component uart_r is
    rx_in  :in std_logic;  --´®¿ÚÊý¾ÝÊäÈë
    rx_out :out std_logic_vector(7 downto 0);--´®¿ÚÊäÈëÊä³ö
    ready:out std_logic);--½ÓÊÕÒ»Ö¡Êý¾Ý½áÊø±êÖ¾ÐźÅ
end component;
component fenpin is
    end component;
begin
begin
  if resetin='0' then
   led<="111";
  else
    case led_temp is
    end case;
   end if;
  end if;
end process;
end behave;
testbench我觉得有问题,但是不知道如何写是好?
gaochy1126 发表于 2013-11-14 14:38 | 显示全部楼层
楼主的的串口没有使用fifo么?
gaochy1126 发表于 2013-11-14 14:39 | 显示全部楼层
建议使用fifo,先存储数据,然后读取!
