[CAN-bus/DeviceNet] 谁能帮我看看这段英文
2547|1
 楼主| wxj1952 发表于 2007-8-27 08:27 | 显示全部楼层 |阅读模式
1.&nbsp;FIFO&nbsp;time-out&nbsp;interrupt&nbsp;occurs&nbsp;if&nbsp;the&nbsp;following&nbsp;conditions&nbsp;exist:<br />a.&nbsp;At&nbsp;least&nbsp;one&nbsp;character&nbsp;is&nbsp;in&nbsp;the&nbsp;FIFO.<br />b.&nbsp;The&nbsp;most&nbsp;recent&nbsp;serial&nbsp;character&nbsp;was&nbsp;received&nbsp;more&nbsp;than&nbsp;four&nbsp;continuous&nbsp;character&nbsp;times&nbsp;ago&nbsp;(if&nbsp;two&nbsp;stop&nbsp;bits&nbsp;are&nbsp;programmed,&nbsp;the&nbsp;second&nbsp;one&nbsp;is&nbsp;included&nbsp;in&nbsp;this&nbsp;time&nbsp;delay).<br />c.&nbsp;The&nbsp;most&nbsp;recent&nbsp;microprocessor&nbsp;read&nbsp;of&nbsp;the&nbsp;FIFO&nbsp;has&nbsp;occurred&nbsp;more&nbsp;than&nbsp;four&nbsp;continuous&nbsp;character&nbsp;times&nbsp;before.&nbsp;This&nbsp;causes&nbsp;a&nbsp;maximum&nbsp;character&nbsp;received&nbsp;command&nbsp;to&nbsp;interrupt&nbsp;an&nbsp;issued&nbsp;delay&nbsp;of&nbsp;160ms&nbsp;at&nbsp;a&nbsp;300&nbsp;baud&nbsp;rate&nbsp;with&nbsp;a&nbsp;12-bit&nbsp;character.<br /><br />*************************************<br /><br />如要参考下文:<br />2.&nbsp;Character&nbsp;times&nbsp;are&nbsp;calculated&nbsp;by&nbsp;using&nbsp;the&nbsp;RCLK&nbsp;input&nbsp;for&nbsp;a&nbsp;clock&nbsp;signal&nbsp;(makes&nbsp;the&nbsp;delay&nbsp;proportional&nbsp;to&nbsp;the&nbsp;baud&nbsp;rate).<br />3.&nbsp;When&nbsp;a&nbsp;time-out&nbsp;interrupt&nbsp;has&nbsp;occurred,&nbsp;it&nbsp;is&nbsp;cleared&nbsp;and&nbsp;the&nbsp;timer&nbsp;is&nbsp;cleared&nbsp;when&nbsp;the&nbsp;microprocessor&nbsp;reads&nbsp;one&nbsp;character&nbsp;from&nbsp;the&nbsp;receiver&nbsp;FIFO.<br />4.&nbsp;When&nbsp;a&nbsp;time-out&nbsp;interrupt&nbsp;has&nbsp;not&nbsp;occurred,&nbsp;the&nbsp;time-out&nbsp;timer&nbsp;is&nbsp;cleared&nbsp;after&nbsp;a&nbsp;new&nbsp;character&nbsp;is&nbsp;received&nbsp;or&nbsp;after&nbsp;the&nbsp;microprocessor&nbsp;reads&nbsp;the&nbsp;receiver&nbsp;FIFO.<br />
 楼主| wxj1952 发表于 2007-8-27 19:39 | 显示全部楼层
re:
真棒,很受启发。谢谢你。<br /><br />
