[应用相关] STM32F407通过自带USB驱动EC20
 楼主| 观海 发表于 2021-7-2 11:34 | 显示全部楼层 |阅读模式
EC20 4G模块可以通过串口和USB去驱动,但是串口速度比较慢,所以通过USB驱动才能提高通信速率。
硬件连接:
STM32F407:
watermark,type_ZmFuZ3poZW5naGVpdGk,shadow_10,text_aHR0cHM6Ly9ibG9nLmNzZG4ubmV0L3FxXzE1MTgxNTY5,size_16,color_FFFFFF,t_70.jpg
EC20模块:
部分参考代码:
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "usb_host.h"
#include "usbh_def.h"
#include "usbh_cdc.h"
#include "string.h"
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
void MX_USB_HOST_Process(void);
unsigned char recData[100];
unsigned int recLen;
void delay_ums(unsigned int i)
        unsigned int cnt;
        while(i--)
                cnt=33500;
                while(cnt--);
 楼主| 观海 发表于 2021-7-2 11:41 | 显示全部楼层
extern USBH_HandleTypeDef hUsbHostFS;
int main(void)
        unsigned int a;
        HAL_Init();
        SystemClock_Config();
        MX_GPIO_Init();
        MX_USART1_UART_Init();
        MX_USB_HOST_Init();
        MX_GPIO_Init();
        HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0, GPIO_PIN_SET);
        delay_ums(1000);
        HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0, GPIO_PIN_RESET);
  while (1)
    /* USER CODE END WHILE */
    MX_USB_HOST_Process();
        delay_ums(1);
          a++;
          if(a>1000)
                  a=0;
                  USBH_CDC_Transmit(&hUsbHostFS, "AT\r\n", strlen("AT\r\n"));
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
 楼主| 观海 发表于 2021-7-2 11:42 | 显示全部楼层
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 4;
  RCC_OscInitStruct.PLL.PLLN = 168;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
 楼主| 观海 发表于 2021-7-2 11:43 | 显示全部楼层
  * @brief USART1 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART1_Init 0 */
  /* USER CODE END USART1_Init 0 */
  /* USER CODE BEGIN USART1_Init 1 */
  /* USER CODE END USART1_Init 1 */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART1_Init 2 */
  /* USER CODE END USART1_Init 2 */
 楼主| 观海 发表于 2021-7-2 11:45 | 显示全部楼层
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
        /* GPIO Ports Clock Enable */
        __HAL_RCC_GPIOH_CLK_ENABLE();
        __HAL_RCC_GPIOA_CLK_ENABLE();
        __HAL_RCC_GPIOC_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  /*Configure GPIO pin : PA15 */
  GPIO_InitStruct.Pin = GPIO_PIN_15;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_15, GPIO_PIN_SET);
  GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_2;
  HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
  HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0|GPIO_PIN_2, GPIO_PIN_RESET);
 楼主| 观海 发表于 2021-7-2 11:46 | 显示全部楼层
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  /* USER CODE END Error_Handler_Debug */
 楼主| 观海 发表于 2021-7-2 11:47 | 显示全部楼层
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
 楼主| 观海 发表于 2021-7-2 11:51 | 显示全部楼层
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
void USBH_CDC_ReceiveCallback(USBH_HandleTypeDef *phost)
        recLen = USBH_CDC_GetLastReceivedDataSize(phost);
        HAL_UART_Transmit_IT(&huart1 ,(uint8_t*)recData,recLen);
        while(__HAL_UART_GET_FLAG(&huart1,UART_FLAG_TC)!=SET);                //等待发送结束
        memset(recData,0x00,sizeof(recData));
主要是通过USB不停的发`AT\r\n`指令,然后串口打印输出USB接收到的数据,从而判断通信是否合适。
