这个是个驱动彩色显示屏ili93XX_LCD的例程。
这个例程使用了一个高难的东东----SMC
至于SMC是什么东东,数据手册上有说明。这个我想在以后好好研究一下。
从字面上看应是静态存贮控制
以下是运行效果:
这个程序先是初使化静态存贮,然后通过静态存贮控制显示屏。
程序如下:
- #include "asf.h"
- #include "stdio_serial.h"
- #include "conf_board.h"
- #include "conf_clock.h"
- #include "smc.h"
- /** Chip select number to be set */
- #define ILI93XX_LCD_CS 1
- struct ili93xx_opt_t g_ili93xx_display_opt;
- * Configure UART console.
- static void configure_console(void)
- const usart_serial_options_t uart_serial_options = {
- .baudrate = CONF_UART_BAUDRATE,
- .paritytype = CONF_UART_PARITY
- /** Configure console UART. */
- sysclk_enable_peripheral_clock(CONSOLE_UART_ID);
- stdio_serial_init(CONF_UART, &uart_serial_options);
- * \brief Application entry point for smc_lcd example.
- * \return Unused (ANSI-C compatibility).
- int main(void)
- sysclk_init();
- board_init();
- /** Initialize debug console */
- configure_console();
- /** Enable peripheral clock */
- pmc_enable_periph_clk(ID_SMC);
- /** Configure SMC interface for Lcd */
- smc_set_setup_timing(SMC, ILI93XX_LCD_CS, SMC_SETUP_NWE_SETUP(2)
- | SMC_SETUP_NCS_WR_SETUP(2)
- | SMC_SETUP_NRD_SETUP(2)
- | SMC_SETUP_NCS_RD_SETUP(2));
- smc_set_pulse_timing(SMC, ILI93XX_LCD_CS, SMC_PULSE_NWE_PULSE(4)
- | SMC_PULSE_NCS_WR_PULSE(4)
- | SMC_PULSE_NRD_PULSE(10)
- | SMC_PULSE_NCS_RD_PULSE(10));
- smc_set_cycle_timing(SMC, ILI93XX_LCD_CS, SMC_CYCLE_NWE_CYCLE(10)
- | SMC_CYCLE_NRD_CYCLE(22));
- #if ((!defined(SAM4S)) && (!defined(SAM4E)))
- smc_set_mode(SMC, ILI93XX_LCD_CS, SMC_MODE_READ_MODE
- | SMC_MODE_WRITE_MODE
- | SMC_MODE_DBW_8_BIT);
- #else
- | SMC_MODE_WRITE_MODE);
- #endif
- /** Initialize display parameter */
- g_ili93xx_display_opt.ul_width = ILI93XX_LCD_WIDTH;
- g_ili93xx_display_opt.ul_height = ILI93XX_LCD_HEIGHT;
- g_ili93xx_display_opt.foreground_color = COLOR_BLACK;
- g_ili93xx_display_opt.background_color = COLOR_WHITE;
- /** Switch off backlight */
- aat31xx_disable_backlight();
- /** Initialize LCD */
- ili93xx_init(&g_ili93xx_display_opt);
- /** Set backlight level */
- aat31xx_set_backlight(AAT31XX_AVG_BACKLIGHT_LEVEL);
- ili93xx_set_foreground_color(COLOR_WHITE);
- ili93xx_draw_filled_rectangle(0, 0, ILI93XX_LCD_WIDTH,
- ILI93XX_LCD_HEIGHT);
- /** Turn on LCD */
- ili93xx_display_on();
- ili93xx_set_cursor_position(0, 0);
- /** Draw text, image and basic shapes on the LCD */
- ili93xx_set_foreground_color(COLOR_BLACK);
- ili93xx_draw_string(10, 20, (uint8_t *)"ili93xx_lcd example");
- ili93xx_set_foreground_color(COLOR_RED);
- ili93xx_draw_circle(60, 160, 40);
- ili93xx_set_foreground_color(COLOR_GREEN);
- ili93xx_draw_circle(120, 160, 40);
- ili93xx_set_foreground_color(COLOR_BLUE);
- ili93xx_draw_circle(180, 160, 40);
- ili93xx_set_foreground_color(COLOR_VIOLET);
- ili93xx_draw_line(0, 0, 240, 320);
- while (1) {
至于SMC的具体分析下一帖说明。
