新近更新的应用笔记
 楼主| Go_PSoC 发表于 2012-12-16 22:23 | 显示全部楼层 |阅读模式
这两天更新的
AN2272 - PSoC® 1 Sensing - Magnetic Compass with Tilt Compensation Updated
AN2272 presents a low-cost, digital 3-axis magnetic compass based on the Honeywell HMC1043 Magneto Resistive Sensor.
http://portal.cypress.com/?rID=2667
应用手册PSoC Designer, CY8C27x43,PSoC® 1, CY8C29x66
尚未评级
12 年 12 月 14 日
AN78737 - PSoC® 1 - Temperature Sensing Solution using a TMP05/TMP06 Digital Temperature Sensor Updated
AN78737 enables designers using the PSoC 1 - CY8C28xxx family to quickly and easily interface with Analog Devices’ TMP05 or TMP06 digital temperature sensors.
http://portal.cypress.com/?rID=63613
应用手册CY8C22xxx/CY8C21x45,CY8C24x23A, PSoC Designer,CY8C23x33, CY8C28xxx,CY8C27x43, CY8C21x34,CY8C21x23, CY8C24x94, PSoC® 1,CY8C29x66
(5/5) 1 个用户
12 年 12 月 14 日
AN78692 - PSoC® 1 - Intelligent Fan Controller Updated
AN78692 demonstrates how to develop 4-wire BLDC fan control systems using PSoC® 1.The four example projects demonstrate how to use the Fan controller IP and to manage BLDC fans in a various configurations.
http://portal.cypress.com/?rID=62757
应用手册PSoC Designer, CY8C28xxx, PSoC® 1
(5/5) 1 个用户
12 年 12 月 14 日
AN78646 - Integrated Power Manager using PSoC® 1 Updated
AN78646 describes power management - a critical component of System Management Control (SMC) for computing and communication systems - and explains key concepts of power management such as voltage sequencing, fault detection, voltage and current monitoring, real-time trimming, and I2C host communication.The associated example project delivers a fully integrated power management system solution using a CY8C28645 PSoC® 1 device.
http://portal.cypress.com/?rID=63431
尚未评级
12 年 12 月 14 日
AN62083 - PSoC® 3 to PSoC 5 Migration Guide Updated
AN62083 provides an overview of topics to consider when designing a project for easy migration from PSoC® 3 to PSoC 5 devices.Device considerations, PSoC Creator topics, and firmware porting are discussed.
http://portal.cypress.com/?rID=43906
应用手册CY8C36xxx, PSoC Creator, PSoC® 5, CY8C34xxx, PSoC® 3,CY8C32xxx, CY8C38xxx
(3.7/5) 3 个用户
12 年 12 月 13 日
AN62582 - AM Modulation and Demodulation Updated
AN62582 explains how to implement amplitude modulation (AM) and demodulation using PSoC® 3 and PSoC 5LP.
http://portal.cypress.com/?rID=44407
应用手册PSoC Creator, PSoC® 5,CY8C55xxx, PSoC® 3, PSoC® 5LP,CY8C38xxx
尚未评级
12 年 12 月 12 日
AN67391 - PSoC® 1 - Low Distortion FSK Generator Updated
AN67391 demonstrates the implementation of Frequency Shift Keying (FSK) modulated signal with all hardware and zero run-time CPU (M8C core) usage.
http://portal.cypress.com/?rID=50238
应用手册CY8C24x23A, PSoC Designer,CY8C28xxx, CY8C27x43,CY8C24x94, PSoC® 1, CY8C29x66
尚未评级
12 年 12 月 12 日
AN70698 - PSoC® 3 and PSoC 5LP - Temperature Measurement with an RTD Updated
AN70698 explains how to measure temperatures precisely using a four-wire resistance temperature detector (RTD)
http://portal.cypress.com/?rID=57546
应用手册CY8C36xxx, PSoC® 5, CY8C55xxx,CY8C34xxx, PSoC® 3, PSoC® 5LP,CY8C38xxx
尚未评级
12 年 12 月 12 日
AN51234 - Getting Started with SPI in PSoC® 1 Updated
AN51234 discusses serial peripheral interface (SPI) and how PSoC® 1 handles SPI communications.
