AXD里,JlinkRDI的jtag时钟设置为固定的1000KHz,flash编程没有使能,软件断点使能,“Allow instruction set simulation”钩上了,小端,“Hardware, halt after reset(normal)”,复位后延迟为0ms。<br /><br />smartarm2200的板子,跳线设为bank0-ram,bank1-flash。<br />同样的代码(就是光盘自带的led流水灯例程),用EasyJtag + AXD调试正常,但是用Jlink + AXD调试,断点有效,但是查看0x80000000开始的空间全是0xFF(AXD根本没能把数据加载到ram里)。<br /><br />用Jlink的命令行测试如下(还是写不到ram里):<br /><br />VTarget = 3.261V<br />Info: TotalIRLen = 4, IRPrint = 0x01<br />JTAG speed: 30 kHz<br />Found 1 JTAG device, Total IRLen = 4:<br /> Id of device #0: 0x4F1F0F0F<br />Found ARM with core Id 0x4F1F0F0F (ARM7)<br /> ETM V1.2: 1 pairs addr.comp, 0 data comp, 4 MM decs, 1 counters<br />J-Link>mem 0x80000000,4<br />80000000 = FF FF FF FF<br />J-Link>w4 0x80000000,0x12345678 “写32位数据到0x80000000”<br />Halting CPU in order to write memory...<br />Writing 12345678 -> 80000000<br />J-Link>mem 0x80000000,4 “再读出来,还是空的”<br />80000000 = FF FF FF FF<br />J-Link>st<br />VTarget=3.261V<br />ITarget=0mA<br />TCK=1 TDI=0 TDO=0 TMS=0 TRES=1 TRST=1<br />Supported JTAG speeds:<br /> - 48 MHz/n, (n>=4). => 12000kHz, 9600kHz, 8000kHz, ...<br /> - Adaptive clocking<br /><br />Jlink软件版本为378c。<br /><br />是我的设置/方法有问题,还是Jlink的问题,还是smartarm2200或者AXD不支持这么调试? |
