[STM32] 模数转换器 SIG5530 国产替代 CS5530
 楼主| slot867 发表于 2024-3-6 16:12 | 显示全部楼层 |阅读模式
信格勒微电子的芯片产品已通过行业头部大厂导入验证,深受百万终端客户好评。
而且因为 fully compatible. 板子拿来,换个芯片,性能更好MCU 不用改 c code。
SIG5530
1.6SPS to 3840SPS 24-bit ADC with PGA GAIN = 64
Compatible Parts
CS5530 pin/register fully compatible (10nV/℃ and 2ppm/℃).
Features
  • Programmable Gain:64
  • Data Rates: 1.6SPS to 3840SPS
  • RMS Noises: 16nV at 4.17SPS (Gain = 128)
  • Offset Drift: 5nV/℃ (Gain = 128)
  • Gain Drift: 0.5ppm/℃
  • Integral Non-linearity: 3ppm
  • Reference input current: 250nA
  • Internal or External Clock
  • SINC3/SINC1 Filter Option
  • 2 Differential Inputs
  • Current: 4.0mA
  • Specified Temperature Range: -40℃ to 125℃
  • Package: 20-ld TSSOP
  • Power Supply
AVDD:
4.75V to 5.25V or ±2.5V
DVDD:
  2.7V to 5.25V
Applications
  • Weight Scales and Strain Gauges
  • Flow/Pressure Measurement
  • Temperature Measurement
  • Industrial Process Control
  • Medical Instrumentation
