Highest-Performing ARM Cortex-M7 based MCUsDownload Now
The Atmel | SMART ARM® Cortex®-M7 based MCUs deliver the highest performing Cortex-M7 based MCUs to the market with exceptional memory and connectivity options for design flexibility making them ideal for the automotive, IoT and industrial connectivity markets. With a 1500 CoreMark Score, the series delivers superior connectivity options and unique memory architecture optimized for real-time deterministic code execution and low Latency peripheral data access. All devices run at speeds up to 300 MHz with up to 2048 KB Flash allowing customers to scale-up performance and deliver SRAM and system functionality, while keeping the Cortex-M processor family ease-of-use and maximizing software reuse. Additional common features include: USART, SPI, I2C, 12-bit ADC & DAC, SDIO, HW encryption, and available in 64 to 144 pin options.
| Flas
(KB) | RAM
(KB) | SDRAM/
QSPI | Ethernet
AVB | Dual
CAN-FD | MediaLB | HS
USB | Camera
I/F | LCD
I/F | Grade | | 512 - 2048 | 256 - 384 | | - | - | - | | | SPI, 8/16-bit// | Industrial | | 512 - 2048 | 256 - 384 | | | | - | | | SPI, 8/16-bit// | Industrial | | 512 - 1024 | 256 - 384 | | - | | | | | SPI, 8/16-bit// | Auto | | 512 - 2048 | 256 - 384 | | | | | | | SPI, 8/16-bit// | Auto |
SAM S - Scalable Performance, Memory Density and Power EfficiencyThe Atmel® | SMART SAM S70 series of general-purpose Flash microcontrollers (MCUs) are based on the high-performance 32-bit ARM® Cortex®-M7 RISC processors with floating point unit (FPU). They operate at a maximum speed of 300MHz and feature up to 2048KB of Flash, dual 16KB of cache memory and up to 384KB of SRAM. The Atmel | SMART SAM S series offers an extensive peripheral set, including High Speed USB Host and Device plus phy, up to 8 UARTs, I2S, SD/MMC interface, a CMOS camera interface, system control and analog interfaces. Learn More SAM E - High Performance and Advanced Connectivity for Industrial ApplicationsThe Atmel® | SMART SAM E70 series of general-purpose Flash microcontrollers (MCUs) are based on the high-performance 32-bit ARM® Cortex®-M7 RISC processors with floating point unit (FPU). They operate at a maximum speed of 300MHz and feature up to 2048KB of Flash, dual 16KB of cache memory and up to 384KB of SRAM. The SAM E70 series offers the same peripherals as the SAM S70 series with the addition of CAN and Ethernet capabilities. The SAM E70 series is also pin compatible with the Atmel │ SMART SAM4E ARM Cortex-M4 series. Learn More SAM V - High Performance plus Ethernet AVB Connectivity for Automotive Infotainment and TelematicsThe Atmel® ǀ SMART SAM V ARM® - based Automotive Microcontrollers focus on in-vehicle infotainment connectivity for Audio Amplifiers, Telematic Control Units or Head Units. The SAM V ARM Cortex™-M7 based Microcontroller series provides the best combination of connectivity interfaces including Ethernet AVB, MediaLB, USB and CAN-FD along with the highest performance ARM Cortex-M core delivering up to 1500 CoreMarks. The SAM V70 is specifically designed for MediaLB connectivity along with advanced audio processing by leveraging the unique multi-port memory architecture and advanced Cortex-M7 DSP capabilities. The SAM V71 series mirrors the SAM V70 features in addition to combining Ethernet-AVB and MediaLB connectivity along with advanced audio processing. Learn More
