ISE 将Verilog小模块封装为IP
 楼主| wolfskin 发表于 2022-1-17 11:34 | 显示全部楼层 |阅读模式
一个很简单的小程序,想将程序内部一个Verilog小模块封装为IP。目前已将该小模块按照网上资料封装为*.ngc和*.v(只含端口定义),添加到顶层工程文件中,这个顶层工程在Synthesize、Implement Design均能通过编译,而在Generate Programming File出错,已确认管脚分配正确,不知道哪里出了问题?请教!!!!!
错误提示为:
ERROR:PhysDesignRules:368 - The signal <oData_1_OBUF> is incomplete. The signal
   is not driven by any source pin in the design.
ERROR:PhysDesignRules:10 - The network <oData_1_OBUF> is completely unrouted.
