static void MX_LPUART1_UART_Init(void) { /* USER CODE BEGIN LPUART1_Init 0 */ /* USER CODE END LPUART1_Init 0 */ /* USER CODE BEGIN LPUART1_Init 1 */ /* USER CODE END LPUART1_Init 1 */ hlpuart1.Instance = LPUART1; hlpuart1.Init.BaudRate = 115200; hlpuart1.Init.WordLength = UART_WORDLENGTH_8B; hlpuart1.Init.StopBits = UART_STOPBITS_1; hlpuart1.Init.Parity = UART_PARITY_NONE; hlpuart1.Init.Mode = UART_MODE_TX_RX; hlpuart1.Init.HwFlowCtl = UART_HWCONTROL_NONE; hlpuart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE; hlpuart1.Init.ClockPrescaler = UART_PRESCALER_DIV1; hlpuart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT; hlpuart1.FifoMode = UART_FIFOMODE_DISABLE; if (HAL_UART_Init(&hlpuart1) != HAL_OK) { Error_Handler(); } if (HAL_UARTEx_SetTxFifoThreshold(&hlpuart1, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK) { Error_Handler(); } if (HAL_UARTEx_SetRxFifoThreshold(&hlpuart1, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK) { Error_Handler(); } if (HAL_UARTEx_DisableFifoMode(&hlpuart1) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN LPUART1_Init 2 */ #ifdef BOARD_IN_STOP_MODE LPUART1_EXTI_ENABLE_IT(); #endif /* BOARD_IN_STOP_MODE */ /* USER CODE END LPUART1_Init 2 */ }2、LPUART_RX中断处理 复制void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) { UserReceptionComplete = 1; } RX收到数据,设置标志UserReceptionComplete = 1。 3、main函数 复制 BSP_LED_On(LD2); /* wait for two seconds before test start */ HAL_Delay(2000); /* Disable Debug during Stop mode */ HAL_DBGMCU_DisableDBGStopMode(); /* Enable MCU wake-up by LPUART */ HAL_UARTEx_EnableStopMode(&hlpuart1); /*##-1- Put UART peripheral in reception process ###########################*/ if (HAL_UART_Receive_IT(&hlpuart1, (uint8_t *)aRxBuffer, RXBUFFERSIZE) != HAL_OK) { Error_Handler(); } /* about to enter STOP mode: switch off LD2 */ BSP_LED_Off(LD2); /* enter STOP mode */ HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI); /* The board receives the message from the other board. Message reception wakes up the board. */ /* Switch On LD2 */ BSP_LED_On(LD2); /* At that point, MCU has been awoken: LD2 has been turned back on ; Wake Up based on RXNE flag successful */ SystemClock_Config_fromSTOP(); /* Disable MCU wake-up by LPUART */ HAL_UARTEx_DisableStopMode(&hlpuart1); /* Wait for reception complete callback */ while (UserReceptionComplete == 0) { } /*##-2- Start the transmission process #####################################*/ /* Send back received buffer */ if (HAL_UART_Transmit_IT(&hlpuart1, (uint8_t *)aRxBuffer, RXBUFFERSIZE) != HAL_OK) { Error_Handler(); }进入STOP模式:HAL_PWR_EnterSTOPMode(PWR_LOWPOWERREGULATOR_ON, PWR_STOPENTRY_WFI); 设置LPUART1结束STOP模式使能:HAL_UARTEx_EnableStopMode(&hlpuart1); 4、while(1) 复制 while (1) { BSP_LED_Toggle(LD2); HAL_Delay(1000); /* USER CODE END WHILE */ /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ }退出stop后,进入while(1),没隔1秒翻转LD2。 三、运行 LPUART(PA2、PA3)和串口工具连接 1、按reset开机,几秒后开发板进入Stop模式,电流0.3mA左右 2、PC机通过串口工具向LPUART1发送"hello world",MCU被唤醒,PC机接收返回的"hello world",此时电流1.0mA左右 3、板载LD2每1秒翻转1次
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
84
146
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
