关于51单片机LED矩阵流水显示时间怎么加长
 楼主| zoufeng0720 发表于 2020-3-5 21:46 | 显示全部楼层 |阅读模式
关于51单片机LED矩阵流水显示时间怎么加长  怎么把0显示两秒后再 再黑屏1秒  再显示2 两秒钟.....这样流水显示0.1.23.4.5.6......
#include<reg51.h>                //调用头文件
#include<intrins.h>     //包含有左移 右移 延时nop
typedef unsigned int u16;//数据类型声明定义
typedef unsigned char u8;
sbit SRCLK=P3^6;                   //   接P3-6口 74HC595 移位寄存器时钟输入 上升沿有效
sbit RCLK=P3^5;                   //         接P3-5口  数据 存储送入锁存器     上升沿有效
sbit SER=P3^4;                   //   接P3-4口   串行数据输入 一个字节
u8 code LEDduan[][8]={{0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
{0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
{0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
{0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
{0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
{0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
{0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
{0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
{0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
{0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
{0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
{0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
{0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
{0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
{0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
{0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
{0x00,0x7F,0x10,0x08,0x04,0x7F,0x00,0x00}, //N
{0x00,0x12,0x14,0x78,0x14,0x12,0x00,0x00},  //大
{0x00,0x08,0x12,0x01,0xFF,0x00,0x10,0x08},   //小
{0x7F,0x41,0x5D,0x55,0x5D,0x41,0x7F,0x00},  //回
{0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00}};  //中
u8 LEDwei[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
void delay(u16 i)//定义延时函数
while(i--);
void HC595Send(u8 dat) //定义HC595函数,dat是形式参数          dat表示要输入数据
        u8 i ;
        SRCLK=0;           //移位时钟清零
        RCLK=0;                   //锁存输出清零
        for(i=0;i<8;i++)         //循环8次,从高位到低位 逐位输出8位SER数据
          SER=dat>>7;
          /* 将dat右移7位 赋值给SER  dat数据不变 ; 例如 1001 1011  经过右移7位后
                                后7位全部移走 只剩之前最高位的1 ,1赋值给SER的最低位;
                                                        若下次循环,再赋值给SER的次最低位
                                            SER输出的值
   输入串行dat数据                        0
        1001 1011  →→→→→→                1
          dat<<=1;                          //dat左移1位,最高位移走 最低位补0;例如dat的值1001 1011左移一位以后 dat的值是0011 0110  这是为下次移次低高位做准备  下次移0011 0110 最高位的0
          SRCLK=1;                          //输出移位时钟信号,HC595锁存器从低到高移动一位锁存
          _nop_();                      // 延时一个周期
          _nop_();
          SRCLK=0;                           //移位寄存器拉低,为下次移位存储拉高准备
        RCLK=1;                             //锁存已经全部移好的数据
void   main()
        while(1)
                u8 i,j,k=0;
                for(j=0;j<100;j++)
                    for(i=0;i<8;i++)
                HC595Send(LEDduan[k][i]);
                P0=LEDwei[i];
                        delay(100);
                  delay(3000);
                  HC595Send(0x0);
                  delay(1000000000000000);
                  k++;
                 if(k==21)k=0;
 楼主| zoufeng0720 发表于 2020-3-5 21:47 | 显示全部楼层
求大神 修改
叶春勇 发表于 2020-3-6 08:43 | 显示全部楼层
  1. void LED_show(uint8_t ch) //码表增加一个空格
  3.         uint8_t i=0;
  4.         for(i=0;i<8;i++)
  5.         {
  6.                 HC595Send(LEDduan[ch][i]);
  7.                 P0=LEDwei[i];
  8.                 delay(100);
  9.         }
  10. }
  11. void LED_off(void) //码表不增加一个空格,专门搞个关闭
  12. {
  13.         uint8_t i=0;
  14.         for(i=0;i<8;i++)
  15.         {
  16.                 HC595Send(0);
  17.                 P0=LEDwei[i];
  18.                 delay(100);
  19.         }
  20. }
  21. void main()
  22. {
  23.         u8 i,j,k=0;
  24.         while(1)
  25.         {
  26.                 switch(state)
  27.                 {
  28.                 case 0:
  29.                         LED_show(k);
  30.                         if(++timer_acc>xxxx) //xxxx自己弄出3秒,最好用定时器控制。
  31.                         {
  32.                                 timer_acc=0;
  33.                                 state=1;
  34.                         }
  35.                         break;
  36.                 case 1:
  37.                         LED_off();
  38.                         if(++timer_acc>yyyy) //yyyy自己弄出1秒,最好用定时器控制。
  39.                         {
  40.                                 timer_acc=0;
  41.                                 state=0;
  42.                                 if((++k)>=20) k=0;
  43.                         }
  44.                         break;
  45.                 default:
  46.                         break;
  47.                 }
  48.    }
  49. }
用状态机来搞就是了
cainiao518 发表于 2020-3-6 09:20 | 显示全部楼层
用定时器来延时配合状态机实现
123654789 发表于 2020-3-6 09:44 | 显示全部楼层
while(i--);
超出 0xffff 了
xyz549040622 发表于 2020-3-6 10:19 | 显示全部楼层
delay函数太牛……逼了。。。
确实厉害。。。。我咋就没想过这么写呢  发表于 2020-3-6 11:44
xyz549040622 发表于 2020-3-6 10:23 | 显示全部楼层
参考二楼的,如果你显示的是规律的,显示里面加延时函数,如果这个时间不规律,参考二楼的,用状态机。还有就是,那个延时函数可以用定时器做,更精确,也方便修改。
 楼主| zoufeng0720 发表于 2020-3-6 21:46 | 显示全部楼层
用状态机来搞就是了
state 应该要赋值吧   不然swith  怎么选择case 呢
 楼主| zoufeng0720 发表于 2020-3-6 22:59 | 显示全部楼层
用状态机来搞就是了
if(++timer_acc>xxxx)  看不懂
叶春勇 发表于 2020-3-7 07:46 | 显示全部楼层
参考代码
yzl100205 发表于 2020-3-24 10:35 | 显示全部楼层
学习了
Fimer 发表于 2020-3-24 14:08 | 显示全部楼层
