//十六进制转十进制
Console.WriteLine("十六进制 CC的十进制表示: "+Convert.ToInt32("CC", 16));
16进制转换成汉字
///<summary>
/// 从16进制转换成汉字
/// </summary>
/// <param name="hex"></param>
/// <param name="charset">编码,如"utf-8","gb2312"</param>
/// <returns></returns>
public static string UnHex(string hex, string charset)
if (hex == null)
throw new ArgumentNullException("hex");
hex = hex.Replace(",", "");
hex = hex.Replace("\n", "");
hex = hex.Replace("\\", "");
hex = hex.Replace(" ", "");
if (hex.Length % 2 != 0)
hex += "20";//空格
// 需要将 hex 转换成 byte 数组。
byte[] bytes = new byte[hex.Length / 2];
for (int i = 0; i < bytes.Length; i++)
try
// 每两个字符是一个 byte。
bytes = byte.Parse(hex.Substring(i * 2, 2),
System.Globalization.NumberStyles.HexNumber);
catch
// Rethrow an exception with custom message.
throw new ArgumentException("hex is not a valid hex number!", "hex");
System.Text.Encoding chs = System.Text.Encoding.GetEncoding(charset);
return chs.GetString(bytes);
