这里的UART中断要怎么使用呢?
2180|8
 楼主| Larkinn 发表于 2015-8-17 17:40 | 显示全部楼层 |阅读模式
本人初学CYBLE,求大神指导
这里的UART中断要怎么使用呢?
是指外面的MCU串口发给蓝牙芯片的UART中断吗?还是蓝牙天线接收数据后的中断?
函数在BLE_HAL_INT.C源文件里面
* Function Name: CyBLE_Uart_Interrupt
* Summary:
*  Handles the Interrupt Service Routine for the UART.
* Parameters:
*  None
* Return:
*  None
CY_ISR(CyBLE_Uart_Interrupt)
    uint8  uartTxStatus = CyBLE_INTR_TX_SUCCESS;
    uint32 srcInterrupt = 0u;
    uint8 length = 0u;
    uint8 srcCount = 0u;
    uint8 uartRxStatus = CyBLE_INTR_RX_SUCCESS;
    uint8 receivedData[BLE_HAL_Uart_FIFO_SIZE] = {0u};
    /* Evaluate RX interrupt event */
    srcInterrupt = BLE_HAL_Uart_GetRxInterruptSourceMasked();
    if(0u != (srcInterrupt & BLE_HAL_Uart_INTR_RX_NOT_EMPTY))
        if(0u != (srcInterrupt & BLE_HAL_Uart_INTR_RX_PARITY_ERROR))
            uartRxStatus |= CyBLE_INTR_RX_PARITY_ERROR;
        if(0u != (srcInterrupt & BLE_HAL_Uart_INTR_RX_FRAME_ERROR))
            uartRxStatus |= CyBLE_INTR_RX_FRAME_ERROR;
        if(0u != (srcInterrupt & BLE_HAL_Uart_INTR_RX_OVERFLOW))
            uartRxStatus |= CyBLE_INTR_RX_OVERFLOW;
        if(uartRxStatus == CyBLE_INTR_RX_SUCCESS)
            length = (uint8)BLE_HAL_Uart_SpiUartGetRxBufferSize();
            for(srcCount = 0u; srcCount < length; srcCount++)
                receivedData[srcCount] = (uint8)BLE_HAL_Uart_SpiUartReadRxData();
        else
            BLE_HAL_Uart_SpiUartClearRxBuffer();
        for(uartTxStatus = 0u; uartTxStatus < length; uartTxStatus++)
            CyBLE_pf_handle_uart_rx_data(receivedData[uartTxStatus]);
        BLE_HAL_Uart_ClearRxInterruptSource(srcInterrupt);
    else
        /* No RX interrupt. Do nothing. */
    /* Evaluate TX interrupt event in sequence */
    srcInterrupt = BLE_HAL_Uart_GetTxInterruptSourceMasked();
    /* Stack manager TX uart complete */
    if(0u != (srcInterrupt & BLE_HAL_Uart_INTR_TX_UART_DONE))
        if(0u != (srcInterrupt & BLE_HAL_Uart_INTR_TX_OVERFLOW))
            /*Stack manager TX uart error */
            uartTxStatus |= CyBLE_INTR_TX_OVERFLOW;
        CyBLE_pf_handle_uart_tx_complt();
        BLE_HAL_Uart_ClearTxInterruptSource(srcInterrupt);
    else
        /* No TX interrupt. Do nothing. */
上山砍老虎 发表于 2015-8-18 08:38 | 显示全部楼层
根据这个程序看,应该是你的串口收到数据的中断吧
关小波522 发表于 2015-8-18 08:39 | 显示全部楼层
建议楼主好好看下你的原理图,再看看你的程序,分析下
 楼主| Larkinn 发表于 2015-8-18 09:13 | 显示全部楼层
嗯嗯,我想用蓝牙的Broadcaster模式,只广播血压值到手机APP端,不知道BLE是怎么接收从单片机串口发来的数据的,上面贴的是Creator 自动生成的代码,不知道是不是用这个中断函数。
 楼主| Larkinn 发表于 2015-8-18 09:21 | 显示全部楼层
这两个中断函数如图分别是怎么使用的呢?求指教,谢谢~
leijixiaomile 发表于 2015-8-18 13:52 | 显示全部楼层
楼主,蓝牙广播血压信号,为何要用到串口中断呢?  直接在蓝牙的广播数据中添加血压信号就好了。
gll123 发表于 2015-8-18 14:10 | 显示全部楼层
:handshake赞楼上
 楼主| Larkinn 发表于 2015-8-18 16:16 | 显示全部楼层
楼主,蓝牙广播血压信号,为何要用到串口中断呢?  直接在蓝牙的广播数据中添加血压信号就好了。 ...
我是血压计主控IC 通过串口把血压数据发给蓝牙的,
 楼主| Larkinn 发表于 2015-9-7 22:53 | 显示全部楼层
是的
