达到1.5mm的话,按频率计算得200GHz,看来不是这样,它是怎么实现这个精度的?<br /><a href="http://www.fluke.com.cn/cnzh/products/specifications.htm-cs_id=38155(FlukeProducts)&category=LDMT(FlukeProducts).htm" target=_blank>http://www.fluke.com.cn/cnzh/products/specifications.htm-cs_id=38155(FlukeProducts)&category=LDMT(FlukeProducts).htm</a><br /><TR><td class=ubb><br />416D 和 411D 激光测距仪</td> </TR><TR><td class=ubb><img src="http://www.fluke.com.cn/images/spacer.gif"></td> </TR><TR><td class=ubb><br /><table class=ubb cellspacing=0><TR><td class=ubb>技术参数</td></TR><TR><td class=ubb>距离(对于较长距离,请使用一个靶板)</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>0.1 m 至 30 m</td></TR><TR><td class=ubb></td><td class=ubb>(0.33 ft 至 100 ft)</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>0.05 m 至 60 m</td></TR><TR><td class=ubb></td><td class=ubb>(0.16 ft 至 200 ft)</td></TR></table></td></TR><TR><td class=ubb>测量准确度</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D*</td><td class=ubb>± 3 mm (0.118 in)</td></TR><TR><td class=ubb>Fluke 416D**</td><td class=ubb>± 1.5 mm (± 0.059 in)</td></TR></table></td></TR><TR><td class=ubb>显示单位</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>00.000 m, 000 ft 00 in 1/8, 0000 in 1/8</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>00.000 m, 000 ft 00 in 1/16, 0000 in 1/16, 000.00 ft</td></TR></table></td></TR><TR><td class=ubb>激光等级</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>Class II</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>Class II</td></TR></table></td></TR><TR><td class=ubb>激光类型</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>635 nm, < 1 mW</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>635 nm, < 1 mW</td></TR></table></td></TR><TR><td class=ubb>自动断电</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>180 秒后</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>180 秒后</td></TR></table></td></TR><TR><td class=ubb>连续测量</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>是</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>是</td></TR></table></td></TR><TR><td class=ubb>加/减</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>是</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>是</td></TR></table></td></TR><TR><td class=ubb>电池寿命</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>最多 3000 次测量</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>最多 5000 次测量</td></TR></table></td></TR><TR><td class=ubb>LCD 照明</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>否</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>是</td></TR></table></td></TR><TR><td class=ubb>数据位置</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>否</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>10</td></TR></table></td></TR><TR><td class=ubb>最小值/最大值</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>否</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>是</td></TR></table></td></TR><TR><td class=ubb>声音反馈</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>否</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>是</td></TR></table></td></TR><TR><td class=ubb>勾股定理功能(间接测量)</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>简单</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>全</td></TR></table></td></TR><TR><td class=ubb>防护等级</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>IP40</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>IP54</td></TR></table></td></TR><TR><td class=ubb>尺寸</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>123 mm x 50 mm x 26 mm</td></TR><TR><td class=ubb></td><td class=ubb>(4.84 in x 1.97 in x 1.02 in)</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>135 mm x 46 mm x 31 mm</td></TR><TR><td class=ubb></td><td class=ubb>(5.31 in x 1.81 in x 1.22 in)</td></TR></table></td></TR><TR><td class=ubb>重量</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>150 g (5.29 oz)</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>110 g (3.88 oz)</td></TR></table></td></TR><TR><td class=ubb>温度范围</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb><B>贮存:</B> -25 °C 至 70 °C(-13 °F 至 158 °F)<br /></td></TR><TR><td class=ubb></td><td class=ubb><B>工作:</B> 0 °C 至 40 °C(32 °F 至 104 °F)</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb><B>贮存:</B> -25 °C 至 70 °C(-13 °F 至 158 °F)<br /></td></TR><TR><td class=ubb></td><td class=ubb><B>工作:</B> 0 °C 至 40 °C(32 °F 至 104 °F)</td></TR></table></td></TR><TR><td class=ubb>使用海拔<br />(ISO 9022)</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>最高 3500 m</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>最高 3500 m</td></TR></table></td></TR><TR><td class=ubb>贮存湿度<br />(35 °C 时)</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>最高 85 %(24 小时)</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>最高 85 %(24 小时)</td></TR></table></td></TR><TR><td class=ubb>电池</td><td class=ubb><table class=ubb cellspacing=0><TR><td class=ubb>Fluke 411D</td><td class=ubb>AAA (2)</td></TR><TR><td class=ubb>Fluke 416D</td><td class=ubb>AAA (2)</td></TR></table></td></TR></table><br />* 在有利条件下(最佳目标表面、室温),最长 10 m (33 ft)。在不利条件下(如强烈日照、反射很弱的目标表面或很大的温度波动),距离在 10 m (33 ft) 以上时,测量准确度可能会下降到大约 ± 0.25 mm/m (± 0.003 in/ft)。 <br />** 在有利条件下(最佳目标表面、室温),最长 10 m (33 ft)。在不利条件下(如强烈日照、反射很弱的目标表面或很大的温度波动),距离超过 10 m (33 ft) 时的偏差可能会增加大约 ±0.15 mm/m (±0.0018 in/ft)。 </td></TR> |