http://portal.cypress.com/?rID=34609
应用手册PSoC Designer, CY8C28xxx,CY8C27x43, CY8C21x23,CY8C24x94, PSoC® 1, CY8C29x66
(4.5/5) 2 个用户
12 年 12 月 12 日
AN75511 - PSoC® 3 and PSoC 5LP - Temperature Measurement with a ThermocoupleUpdated
AN75511 explains how to make precise temperature measurements using a Thermocouple and a PSoC® 3 or PSoC 5LP.
http://portal.cypress.com/?rID=60544
应用手册CY8C36xxx, CY8C55xxx, CY8C34xxx,PSoC® 3, PSoC® 5LP, CY8C38xxx
尚未评级
12 年 12 月 12 日
应用手册PowerPSoC®, PSoC Designer,PowerPSoC® Power Controllers
(4.3/5) 6 个用户
12 年 12 月 12 日
AN51188 - EZ Color - Multi Channel Color Mixing Using HB LEDs Updated
AN51188 describes the basics of four-channel color mixing for LED dimming applications using EZ-Color.
http://portal.cypress.com/?rID=34809
应用手册PSoC Designer, PowerPSoC® Power Controllers
(5/5) 1 个用户
12 年 12 月 12 日
AN47372 - PowerPSoC - PrISM(TM) Technology for LED Dimming Updated
AN47372 provides an overview of Cypress' PrISM Technology for LED dimming and its implementation using PowerPSoC
http://portal.cypress.com/?rID=2922
(4.5/5) 2 个用户
12 年 12 月 12 日
AN62792 - Updating Field Firmware With PLC Updated
AN62792 describes how to remotely update user application code of systems with Cypress PLC device without any external microcontroller or EEPROM.
http://portal.cypress.com/?rID=46688
应用手册PSoC Designer, Powerline Communication
尚未评级
12 年 12 月 12 日
AN60685 - PLC - Interfacing the Cypress Powerline Communication Solution to CyFi Low-Power RF Module Updated
AN60685 describes an application that bridges Cypress’ Powerline communication solution with an Artaflex AWP24S CyFi module.
http://portal.cypress.com/?rID=46713
尚未评级
12 年 12 月 12 日
AN62769 - Encrypted Data Communication Using Cypress PLC Solution Updated
http://portal.cypress.com/?rID=45490
尚未评级
12 年 12 月 12 日
AN54416 - Using CY8CPLC20 in Powerline Communication (PLC) ApplicationsUpdated
AN54416 describes how to use the Powerline Transceiver (PLT) User Module on the CY8CPLC20 device for PLC applications.
http://portal.cypress.com/?rID=37951
尚未评级
12 年 12 月 12
chen0204 发表于 2012-12-25 17:41 | 显示全部楼层
很不错啊~~给力,顶一个
taihezhibanh 发表于 2012-12-25 18:10 | 显示全部楼层
好多哇
sishangcine 发表于 2012-12-25 18:52 | 显示全部楼层
不错 支持
zgsxhzac 发表于 2012-12-25 19:00 | 显示全部楼层
最近又有的看了
shibalihuandao 发表于 2012-12-25 19:19 | 显示全部楼层
呵呵 是不少
meishizhaoshi 发表于 2012-12-25 19:25 | 显示全部楼层
多谢版主分享
wangjinlili 发表于 2012-12-25 19:27 | 显示全部楼层
有的看了
teabottle 发表于 2012-12-25 19:29 | 显示全部楼层
upupup
个人签名:迷你,但包含一切——隆重推荐Cypress中文迷你网站:http://cypress.21ic.com/ 赛普拉斯官方微博开通啦!http://e.weibo.com/cypresschina
898
