请教几个专业术语blocking and selectivity
2992|4
 楼主| shanbaoyin 发表于 2008-10-14 19:43 | 显示全部楼层 |阅读模式
在看cc1020的data&nbsp;sheet,看不懂呀,请高手翻译下<br />The&nbsp;blocking&nbsp;rejection&nbsp;is&nbsp;the&nbsp;ratio&nbsp;between&nbsp;a&nbsp;modulated&nbsp;blocker&nbsp;(interferer)&nbsp;and&nbsp;a&nbsp;wanted&nbsp;signal&nbsp;3&nbsp;dB&nbsp;above&nbsp;the&nbsp;sensitivity&nbsp;limit.
 楼主| shanbaoyin 发表于 2008-10-14 19:48 | 显示全部楼层
还有Exposed die attached pad是哪种地,怎么翻译
haiyourong 发表于 2008-10-23 21:17 | 显示全部楼层
怎么没人回阿
myic200610 发表于 2008-11-13 00:01 | 显示全部楼层
RE
你的句子中并没有selectivity这个单词呀?!!!
宇宙飞船 发表于 2008-11-22 23:02 | 显示全部楼层
没时间看原文,
不过总觉得这段话有错误,<br />The&nbsp;blocking&nbsp;rejection&nbsp;is&nbsp;the&nbsp;ratio&nbsp;between&nbsp;a&nbsp;modulated&nbsp;blocker&nbsp;(interferer)&nbsp;and&nbsp;a&nbsp;wanted&nbsp;signal&nbsp;3&nbsp;dB&nbsp;above&nbsp;the&nbsp;sensitivity&nbsp;limit.<br />//----------------------------<br />The&nbsp;blocking&nbsp;rejection&nbsp;....&nbsp;<br />The&nbsp;blocking&nbsp;rejection&nbsp;that&nbsp;....//改成这才好理解。<br />。。。。。。。。<br />a&nbsp;wanted&nbsp;signal&nbsp;3&nbsp;dB&nbsp;above&nbsp;the&nbsp;sensitivity&nbsp;limit.<br />需要大于3dB灵敏度界限的信号。<br /><br />the&nbsp;ratio&nbsp;between&nbsp;A&nbsp;and&nbsp;B&nbsp;.--&gt&nbsp;ratio&nbsp;在A&nbsp;与B之间,代入以上句子就有逻辑上的错误问题。<br />
