Do you know what is the "legacy-free" PC revolution ?
3556|9
 楼主| mxh0506 发表于 2008-2-22 10:13 | 显示全部楼层 |阅读模式
This&nbsp;is&nbsp;an&nbsp;excerpt&nbsp;from&nbsp;microsoft.com:<br /><br />The&nbsp;&quot;legacy-free&quot;&nbsp;PC&nbsp;revolution&nbsp;will&nbsp;eliminate&nbsp;not&nbsp;only&nbsp;legacy&nbsp;connection&nbsp;ports&nbsp;such&nbsp;as&nbsp;serial,&nbsp;parallel,&nbsp;and&nbsp;PS/2&nbsp;but&nbsp;also&nbsp;legacy&nbsp;expansion&nbsp;buses&nbsp;such&nbsp;as&nbsp;ISA&nbsp;and&nbsp;PCI&nbsp;in&nbsp;mainstream&nbsp;PCs.<br /><br />It&nbsp;seems&nbsp;that&nbsp;a&nbsp;lot&nbsp;of&nbsp;old&nbsp;familiar&nbsp;interfaces&nbsp;will&nbsp;be&nbsp;removed&nbsp;in&nbsp;the&nbsp;new&nbsp;PCs.
happystar 发表于 2008-2-22 20:46 | 显示全部楼层
翻译一下
你知道什么是消除PC包袱的变革吗?<br />以下摘自微软公司:<br />在主流PC上要实现消除PC包袱的变革,不但将要淘汰传统留下来的连接端口,比如串口、并口和PS/2接口等,而且还要淘汰遗留下来的ISA,PCI等总线扩展接口。<br />看来在主流PC上,许多我们熟悉老式接口将要升级啦。
ic921 发表于 2008-2-22 23:02 | 显示全部楼层
以下摘自Microsoft网站?
yixiao2000 发表于 2008-2-23 08:27 | 显示全部楼层
oh
if&nbsp;this&nbsp;is&nbsp;realy,How&nbsp;to&nbsp;connect&nbsp;one&nbsp;device&nbsp;with&nbsp;PC&nbsp;to&nbsp;communicate?
happystar 发表于 2008-2-23 17:35 | 显示全部楼层
re
i&nbsp;think&nbsp;that&nbsp;Microsoft&nbsp;company&nbsp;will&nbsp;also&nbsp;develop&nbsp;a&nbsp;device&nbsp;which&nbsp;used&nbsp;for&nbsp;converting&nbsp;this&nbsp;new&nbsp;interface&nbsp;to&nbsp;other&nbsp;ports&nbsp;such&nbsp;as&nbsp;serial&nbsp;port.<br />for&nbsp;example&nbsp;if&nbsp;you&nbsp;want&nbsp;to&nbsp;communite&nbsp;with&nbsp;PC&nbsp;with&nbsp;RS232,so&nbsp;you&nbsp;can&nbsp;connect&nbsp;port&nbsp;to&nbsp;this&nbsp;new&nbsp;device.<br />
123654789 发表于 2008-2-23 17:46 | 显示全部楼层
123654789
楼上的英语应该修改<br />1&nbsp;.&nbsp;把which&nbsp;used&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;改为which&nbsp;is&nbsp;used<br />2&nbsp;.&nbsp;把&nbsp;&nbsp;communite<br />&nbsp;&nbsp;&nbsp;&nbsp;改为communicate&nbsp;<br /><br />3&nbsp;.&nbsp;communite&nbsp;with&nbsp;PC&nbsp;with&nbsp;RS232,&nbsp;&nbsp;&nbsp;(两个with&nbsp;&nbsp;???)<br /><br /><br /><br /><br /><br /><br /><br /><br />happystar&nbsp;发表于&nbsp;2008-2-23&nbsp;17:35&nbsp;↑English&nbsp;Corner&nbsp;←返回版面&nbsp;&nbsp;&nbsp;&nbsp;<br /><br />6楼:&nbsp;re&nbsp;<br /><br />i&nbsp;think&nbsp;that&nbsp;Microsoft&nbsp;company&nbsp;will&nbsp;also&nbsp;develop&nbsp;a&nbsp;device&nbsp;which&nbsp;used&nbsp;for&nbsp;converting&nbsp;this&nbsp;new&nbsp;interface&nbsp;to&nbsp;other&nbsp;ports&nbsp;such&nbsp;as&nbsp;serial&nbsp;port.<br />for&nbsp;example&nbsp;if&nbsp;you&nbsp;want&nbsp;to&nbsp;communite&nbsp;with&nbsp;PC&nbsp;with&nbsp;RS232,so&nbsp;you&nbsp;can&nbsp;connect&nbsp;port&nbsp;to&nbsp;this&nbsp;new&nbsp;device.&nbsp;<br />&nbsp;<br />
iC921 发表于 2008-2-23 23:33 | 显示全部楼层
123英语那么厉害
来当俺们老师吧
happystar 发表于 2008-2-24 10:27 | 显示全部楼层
thank Arab sister
 楼主| mxh0506 发表于 2008-2-25 22:24 | 显示全部楼层
Maybe the legacy interfaces can be virtualize
&nbsp;by&nbsp;the&nbsp;new&nbsp;one.&nbsp;The&nbsp;typical&nbsp;examples&nbsp;are&nbsp;virtual&nbsp;serial&nbsp;port&nbsp;and&nbsp;virtual&nbsp;parallel&nbsp;port&nbsp;over&nbsp;USB.&nbsp;The&nbsp;old&nbsp;applications&nbsp;can&nbsp;still&nbsp;use&nbsp;these&nbsp;virtual&nbsp;devices&nbsp;as&nbsp;if&nbsp;there&nbsp;were&nbsp;still&nbsp;in&nbsp;the&nbsp;system.&nbsp;Thus&nbsp;the&nbsp;availability&nbsp;of&nbsp;the&nbsp;legacy&nbsp;interfaces&nbsp;is&nbsp;not&nbsp;a&nbsp;matter&nbsp;of&nbsp;hardware,&nbsp;but&nbsp;pure&nbsp;software&nbsp;drivers.
平常人 发表于 2008-2-25 22:31 | 显示全部楼层
It is not the matter of how to integrate legacy device.
It&nbsp;is&nbsp;the&nbsp;matter&nbsp;of&nbsp;who&nbsp;makes&nbsp;the&nbsp;standard.&nbsp;It&nbsp;is&nbsp;the&nbsp;matter&nbsp;of&nbsp;who&nbsp;makes&nbsp;money.&nbsp;It&nbsp;is&nbsp;the&nbsp;matter&nbsp;of&nbsp;who&nbsp;controls&nbsp;the&nbsp;world.
