我的英文的项目描述,不知道大家能看懂不,有错误麻烦提
2458|0
 楼主| ijoy 发表于 2007-5-1 15:51 | 显示全部楼层 |阅读模式
ic, TI, IO, ni, se
明天要去用英文描述自己的项目,请大家指教!多谢多谢!<br /><br />1、A&nbsp;signal&nbsp;generator&nbsp;for&nbsp;“High&nbsp;voltage&nbsp;switch&nbsp;tester”<br />&nbsp;&nbsp;&nbsp;It&nbsp;contains&nbsp;three&nbsp;parts:&nbsp;the&nbsp;module&nbsp;of&nbsp;trigger,&nbsp;micro&nbsp;controller,&nbsp;signal&nbsp;generator.&nbsp;The&nbsp;microcontroller&nbsp;out&nbsp;puts&nbsp;12&nbsp;signals,&nbsp;and&nbsp;a&nbsp;555&nbsp;ic&nbsp;puts&nbsp;out&nbsp;a&nbsp;pulse&nbsp;with&nbsp;tunable&nbsp;frequency.<br />I&nbsp;have&nbsp;developed&nbsp;3&nbsp;version&nbsp;programs&nbsp;running&nbsp;on&nbsp;this&nbsp;PCB.<br /><br />2、A&nbsp;microphone&nbsp;control&nbsp;system&nbsp;of&nbsp;conference:<br />&nbsp;This&nbsp;is&nbsp;a&nbsp;communication&nbsp;system&nbsp;of&nbsp;multi-node&nbsp;inter&nbsp;communication.&nbsp;It&nbsp;based&nbsp;on&nbsp;RS232.&nbsp;there&nbsp;are&nbsp;two&nbsp;wireless&nbsp;module(2.4G)&nbsp;in&nbsp;each&nbsp;slave&nbsp;microphone,&nbsp;the&nbsp;one&nbsp;is&nbsp;a&nbsp;sending&nbsp;module,&nbsp;the&nbsp;other&nbsp;is&nbsp;a&nbsp;receiver.&nbsp;And&nbsp;each&nbsp;slave’s&nbsp;sending&nbsp;has&nbsp;a&nbsp;matching&nbsp;receiver&nbsp;built&nbsp;in&nbsp;the&nbsp;central&nbsp;controller.&nbsp;From&nbsp;this&nbsp;project,&nbsp;I&nbsp;learned&nbsp;the&nbsp;synthesis&nbsp;application&nbsp;of&nbsp;serial&nbsp;communication,&nbsp;as&nbsp;well&nbsp;as&nbsp;the&nbsp;communication&nbsp;format&nbsp;and&nbsp;verification.&nbsp;<br />
